[geos-devel] Editing geometry
Blas Jimenez, Arturo ablas at indra.es
Wed Jan 30 02:12:38 EST 2008
> How are you planning to "add a point" to your (presumably) 100Mb long
> array of points in memory?
To add a point to an array of points it's not trivial, but an efficient
way to do it it's to maintain a list of pointers to points and add it at
the end or change intermediate pointers to insert at the middle of the
list.
> However you do this, you can them simply build a new Geometry sitting
on
> top of the modified array inside a CoordinateSequence.
I cannot do that because I would have been spending high amounts of
memory and time to get 'almost' the same that I had at the beginning.
It's unneficient to copy all the list to add a single point.
> The Javadoc of GeometryEditor in JTS explains how to use it. Not sure
if
> this is provided in GEOS - if not, download JTS 1.9 (
> http://sourceforge.net/projects/jts-topo-suite/) and have a look.
I have already take a look, but the documentation is very similar that
GEOS'.
How can be used GEOS geometry editors/filters? Is also with this method
necessary to copy the whole geometry to a new one)
Best regards.
geos-devel mailing list
geos-devel at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/geos-devel
