[geos-devel] Thread Safe CAPI next steps?
Paul Ramsey pramsey at cleverelephant.ca
Fri Dec 19 14:25:06 EST 2008
Yes, separate tools, not part of the unit suite.
On Fri, Dec 19, 2008 at 11:14 AM, Chuck Thibert
<charles.thibert at ingres.com> wrote:
> Just wanted to be sure since all that is compiled into the unit test
> executable.  I don't think these tests go into the unit test tool but I
> have no problem putting them there and compiling into the separate tools
> if there are no objections.
> Chuck
> On Fri, 2008-12-19 at 08:50 -0800, Paul Ramsey wrote:
>> I would hazard tests/capi
>> Other thoughts?
>> P
>> On Fri, Dec 19, 2008 at 8:31 AM, Chuck Thibert
>> > Got the other comments worked out but I have a couple questions about
>> > moving the test programs.
>> > 1) The original test program, geostest.c has been there all along.  The
>> > new ones I added were copies of geostest.c.  Should everything be moved?
>> > 2) Where in the tests directory should they go? They aren't currently
>> > part of the unit testing.
>> > Thanks,
>> > Chuck
>> > On Wed, 2008-12-17 at 21:25 -0800, Paul Ramsey wrote:
>> >> On Wed, Dec 17, 2008 at 9:07 PM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
>> >> > - Also not glad to see the test programs in the midst of the other
>> >> > stuff. Subdir it?
>> >> No, really, in ./tests would be best. To answer myself.
>> >> P
>> >> _______________________________________________
>> >> geos-devel mailing list
>> >> geos-devel at lists.osgeo.org
>> >> http://lists.osgeo.org/mailman/listinfo/geos-devel
