[geos-devel] [GEOS] #783: 2 GEOS specific Memory leaks when using spatialite
GEOS geos-trac at osgeo.org
Tue Jul 5 23:42:41 PDT 2016
 Reporter:  mj10777                              |       Owner:  geos-
                                                 |  devel@…
     Type:  defect                               |      Status:  closed
 Priority:  trivial                              |   Milestone:  3.5.1
Component:  Default                              |     Version:  3.5.0
 Severity:  Unassigned                           |  Resolution:  duplicate
 Keywords:  memory leak, GEOS_init_r,            |
  GeometryFactory                                |
Changes (by strk):
 * status:  new => closed
 * resolution:   => duplicate
Comment:
 I turns out, this is a duplicate of #587
Ticket URL: <https://trac.osgeo.org/geos/ticket/783#comment:2>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
