[geos-devel] [GEOS] #863: DEBUG_BYTEORDER_VALUES=1 does not build
GEOS geos-trac at osgeo.org
Fri Mar 16 14:47:25 PDT 2018
 Reporter:  goatbar    |       Owner:  geos-devel@…
     Type:  defect     |      Status:  new
 Priority:  minor      |   Milestone:  3.6.3
Component:  Default    |     Version:  3.6.2
 Severity:  Annoyance  |  Resolution:
 Keywords:  debugging  |
Comment (by goatbar):
 I think there is still more that can be done to improve the eof checks,
 but here is what I ended up with after code review.  I'll try to get the
 tests I've been working on out in the autotest2 tree in the next few days.
 I have more work to do for coverage.
 {{{#!c++
 namespace {
 unsigned char ASCIIHexToUChar(char val)
         switch ( val )
                 case '0' :
                         return 0;
                 case '1' :
                         return 1;
                 case '2' :
                         return 2;
                 case '3' :
                         return 3;
                 case '4' :
                         return 4;
                 case '5' :
                         return 5;
                 case '6' :
                         return 6;
                 case '7' :
                         return 7;
                 case '8' :
                         return 8;
                 case '9' :
                         return 9;
                 case 'A' :
                 case 'a' :
                         return 10;
                 case 'B' :
                 case 'b' :
                         return 11;
                 case 'C' :
                 case 'c' :
                         return 12;
                 case 'D' :
                 case 'd' :
                         return 13;
                 case 'E' :
                 case 'e' :
                         return 14;
                 case 'F' :
                 case 'f' :
                         return 15;
                 default:
                         throw ParseException("Invalid HEX char");
 }  // namespace
 // Must be an even number of characters in the istream.
 // Throws a ParseException if there are an odd number of characters.
 Geometry *
 WKBReader::readHEX(istream &is)
         // setup input/output stream
         stringstream os(ios_base::binary|ios_base::in|ios_base::out);
         while( true )
                 const int input_high = is.get();
                 if (input_high == char_traits<char>::eof())
                         break;
                 const int input_low = is.get();
                 if (input_low == char_traits<char>::eof())
                         throw ParseException("Premature end of HEX
 string");
                 const char high = static_cast<char>(input_high);
                 const char low = static_cast<char>(input_low);
                 const unsigned char result_high = ASCIIHexToUChar(high);
                 const unsigned char result_low = ASCIIHexToUChar(low);
                 const unsigned char value =
                         static_cast<char>((result_high<<4) + result_low);
 #if DEBUG_HEX_READER
         cout<<"HEX "<<high<<low<<" -> DEC "<<(int)value<<endl;
 #endif
                 // write the value to the output stream
                 os << value;
         // now call read to convert the geometry
         return this->read(os);
Ticket URL: <https://trac.osgeo.org/geos/ticket/863#comment:1>
GEOS <http://trac.osgeo.org/geos>
GEOS (Geometry Engine - Open Source) is a C++ port of the Java Topology Suite (JTS).
