[geos-devel] 3.0.3 To Do
Obe, Regina robe.dnd at cityofboston.gov
Mon Oct 27 10:56:00 EDT 2008
Sanak,
Sounds great.  Actually Paul has already applied the patch to geos 3.0
branch.  We left out the geos_test part though since it wasn't in trunk
so used just the original patch you sent.
Feel free to test it out.
Paul,
 When are you going to release a geos 3.0.3.  Maybe we should make it
geos 3.0.3 RC1 since if we continue going at this rate we'll catch up to
3.1 and then we'll be forced to release 3.1  :).
Thanks,
Regina
[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Sanak
Sent: Monday, October 27, 2008 10:43 AM
To: GEOS Development List
Subject: Re: [geos-devel] 3.0.3 To Do
Paul, Regina
Sorry, I am a Windows person, and have few knowledge of *nix and Mac
environment.
So please check Regina's modified patch. Thanks Regina.
On another note, I am a developer of GEOS COM
Wrapper(http://sourceforge.jp/projects/geos-com/) project.
Currently, the geos-com api interface is flat, and sample is VB6 only,
but in the future, I want to apply
swig-com(http://code.google.com/soc/2008/swig/appinfo.html?csaid=39B8865
043331AF) based api,
and add browser sample(use IE + OpenLayers, and has "JTS Test
Builder"-like user interface).
Please look forward to it!
Regards,
2008/10/25 Obe, Regina <robe.dnd at cityofboston.gov>
	Paul,
	Can you try applying this revised attached patch.  I ran into
the same
	issues you described when trying to apply the tortoise generated
patch
	to my OpenSUSE VM install.
	I used the original patch he sent since didn't want to fuss with
	updating trunk and I really don't want geos 3.0 having stuff
that trunk
	doesn't have.
	As a workaround I
	1) checked out  geos 3.0 on both OpenSUSE VM and windows
	2) patched my windows using tortoise svn with Sanak's patch
	3) uploaded changed files to OpenSuse VM
	4) Did a svn diff on my OpenSUSE to generate this new patch
	5) To test I wiped out my msvc8 on windows did svn checkout and
applied
	the patch I created in OpenSuse  and then did a build in VS8 to
make
	sure it worked.
	6) Also did the same thing in OpenSuse
	I'm sure there is a more elegant way to do this, but that's the
best I
	could do with my limited skill set :(.
	Thanks,
	Regina
	-----Original Message-----
	[mailto:geos-devel-bounces at lists.osgeo.org] On Behalf Of Paul
Ramsey
	Sent: Friday, October 24, 2008 11:50 AM
	I tried the earlier one and that didn't work either. I'm
suspecting my
	OS/X patch is (a) first stripping the CRs from the dos-generated
patch
	and then (b) not finding any matches in the dos-formatted target
file.
	I think someone else with a cygwin sandbox should apply this
patch.
	P.
	On Fri, Oct 24, 2008 at 8:46 AM, Obe, Regina
	wrote:
	> Paul,
	> The earlier one doesn't add any new files so may be more
appropriate.
	> This one adds a new geostest folder to the msvc80 and geostest
to the
	> solution to add the test that Frank was running using make.vc
(that
	does
	> the test.wkt compare thing).
	> Note:  this geostest isn't even in trunk so I'm questioning if
we
	really
	> want to include it in the geos 3.0 branch. If we do we should
include
	it
	> in trunk to be consistent.
	> Since we already have a unit test for VC and the unit test is
much
	> easier to use than the geostest, I question the value of
adding this
	> extra project to the solution.
	> Thanks,
	> Regina
	> From: geos-devel-bounces at lists.osgeo.org
Ramsey
	> Sent: Friday, October 24, 2008 11:39 AM
	> On Thu, Oct 23, 2008 at 9:48 PM, Obe, Regina
	> wrote:
	>> Actually which patch are you referring to.  The version one
or the
	big
	>> patch.  I just redownloaded the msvc80 folder from svn that
has your
	> version
	>> patch and then reapplied Sanak's patch and didn't run into
any
	> conflicts.
	> this one
	> geos-branches-3.0-build-msvc80_add_geostest.patch
	> should I be doing the earlier one?
	> P
	> geos-devel mailing list
	> geos-devel at lists.osgeo.org
	> http://lists.osgeo.org/mailman/listinfo/geos-devel
	> The substance of this message, including any attachments, may
be
	> confidential, legally privileged and/or exempt from disclosure
	> pursuant to Massachusetts law. It is intended
	> solely for the addressee. If you received this in error,
please
	> contact the sender and delete the material from any computer.
URL: http://lists.osgeo.org/pipermail/geos-devel/attachments/20081027/ab2112c7/attachment-0001.html
