[GRASS-ABM] Which language to ABM with GRASS (chris carleton)
"Peter Löwe" peter.loewe at gmx.de
Thu Feb 12 03:11:13 EST 2009
Chris:
To get started quickly you might also want to consider Clips.
http://clipsrules.sourceforge.net/
{I did some GRASS-Clips stuff some years ago - this information might be outdated: http://conference.osgeo.org/index.php/foss4g/2008/paper/viewFile/192/71}
Its a C-coded Expert System Shell Environment (-> Rete) which internally provides a Lisp-like language environment ("COOL"), which can be used to model agents interacting with GRASS-data.
For loose-level coupling with GRASS using Perl, there used to be the CAPE project (http://cape.sourceforge.net/). Unfortunately, the projects seems to be dormand for now.
There's also the option of tight coupling of Clips/GRASS, but that seems to be unexplored.
Best,
Peter
Dr. Peter Löwe
<peter.loewe at gmx.de>
Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen: http://www.gmx.net/de/go/multimessenger01
More information about the grass-abm mailing list
