[geos-devel] GEOS 3 RC4 refuses to build unless Python is installed
strk at refractions.net strk at refractions.net
Thu Feb 8 17:34:12 EST 2007
On Thu, Feb 08, 2007 at 06:05:20PM +0000, Mark Cave-Ayland wrote:
> It appears as if the recently added AM_PATH_PYTHON macro defaults to
> aborting configure if Python is not found. The attached patch allows
> configure to continue with use_python set to false if a python binary is
> not found, as per
> http://sources.redhat.com/automake/automake.html#Python.
Committed, thanks.
--strk;
