[geos-devel] Re: [GEOS] #275: Topology Exception on valid geometries
GEOS geos-trac at osgeo.org
Mon Jul 6 13:43:39 EDT 2009
 Reporter:  yabo        |        Owner:  geos-devel at lists.osgeo.org
     Type:  defect      |       Status:  new
 Priority:  major       |    Milestone:  3.1.1
Component:  Default     |      Version:  svn-trunk
 Severity:  Unassigned  |   Resolution:
 Keywords:              |
Comment (by strk):
 I tried the C++ version too, and I get a result there as well.
 The topology exception is cought internally, triggering snapping code:
 Overlay op threw TopologyException: found non-noded intersection between
 -3138.99 39.9929, -3195.93 131.777 and -3145.05 62.5969, -3138.99 39.9929
 -3138.99 39.9929. Will try snapping now
Ticket URL: <http://trac.osgeo.org/geos/ticket/275#comment:2>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
