[geos-devel] Re: [GEOS] #299: geos::geom::CoordinateArraySequenceFactory unit test failing on Bad Apple
GEOS geos-trac at osgeo.org
Mon Feb 13 11:48:06 EST 2012
 Reporter:  pramsey         |        Owner:  geos-devel@…
     Type:  defect          |       Status:  reopened
 Priority:  major           |    Milestone:  GEOS Future
Component:  Unit Tests      |      Version:  svn-trunk
 Severity:  Unassigned      |   Resolution:
 Keywords:  mac,macosx,osx  |
Comment(by 2sin18):
 Replying to [comment:32 hobu]:
 > Additionally, how did you track this down?  I spent quite a while
 chasing this and mostly chased my tail...
 > Do you have a fix for  #479 too, or did you compile this with clang?
 I used llvm/clang with the help of xCode. xCode suggested the problem is
 that some classes are incomplete types at the point where auto_ptr
 destructor is instantiated. So I checked the source code, and found one
 class missing non-trivial destructor and another class missing necessary
 includes for forward declared types.
 Sorry, my English is too poor to explain more.
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:34>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
