[geos-devel] left and right buffer
zhangjing jingzhang at cbigroup.com
Wed May 17 21:27:49 EDT 2006
Our client need a tool like ArcToolbox Buffer which has functionality of Left/Right/Full buffer, and i believe negative distances could not be applied to polyline geometry.
Thanks.
>Am I missing something?  Isn't this the functionality that negative
>buffer distances gives today?
>Martin Davis, Senior Technical Architect
>Vivid Solutions Inc.      www.vividsolutions.com
>Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
>Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
>> -----Original Message-----
>> From: geos-devel-bounces at geos.refractions.net
>> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
>> Stephen Woodbridge
>> Sent: May 17, 2006 10:06 AM
>> To: GEOS Development List
>> Subject: Re: [geos-devel] left and right buffer
>> Hi Martin,
>> I think a useful variant of this for polygons it to be able
>> to specify
>> inside or outside, so you could effectively grow and shrink
>> the polygon.
>> The "grow" option is great for finding abutters, and I think
>> the buffer
>> command today already does this.
>> The "shrink" option is great for defining/showing boundary offsets
>> within a lot that might be needed to insure zoning rules.
>> -Steve
>> Martin Davis wrote:
>> > I'm curious what your use case is for this functionality.  Can you
>> > post some sample data that you want L/R buffers for, and perhaps an
>> > image of what you expect the results to look like?
>> >>zhangjing
>> >>Sent: May 17, 2006 12:10 AM
>> >>To: geos-devel at geos.refractions.net
>> >>Subject: [geos-devel] left and right buffer
>> >>hi,
>> >>Is there any way in GEOS to calculate geometry's left or
>> >>right buffer ?
>> >>TIA
>> >>Jing Zhang
>> >>_______________________________________________
>> >>geos-devel mailing list
>> >>http://geos.refractions.net/mailman/listinfo/g> eos-devel
>> > http://geos.refractions.net/mailman/listinfo/geos-devel
