[geos-devel] [GEOS] #766: Patch for StringTokenizer.cpp to include std::numeric
GEOS geos-trac at osgeo.org
Fri Feb 5 00:03:16 PST 2016
 Reporter:  jmckenna       |       Owner:  geos-devel@…
     Type:  defect         |      Status:  closed
 Priority:  major          |   Milestone:  3.5.1
Component:  Build/Install  |     Version:  3.5.0
 Severity:  Unassigned     |  Resolution:  fixed
 Keywords:                 |
Changes (by strk):
 * status:  new => closed
 * component:  Default => Build/Install
 * resolution:   => fixed
Comment:
 Thanks Jeff, applied to 3.5 branch (for 3.5.1) with r4143 and to trunk
 (for 3.6.0) with r4142
Ticket URL: <https://trac.osgeo.org/geos/ticket/766#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
