[geos-devel] Benchmark between various geometry libraries
Martin Davis mbdavis at refractions.net
Wed Nov 18 12:43:21 EST 2009
Further to this, I did look at the GGL source to see if there were some
obvious algorithmic ideas that could be used in JTS/GEOS.  But I got
lost in all the template code...  8^(
I am curious to know how much of the speed improvement is due to more
efficient compilation due to templating, VS pure algorithm design.  The
latter can inform other libraries - the former, not so much.
Martin Davis wrote:
> Maxime van Noppen wrote:
>> It's quite interesting to have some numbers though, as sometimes they
>> can lead to significant performance boost (CascadedPolygonUnion is a
>> good example). It might be interesting to analyze why geos is 23x slower
>> than other geometry libraries in some cases whereas it competes with
>> them elsewhere.
> Yes, definitely it's nice to have examples of how things can be improved.
> Personally I intend to stay well away from any C++ template hacking,
> though!
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
