[geos-devel] speed difference between release and debug builds
Pete Gerritson pgerritson at adelphia.net
Thu Oct 11 18:43:08 EDT 2007
I've noticed some large performance differences between debug and release
builds using VC 8.0 when stl containers are used (not specifically with
geos, but in general).  I believe iterator debugging is enabled by default
in debug builds.  See
http://msdn2.microsoft.com/en-us/library/Aa985939(VS.80).aspx for more info.
You might try turning this off and see what effect it has.
Pete
----- Original Message -----
From: "Fabian Hohmuth" <fabian.hohmuth at pixelgrammetry.com>
To: "GEOS Development List" <geos-devel at geos.refractions.net>
Sent: Thursday, October 11, 2007 2:41 PM
Subject: [geos-devel] speed difference between release and debug builds
> Hi all,
> we're using GEOS via the C API under Windows (doing unions on a number of
> complex polygons) and noticed that there is a major (3x) speed difference
> between the Release and Debug builds. I somehow can't believe that the
> compiler optimization is that good. The defined preprocessor symbols are
> the same between the two configurations. Any hints where this could come
> from?
> Thanks,
> - Fabian
> geos-devel mailing list
> http://geos.refractions.net/mailman/listinfo/geos-devel
