[geos-devel] Re: [GEOS] #397: Valgrind reported errors
GEOS geos-trac at osgeo.org
Fri Mar 4 04:45:57 EST 2011
 Reporter:  strk        |       Owner:  geos-devel@…
     Type:  defect      |      Status:  new
 Priority:  major       |   Milestone:
Component:  Default     |     Version:  svn-trunk
 Severity:  Unassigned  |    Keywords:
Comment(by strk):
 Found that the errors are NOT output, on the 64bit system, unless
 --enable-glibcxx-debug configure switch is given.
Ticket URL: <http://trac.osgeo.org/geos/ticket/397#comment:10>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
