[geos-devel] [GEOS] #863: DEBUG_BYTEORDER_VALUES=1 does not build
GEOS geos-trac at osgeo.org
Fri Mar 16 07:34:40 PDT 2018
 Reporter:  goatbar    |      Owner:  geos-devel@…
     Type:  defect     |     Status:  new
 Priority:  minor      |  Milestone:  3.6.3
Component:  Default    |    Version:  3.6.2
 Severity:  Annoyance  |   Keywords:  debugging
 Missing includes and missing std::
 Also, most other switches are `#ifdef` rather than `#if`, so maybe that
 should change too.
 {{{#!patch
 --- a/src/io/ByteOrderValues.cpp        2017-10-20 17:04:17.000000000
 -0700
 +++ b/src/io/ByteOrderValues.cpp        2018-03-15 22:25:50.000000000
 -0700
 @@ -23,6 +23,11 @@
  #include <cstring>
  #include <cassert>
 +#if DEBUG_BYTEORDER_VALUES
 +#include <ios>
 +#include <iostream>
 +#endif
  namespace geos {
  namespace io { // geos.io
 @@ -143,12 +148,12 @@
         int64 longValue;
      std::memcpy(&longValue, &doubleValue, sizeof(double));
 -       cout<<"ByteOrderValues::putDouble("<<doubleValue<<
 +       std::cout<<"ByteOrderValues::putDouble("<<doubleValue<<
                 ", order:"<<byteOrder
 -               <<") = "<<hex;
 +               <<") = "<<std::hex;
         for (int i=0; i<8; i++)
 -               cout<<"["<<(int)buf[i]<<"]";
 -       cout<<dec<<endl;
 +               std::cout<<"["<<(int)buf[i]<<"]";
 +       std::cout<<std::dec<<std::endl;
  #endif
         putLong(longValue, buf, byteOrder);
Ticket URL: <https://trac.osgeo.org/geos/ticket/863>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
