[geos-devel] [GEOS] #784: g++ 6 isnan issues
GEOS geos-trac at osgeo.org
Wed Jul 6 03:14:43 PDT 2016
 Reporter:  rsbivand    |      Owner:  geos-devel@…
     Type:  defect      |     Status:  new
 Priority:  major       |  Milestone:  3.5.1
Component:  Default     |    Version:  3.5.0
 Severity:  Unassigned  |   Keywords:
 Further to https://lists.osgeo.org/pipermail/geos-
 devel/2016-March/007433.html, and success with the suggested patch for
 3.5.0 for some of the make, on Fedora 24, g++ 6.1.1 20160621, I see later
 on, in tests/xmltester:
 g++ -DHAVE_CONFIG_H -I. -I../../include -I../../include/geos
 -I../../include -I../../src/io/tinyxml -DTIXML_USE_STL  -DGEOS_INLINE -g
 -O2 -MT XMLTester-XMLTester.o -MD -MP -MF .deps/XMLTester-XMLTester.Tpo -c
 -o XMLTester-XMLTester.o `test -f 'XMLTester.cpp' || echo
 './'`XMLTester.cpp
 In file included from ../../include/geos/geom/Point.h:25:0,
                  from XMLTester.cpp:27:
 ../../include/geos/geom/Coordinate.inl: In member function ‘bool
 geos::geom::Coordinate::isNull() const’:
 ../../include/geos/platform.h:90:27: error: ‘isnan’ was not declared in
 this scope
  # define ISNAN(x) (isnan(x))
 ../../include/geos/geom/Coordinate.inl:38:10: note: in expansion of macro
 ‘ISNAN’
   return (ISNAN(x) && ISNAN(y) && ISNAN(z));
 ../../include/geos/platform.h:90:27: note: suggested alternative:
 ‘ISNAN’
 In file included from ../../include/geos/geom/Coordinate.inl:22:0,
                  from ../../include/geos/geom/Coordinate.h:158,
                  from ../../include/geos/geom/Envelope.h:25,
                  from ../../include/geos/geom/Geometry.h:27,
                  from ../../include/geos/geom/Point.h:26,
 /usr/include/c++/6.1.1/cmath:655:5: note:   ‘std::isnan’
      isnan(_Tp __x)
 This means that 3.5.0 cannot be built on Fedora 24 without further changes
 to configure.ac, and possibly elsewhere, to pass through the settings seen
 earlier in the make process.
Ticket URL: <https://trac.osgeo.org/geos/ticket/784>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
