[geos-devel] Re: [GEOS] #275: Topology Exception on valid geometries
GEOS geos-trac at osgeo.org
Mon Jul 6 13:36:11 EDT 2009
 Reporter:  yabo        |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.1.1
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by strk):
 For the record, the test encoded as an XML testcase works fine.
 Was committed as tests/xmltester/tests/bug275.xml as of r2610.
 Martin, is that the same path you took to test JTS ?
Ticket URL: <http://trac.osgeo.org/geos/ticket/275#comment:1>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
