[geos-devel] left and right buffer
Martin Davis mbdavis at VividSolutions.com
Thu May 18 12:11:08 EDT 2006
Yes, I know that negative buffer won't doesn't handle left/right - that
suggestion was in answer to Stephen's question about "shrinking"
buffers.
What I'm looking for is some examples of what left/right buffers look
like (especially for pathological cases such as very narrow V shapes)
Martin Davis, Senior Technical Architect
Vivid Solutions Inc.      www.vividsolutions.com
Suite #1A-2328 Government Street Victoria, B.C. V8T 5G5
Phone: (250) 385 6040 - Local 308 Fax: (250) 385 6046
> -----Original Message-----
> From: geos-devel-bounces at geos.refractions.net
> [mailto:geos-devel-bounces at geos.refractions.net] On Behalf Of
> zhangjing
> Sent: May 17, 2006 6:28 PM
> To: GEOS Development List
> Subject: Re: RE: [geos-devel] left and right buffer
> Our client need a tool like ArcToolbox Buffer which has
> functionality of Left/Right/Full buffer, and i believe
> negative distances could not be applied to polyline geometry.
> Thanks.
> >Am I missing something?  Isn't this the functionality that negative
> >buffer distances gives today?
> >> Stephen Woodbridge
> >> Sent: May 17, 2006 10:06 AM
> >> Subject: Re: [geos-devel] left and right buffer
> >> Hi Martin,
> >> I think a useful variant of this for polygons it to be able
> >> to specify
> >> inside or outside, so you could effectively grow and shrink
> >> the polygon.
> >> The "grow" option is great for finding abutters, and I think
> >> the buffer
> >> command today already does this.
> >> The "shrink" option is great for defining/showing boundary offsets
> >> within a lot that might be needed to insure zoning rules.
> >> -Steve
> >> Martin Davis wrote:
> >> > I'm curious what your use case is for this
> functionality.  Can you
> >> > post some sample data that you want L/R buffers for, and
> perhaps an
> >> > image of what you expect the results to look like?
> >> >>zhangjing
> >> >>Sent: May 17, 2006 12:10 AM
> >> >>To: geos-devel at geos.refractions.net
> >> >>Subject: [geos-devel] left and right buffer
> >> >>hi,
> >> >>Is there any way in GEOS to calculate geometry's left or right
> >> >>buffer ?
> >> >>TIA
> >> >>Jing Zhang
> >> >>_______________________________________________
> >> >>geos-devel mailing list
> >> >>http://geos.refractions.net/mailman/listinfo/g> eos-devel
> >> > http://geos.refractions.net/mailman/listinfo/geos-devel
