[geos-devel] Union problem
Martin Davis mbdavis at refractions.net
Fri Apr 4 15:17:41 EDT 2008
This works fine in JTS.
Unfortunately I don't have GEOS running, so can't test it there.
Possibly we could look into that during some future work.
It is a bit suspicious that it looks like the offending point is the
terminating point of the last ring in the US MultiPolygon.
M
Martin Chapman wrote:
> Martin,
> Here you go.  It occurs when you union the US and Mexico. Thanks for your
> help!
> Best regards,
> Martin
> -----Original Message-----
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Martin Davis
> Sent: Thursday, April 03, 2008 12:32 PM
> To: GEOS Development List
> Subject: Re: [geos-devel] Union problem
> Send me the shapefile and I'll try it out in JTS.
> M
>> Unfortunately, I do not have JTS but I will try to step through the code
> and
>> see if I can learn more about the problem.  Perhaps a careful inspection
> of
>> the input and output point sets will yield some clues because the problem
> is
>> predictable.
>> Best regards,
>> Martin
>> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
>> Sent: Thursday, April 03, 2008 11:50 AM
>> Most probably a bug... any chance you could run this same test case
>> under JTS so we can confirm if it's a problem at the algorithm level
>> or the port level?
>> Thanks,
>> P
>> On Thu, Apr 3, 2008 at 10:47 AM, Martin Chapman <mchapman at texelinc.com>
>> wrote:
>>> All,
>>> When I union the two features USA and Mexico I end up with a geometry
> that
>>> has one point where the y or lat value for one point is zero.  See the
>>> attachment for what I mean.  Does anyone think this is a bug in GEOS or
> am
>> I
>>> not doing something correctly?  Most other geometric unions create good
>>> geometries.  If you want I can send the original shape file.
>>> Thanks for any help.
>>> Best regards,
>>> Martin
>>>  geos-devel mailing list
>>>  geos-devel at lists.osgeo.org
>>>  http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
