[geos-devel] Another bug fix in JTS 1.4.1 for GEOS
Martin Davis mbdavis at VividSolutions.com
Tue May 18 14:46:00 EDT 2004
Yury, attached is a bug fix in JTS for a problem which has just come to
light.  (Buffers of some polygons with small & large were being computed
with no holes)
See line 184 - "return" replaced by "continue"
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: Yury A. Bychkov [mailto:me at yury.ca]
> Sent: May 17, 2004 5:02 PM
> To: 'GEOS Development List'
> Subject: RE: [geos-devel] Current status
> Fixed and committed. Now GEOS is ahead of JTS ;-)
> Yury
> > From: Martin Davis [mailto:mbdavis at VividSolutions.com]
> > Sent: Monday, May 17, 2004 2:27 PM
> > To: reply at yury.ca; GEOS Development List
> > Yury:
> > I've made one small bug fix to JTS since March.  (It will
> be in 1.4.1,
> > which we haven't quite released yet).  The change is minor
> - fixes a
> > bug which causes some kinds of MultiPolygons to report as invalid.
> > Seems to me you might as well implement this in GEOS as well right
> > now.  I've attached the file which changed (let me know if you need
> > help in figuring out the exact changes).
> > Martin
> > > Sent: May 17, 2004 2:16 PM
> > > Subject: [geos-devel] Current status
> > > The GEOS code is now completely up to date. It has been
> synchronized
> > > with the latest (March 26, 2004) changes to JTS. The changes were
> > > minor and wouldn't affect any test results.
> > > Yury
> > > _______________________________________________
> > > geos-devel mailing list
> > > geos-devel at geos.refractions.net
> > > http://geos.refractions.net/mailman/listinfo/geos-devel
Type: application/octet-stream
Desc: OffsetCurveSetBuilder.java
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20040518/77881b2c/OffsetCurveSetBuilder.obj
