[geos-devel] Union problem
mchapman at texelinc.com mchapman at texelinc.com
Fri Apr 4 18:32:18 EDT 2008
Martin,
Thank you for confirming that.  I will look at my code and validate that I am not screwing up the points after the geos operation. If not, I will try my best to debug through the geos source and look for the problem.
By chance do you have a recommendation on where I should start looking in the union operation source code for this issue? Could I put a linearRing.isClosed() method call somewhere in the union code to trap the violating ring?
Thanks again for all your help!
Best regards,
Martin.
Sent via BlackBerry by AT&T
-----Original Message-----
Date: Fri, 04 Apr 2008 12:17:41
To:GEOS Development List <geos-devel at lists.osgeo.org>
Subject: Re: [geos-devel] Union problem
This works fine in JTS.
Unfortunately I don't have GEOS running, so can't test it there.
Possibly we could look into that during some future work.
It is a bit suspicious that it looks like the offending point is the
terminating point of the last ring in the US MultiPolygon.
M
Martin Chapman wrote:
> Martin,
> Here you go.  It occurs when you union the US and Mexico. Thanks for your
> help!
> Best regards,
> Martin
> From: geos-devel-bounces at lists.osgeo.org
> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Martin Davis
> Sent: Thursday, April 03, 2008 12:32 PM
> To: GEOS Development List
> Send me the shapefile and I'll try it out in JTS.
> M
>> Unfortunately, I do not have JTS but I will try to step through the code
> and
>> see if I can learn more about the problem.  Perhaps a careful inspection
> of
>> the input and output point sets will yield some clues because the problem
> is
>> predictable.
>> Best regards,
>> Martin
>> [mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul Ramsey
>> Sent: Thursday, April 03, 2008 11:50 AM
>> Most probably a bug... any chance you could run this same test case
>> under JTS so we can confirm if it's a problem at the algorithm level
>> or the port level?
>> Thanks,
>> P
>> On Thu, Apr 3, 2008 at 10:47 AM, Martin Chapman <mchapman at texelinc.com>
>> wrote:
>>> All,
>>> When I union the two features USA and Mexico I end up with a geometry
> that
>>> has one point where the y or lat value for one point is zero.  See the
>>> attachment for what I mean.  Does anyone think this is a bug in GEOS or
> am
>> I
>>> not doing something correctly?  Most other geometric unions create good
>>> geometries.  If you want I can send the original shape file.
>>> Thanks for any help.
>>> Best regards,
>>> Martin
>>>  geos-devel mailing list
>>>  http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
