[geos-devel] Re: [GEOS] #299: geos::geom::CoordinateArraySequenceFactory unit test failing on Bad Apple
GEOS geos-trac at osgeo.org
Mon Feb 13 12:43:58 EST 2012
 Reporter:  pramsey         |        Owner:  geos-devel@…
     Type:  defect          |       Status:  reopened
 Priority:  major           |    Milestone:  GEOS Future
Component:  Unit Tests      |      Version:  svn-trunk
 Severity:  Unassigned      |   Resolution:
 Keywords:  mac,macosx,osx  |
Comment(by hobu):
 Can you please supply a patch?  The patch I have attached that attempts to
 do what you suggest does not seem to fix the issue.
Ticket URL: <http://trac.osgeo.org/geos/ticket/299#comment:35>
GEOS <http://geos.refractions.net/>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
