[geos-devel] 3.1.0rc1
Sean Gillies sgillies at frii.com
Thu Jan 29 16:07:02 EST 2009
Another data point: I found Dane's shapefile to contain 100 polygons
and 145 multipolygons. I was able to cascade union a) the first
collection of 100 polygons, and also b) the collection of 3238
polygons exploded from the 145 multis. An attempt to cascade union
everything (a + b) failed, as you're finding.
http://lists.gispython.org/pipermail/community/2009-January/001963.html
Sean
On Jan 29, 2009, at 1:39 PM, Martin Davis wrote:
> I would have expected so - so I'm puzzled.  No further ideas at the
> moment, I'm afraid.
> Paul Ramsey wrote:
>> I can do an individual union of Mozambique and Zimbabwe without
>> problems. Should I be seeing a topology exception?
>> P
>> On Thu, Jan 29, 2009 at 12:09 PM, Martin Davis <mbdavis at refractions.net
>> > wrote:
>>> When I look at the area of the reported TopologyException in
>>> OpenJUMP, I'm
>>> seeing the following kinds of vertex values:
>>> Feature ID: 122
>>> [   3:0:666] POINT (32.476230999999984 -21.321853999999973)
>>> Feature ID: 222
>>> [     0:144] POINT (32.476231 -21.321854)
>>> So the dataset is not actually 100% cleanly noded.  These kinds of
>>> small
>>> discrepancies are exactly the kind of situation which used to cause
>>> robustness errors in JTS.  This has pretty much been fixed by the
>>> addition
>>> of the Geometry Snapping concept.  I think this made it into GEOS
>>> - but
>>> perhaps there's a bug in it?
>>> It should be possible to narrow down the problem by finding the two
>>> geometries which containing the problematic points and just
>>> working with
>>> them.  (Mozambique and Zimbabwe)
>>> Paul Ramsey wrote:
>>>> Incidentally, the problem is not the invalid geometries. I first
>>>> tried
>>>> the union after "fixing" them with buffer(0), but I just now
>>>> tried the
>>>> union after deleting them, with the same result.
>>>> aggtest=# delete from tm_world_2 where not st_isvalid(the_geom);
>>>> NOTICE:  Ring Self-intersection at or near point -53.7564 48.5033
>>>> NOTICE:  Ring Self-intersection at or near point -70.9172 -54.7086
>>>> NOTICE:  Ring Self-intersection at or near point 5.33694 61.5928
>>>> NOTICE:  Ring Self-intersection at or near point 143.662 49.3122
>>>> DELETE 4
>>>> aggtest=# select geometrytype(st_union(the_geom)) from tm_world_2;
>>>> NOTICE:  TopologyException: found non-noded intersection between
>>>> 32.4122 -21.2178, 32.4762 -21.3219 and 32.4762 -21.3219, 32.4122
>>>> -21.2178 32.4756 -21.3208
>>>> ERROR:  GEOS2POSTGIS returned an error
>>>> aggtest=#
>>>> P
>>>> On Wed, Jan 28, 2009 at 1:49 PM, Paul Ramsey
>>>> <pramsey at opengeo.org> wrote:
>>>>> For anyone that needs a test geometry, here's Dane's input as a
>>>>> single
>>>>> multipolygon:
>>>>> http://cleverelephant.dyndns.org/~pramsey/bigmulti.txt.bz2
>>>>> On Wed, Jan 28, 2009 at 7:44 AM, Hartmut Kaiser
>>>>> <hartmut.kaiser at gmail.com> wrote:
>>>>>>> I just did a bit further testing of the new cascaded union
>>>>>>> goodness
>>>>>>> via Shapely. See the linked email below:
>>>>>>> http://lists.gispython.org/pipermail/community/2009-January/001960.html
>>>>>>> Seems that I reached where a point that 'should never be
>>>>>>> reached' ?
>>>>>>> http://trac.osgeo.org/geos/browser/trunk/source/index/strtree/AbstractS
>>>>>>> TRtree.cpp#L358
>>>>>>> I am new to looking at the geos code, so any pointers to help
>>>>>>> me test
>>>>>>> more would be great.
>>>>>> Could you provide a minimal test I could use to reproduce this
>>>>>> problem?
>>>>>> Regards Hartmut
>>>>>>> Thanks!
>>>>>>> Dane
>>>>>>> On Jan 27, 2009, at 9:02 PM, Dane Springmeyer wrote:
>>>>>>>> Paul,
>>>>>>>> I tested on mac 10.5 and ubuntu 8.10 and all configure;make
>>>>>>>> and make
>>>>>>>> installs went perfectly.
>>>>>>>> Just a few compiler warnings that I've pasted here:
>>>>>>> http://dpaste.com/hold/113736/
>>>>>>>> Dane
>>>>>>>> On Jan 27, 2009, at 10:35 AM, Paul Ramsey wrote:
>>>>>>>>> This is a pre-warning to PSC members to download and test
>>>>>>>>> the first
>>>>>>>>> 3.1 rc tarball:
>>>>>>>>> http://download.osgeo.org/geos/geos-3.1.0rc1.tar.bz2
>>>>>>>>> If I don't hear any howls of dismay over the next 24 hours,
>>>>>>>>> I will
>>>>>>>>> make a wider announcement for testing.
>>>>>>>>> Paul
>>>>>>>>> _______________________________________________
>>>>>>>>> geos-devel mailing list
>>>>>>>>> geos-devel at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/geos-devel
>>> Martin Davis
>>> Senior Technical Architect
>>> Refractions Research, Inc.
>>> (250) 383-3022
> Martin Davis
> (250) 383-3022
