[geos-devel] Thread Safe CAPI 2.0 patch online
Chuck Thibert charles.thibert at ingres.com
Fri Dec 19 15:42:56 EST 2008
Hi all,
I've changed the patch based on Paul's comments.
-- combined the two header files for easy maintenance. (This 'fixed' the
configure error by getting rid of the thread safe header.)
-- fixed the char * error.
-- changed the .c from geosTS_c.cpp to geos_ts_c.cpp
-- moved the test executables to tests/unit/capi directory.  This seemed
to cause patch a bit of problems so I created a little script that does
the svn move before applying the patch.
All this is in a new 2.0 tar file attached to the ticket.
Thanks again for the testing and comments Paul.
Chuck
