[geos-devel] Editing geometry
Martin Davis mbdavis at refractions.net
Wed Jan 30 11:38:51 EST 2008
Blas Jimenez, Arturo wrote:
>> How are you planning to "add a point" to your (presumably) 100Mb long
>> array of points in memory?
> To add a point to an array of points it's not trivial, but an efficient
> way to do it it's to maintain a list of pointers to points and add it at
> the end or change intermediate pointers to insert at the middle of the
> list.
I'm not sure I follow your logic, but the key point is that if you think
you have a structure that allows adding points efficiently and (more
importantly) allows accessing the points in an array fashion
efficiently, then just wrap it in a CoordinateSequence and use that to
build your geometries.  (A CoordinateSequence is just an interface - you
can have whatever implementation you want underneath it)
>> However you do this, you can them simply build a new Geometry sitting
> on
>> top of the modified array inside a CoordinateSequence.
> I cannot do that because I would have been spending high amounts of
> memory and time to get 'almost' the same that I had at the beginning.
> It's unneficient to copy all the list to add a single point.
>> The Javadoc of GeometryEditor in JTS explains how to use it. Not sure
> if
>> this is provided in GEOS - if not, download JTS 1.9 (
>> http://sourceforge.net/projects/jts-topo-suite/) and have a look.
> I have already take a look, but the documentation is very similar that
> GEOS'.
> How can be used GEOS geometry editors/filters? Is also with this method
> necessary to copy the whole geometry to a new one)
Filters don't require you to copy - but they also won't let you change
the length of the underlying array.
> Best regards.
> geos-devel mailing list
> geos-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/geos-devel
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
