[geos-devel] Another bug fix in JTS 1.4.1 for GEOS
Yury A. Bychkov me at yury.ca
Wed May 19 05:55:42 EDT 2004
Fixed.
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net [mailto:geos-devel-
> bounces at geos.refractions.net] On Behalf Of Martin Davis
> Sent: Tuesday, May 18, 2004 11:46 AM
> To: reply at yury.ca; GEOS Development List
> Subject: [geos-devel] Another bug fix in JTS 1.4.1 for GEOS
> Yury, attached is a bug fix in JTS for a problem which has just come to
> light.  (Buffers of some polygons with small & large were being computed
> with no holes)
> See line 184 - "return" replaced by "continue"
> Martin Davis, Senior Technical Architect
> Vivid Solutions Inc.
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> > From: Yury A. Bychkov [mailto:me at yury.ca]
> > Sent: May 17, 2004 5:02 PM
> > To: 'GEOS Development List'
> > Subject: RE: [geos-devel] Current status
> > Fixed and committed. Now GEOS is ahead of JTS ;-)
> > Yury
> > > From: Martin Davis [mailto:mbdavis at VividSolutions.com]
> > > Sent: Monday, May 17, 2004 2:27 PM
> > > Yury:
> > > I've made one small bug fix to JTS since March.  (It will
> > be in 1.4.1,
> > > which we haven't quite released yet).  The change is minor
> > - fixes a
> > > bug which causes some kinds of MultiPolygons to report as invalid.
> > > Seems to me you might as well implement this in GEOS as well right
> > > now.  I've attached the file which changed (let me know if you need
> > > help in figuring out the exact changes).
> > > Martin
> > > > Sent: May 17, 2004 2:16 PM
> > > > Subject: [geos-devel] Current status
> > > > The GEOS code is now completely up to date. It has been
> > synchronized
> > > > with the latest (March 26, 2004) changes to JTS. The changes were
> > > > minor and wouldn't affect any test results.
> > > > Yury
> > > > _______________________________________________
> > > > geos-devel mailing list
> > > > geos-devel at geos.refractions.net
> > > > http://geos.refractions.net/mailman/listinfo/geos-devel
