[geos-devel] [GEOS] #887: Remove pre-release suffix from library name (libgeos-3.7.0alpha.so -> libgeos-3.7.0.so)
GEOS geos-trac at osgeo.org
Fri Jun 15 00:20:31 PDT 2018
libgeos-3.7.0.so)
 Reporter:  Bas Couwenberg  |       Owner:  geos-devel@…
     Type:  defect          |      Status:  closed
 Priority:  major           |   Milestone:  3.7.0
Component:  Default         |     Version:  master
 Severity:  Unassigned      |  Resolution:  fixed
 Keywords:                  |
Comment (by Regina Obe <lr@…>):
 In [changeset:"028fcc1ef07a100bea8c5ed928dee87b7250928c/git" 028fcc1/git]:
 #!CommitTicketReference repository="git"
 revision="028fcc1ef07a100bea8c5ed928dee87b7250928c"
 Revise again to strip anything following the version number.
 Revised patch from Bas Couwenberg. References #887
Ticket URL: <https://trac.osgeo.org/geos/ticket/887#comment:10>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
