[geos-devel] left and right buffer
Stephen Woodbridge woodbri at swoodbridge.com
Wed May 17 14:22:07 EDT 2006
Hah! It is probably that I am missing something. I didn't know you could
apply a negative distance, but now that you mention it, that makes
perfect sense. I will try it when I get a chance.
I return you to your regularly scheduled programming!
Thanks,
   -Steve
Martin Davis wrote:
> Am I missing something?  Isn't this the functionality that negative
> buffer distances gives today?
> Martin Davis, Senior Technical Architect
> Vivid Solutions Inc.      www.vividsolutions.com
> Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
> Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
>>-----Original Message-----
>>From: geos-devel-bounces at geos.refractions.net
>>[mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
>>Stephen Woodbridge
>>Sent: May 17, 2006 10:06 AM
>>To: GEOS Development List
>>Subject: Re: [geos-devel] left and right buffer
>>Hi Martin,
>>I think a useful variant of this for polygons it to be able
>>to specify
>>inside or outside, so you could effectively grow and shrink
>>the polygon.
>>The "grow" option is great for finding abutters, and I think
>>the buffer
>>command today already does this.
>>The "shrink" option is great for defining/showing boundary offsets
>>within a lot that might be needed to insure zoning rules.
>>-Steve
>>Martin Davis wrote:
>>>I'm curious what your use case is for this functionality.  Can you
>>>post some sample data that you want L/R buffers for, and perhaps an
>>>image of what you expect the results to look like?
>>>>zhangjing
>>>>Sent: May 17, 2006 12:10 AM
>>>>To: geos-devel at geos.refractions.net
>>>>Subject: [geos-devel] left and right buffer
>>>>hi,
>>>>Is there any way in GEOS to calculate geometry's left or
>>>>right buffer ?
>>>>TIA
>>>>Jing Zhang
>>>>_______________________________________________
>>>>geos-devel mailing list
>>>>http://geos.refractions.net/mailman/listinfo/g> eos-devel
>>>http://geos.refractions.net/mailman/listinfo/geos-devel
