[geos-devel] GEOS 3 RC4 refuses to build unless Python is installed
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Thu Feb 8 13:05:20 EST 2007
Hi everyone,
It appears as if the recently added AM_PATH_PYTHON macro defaults to
aborting configure if Python is not found. The attached patch allows
configure to continue with use_python set to false if a python binary is
not found, as per
http://sources.redhat.com/automake/automake.html#Python.
Kind regards,
Mark.
Type: text/x-patch
Desc: not available
Url : http://lists.osgeo.org/pipermail/geos-devel/attachments/20070208/b008b136/geos-rc4-python.bin
