[GRASS-SVN] r32647 - in grass/branches/develbranch_6/gui/wxpython: . gui_modules vdigit
Fri Aug 8 18:44:39 EDT 2008
Author: martinl
Date: 2008-08-08 18:44:39 -0400 (Fri, 08 Aug 2008)
New Revision: 32647
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
   grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
wxGUI: vdigit - settings cosmetics, don't crash when all features are disabled
overwrite checkbox removed from NewVectorDialog (there is already this option in GUI preferences)
some cosmetics in goutput module, print data/time instead thread number
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -380,12 +380,13 @@
     def __init__(self, parent, id, title, vectmap,
                  size = wx.DefaultSize, style = wx.DEFAULT_FRAME_STYLE,
-                 pointdata=None):
+                 pointdata=None, log=None):
         self.vectmap   = vectmap
         self.pointdata = pointdata
         self.parent    = parent # GMFrame
+        self.cmdLog    = log    # self.parent.goutput
         wx.Frame.__init__(self, parent, id, title, style=style)
         # icon
@@ -1721,32 +1722,16 @@
             wx.MessageBox(parent=self,
                           message=_('Nothing to extract.'),
                           caption=_('Extract selected'), style=wx.CENTRE)
-            return False
+            return
         else:
             # dialog to get file name
-            dlg = gdialogs.NewVectorDialog(parent=self, id=wx.ID_ANY, title=_('Extract selected'))
-            if dlg.ShowModal() == wx.ID_OK:
-                outmap, overwrite = dlg.GetName()
-                if outmap == '': # should not happen
-                    return False
-                cmd = ["v.extract",
-                       "input=%s" % self.vectmap,
-                       "output=%s" % outmap,
-                       "list=%s" % utils.ListOfCatsToRange(cats)]
-                if overwrite is True:
-                    cmd.append('--overwrite')
-                p = gcmd.Command(cmd, stderr=None)
+            gdialogs.CreateNewVector(parent=self, title=_('Extract selected'),
+                                     log=self.cmdLog,
+                                     cmdDef=(["v.extract",
+                                              "input=%s" % self.vectmap,
+                                              "list=%s" % utils.ListOfCatsToRange(cats)],
+                                             "output"))
-                if p.returncode == 0:
-                    return True
-        return False
     def AddQueryMapLayer(self):
         """Redraw a map
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gcmd.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -67,6 +67,11 @@
                                message=self.message,
                                style=wx.ICON_ERROR | wx.CENTRE)
         dlg.SetIcon(wx.Icon(os.path.join(globalvar.ETCDIR, 'grass_error.ico'), wx.BITMAP_TYPE_ICO))
+        if self.parent:
+            dlg.CentreOnParent()
+        else:
+            dlg.CentreOnScreen()
         dlg.ShowModal()
         return ''
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gdialogs.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -60,12 +60,7 @@
                                       type='vector', mapsets=[grassenv.GetGRASSVariable('MAPSET'),])
         self.mapName.Bind(wx.EVT_TEXT, self.OnMapName)
-        # TODO remove (see Preferences dialog)
-        self.overwrite = wx.CheckBox(parent=self.panel, id=wx.ID_ANY,
-                                     label=_("Allow output files to overwrite existing files"))
-        self.overwrite.SetValue(UserSettings.Get(group='cmd', key='overwrite', subkey='enabled'))
         self.__Layout()
         self.SetMinSize(self.GetSize())
@@ -86,9 +81,7 @@
                       flag=wx.ALL, border=1)
         dataSizer.Add(self.mapName, proportion=0,
                       flag=wx.EXPAND | wx.ALL, border=1)
-        dataSizer.Add(self.overwrite, proportion=0,
-                      flag=wx.ALL, border=1)
         # buttons
         btnSizer = wx.StdDialogButtonSizer()
         btnSizer.AddButton(self.btnCancel)
@@ -108,46 +101,64 @@
         """Return (mapName, overwrite)"""
         mapName = self.mapName.GetValue().split('@', 1)[0]
-        return (mapName,
-                self.overwrite.IsChecked())
-def CreateNewVector(parent, title=_('Create new vector map'),
-                    exceptMap=None):
+        return mapName
+def CreateNewVector(parent, cmdDef, title=_('Create new vector map'),
+                    exceptMap=None, log=None):
     """Create new vector map layer
+    @cmdList tuple/list (cmd list, output paramater)
     @return name of create vector map
     @return None of failure
+    cmd = cmdDef[0]
     dlg = NewVectorDialog(parent=parent, id=wx.ID_ANY, title=title)
+        outmap = dlg.GetName()
         if outmap == exceptMap:
             wx.MessageBox(parent=parent,
                           message=_("Unable to create vector map <%s>.") % outmap,
                           caption=_("Error"),
                           style=wx.ID_OK | wx.ICON_ERROR | wx.CENTRE)
             return False
             return False
-        cmd = ["v.edit",
-               "map=%s" % outmap,
-               "tool=create"]
+        cmd.append("%s=%s" % (cmdDef[1], outmap))
+        if not UserSettings.Get(group='cmd', key='overwrite', subkey='enabled') and \
+                outmap in grass.list_grouped('vect')[grass.gisenv()['MAPSET']]:
+            dlg = wx.MessageDialog(parent, message=_("Vector map <%s> already exists "
+                                                     "in the current mapset. "
+                                                     "Do you want to overwrite it?") % outmap,
+                                   caption=_("Overwrite?"),
+                                   style=wx.YES_NO | wx.YES_DEFAULT | wx.ICON_QUESTION)
+            if dlg.ShowModal() == wx.ID_YES:
+                cmd.append('--overwrite')
+            else:
+                dlg.Destroy()
+                return False
+        if UserSettings.Get(group='cmd', key='overwrite', subkey='enabled') is True:
         try:
+            gcmd.Command(cmd)
         except gcmd.CmdError, e:
             print >> sys.stderr, e
             return None
-            # return fully qualified map name
-            return outmap + '@' + grassenv.GetGRASSVariable('MAPSET')
+        # return fully qualified map name
+        if '@' not in outmap:
+            outmap += '@' + grassenv.GetGRASSVariable('MAPSET')
+        if log:
+            log.WriteLog(_("New vector map <%s> created") % outmap)
+        return outmap
     return None
 class SavedRegion(wx.Dialog):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -193,14 +193,14 @@
         if Debug.get_level() == 0:
             # don't redirect when debugging is enabled
-            sys.stdout = self.cmd_stdout
-            sys.stderr = self.cmd_stderr
+            #sys.stdout = self.cmd_stdout
+            #sys.stderr = self.cmd_stderr
             return True
         return False
-    def WriteLog(self, line, style=None, wrap=None):
+    def WriteLog(self, text, style=None, wrap=None):
         """Generic method for writing log message in
         given style
@@ -210,21 +210,24 @@
         if not style:
             style = self.cmd_output.StyleDefault
-        self.cmd_output.GotoPos(self.cmd_output.GetLength())
-        p1 = self.cmd_output.GetCurrentPos()
-        # fill space
-        if len(line) < self.lineWidth:
-            diff = 80 - len(line)
+        # p1 = self.cmd_output.GetCurrentPos()
+        p1 = self.cmd_output.GetEndStyled()
+        self.cmd_output.GotoPos(p1)
+        for line in text.split('\n'):
+            # fill space
+            if len(line) < self.lineWidth:
+                diff = 80 - len(line)
             line += diff * ' '
-        self.cmd_output.AddTextWrapped(line, wrap=wrap) # adds os.linesep
-        p2 = self.cmd_output.GetCurrentPos()
-        self.cmd_output.StartStyling(p1, 0xff)
-        self.cmd_output.SetStyling(p2 - p1, style)
+            self.cmd_output.AddTextWrapped(line, wrap=wrap) # adds os.linesep
+            p2 = self.cmd_output.GetCurrentPos()
+            self.cmd_output.StartStyling(p1, 0xff)
+            self.cmd_output.SetStyling(p2 - p1, style)
         self.cmd_output.EnsureCaretVisible()
     def WriteCmdLog(self, line, pid=None):
@@ -372,14 +375,16 @@
         # switch to 'Command output'
         if self.parent.notebook.GetSelection() != self.parent.goutput.pageid:
             self.parent.notebook.SetSelection(self.parent.goutput.pageid)
         # message prefix
         if type == 'warning':
             messege = 'WARNING: ' + message
         elif type == 'error':
             message = 'ERROR: ' + message
         self.linePos = self.cmd_output.GetCurrentPos()
         pc = -1
@@ -409,16 +414,17 @@
                 self.cmd_output.AddTextWrapped(message, wrap=None)
         if type == 'error':
-            self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleError)
+            self.cmd_output.SetStyling(p2 - p1, self.cmd_output.StyleError)
         elif type == 'warning':
-            self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleWarning)
+            self.cmd_output.SetStyling(p2 - p1, self.cmd_output.StyleWarning)
         elif type == 'message':
-            self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleMessage)
+            self.cmd_output.SetStyling(p2 - p1, self.cmd_output.StyleMessage)
         else: # unknown
-            self.cmd_output.SetStyling(p2 - p1 + 1, self.cmd_output.StyleUnknown)
+            self.cmd_output.SetStyling(p2 - p1, self.cmd_output.StyleUnknown)
         if pc > 0:
             self.cmd_output.SetCurrentPos(pc)
@@ -435,7 +441,7 @@
     def OnCmdRun(self, event):
         """Run command"""
-        self.WriteCmdLog('%s' % ' '.join(event.cmd), pid=event.pid)
+        self.WriteCmdLog('(%s)\n%s' % (str(time.ctime()), ' '.join(event.cmd)))
     def OnCmdDone(self, event):
         """Command done (or aborted)"""
@@ -443,13 +449,16 @@
             # Thread aborted (using our convention of None return)
             self.WriteLog(_('Please note that the data are left in incosistent stage '
                             'and can be corrupted'), self.cmd_output.StyleWarning)
-            self.WriteCmdLog(_('Command aborted'),
-                             pid=self.cmdThread.requestId)
+            self.WriteCmdLog('(%s) %s' % (str(time.ctime()),
+                                          _('Command aborted')))
+            # pid=self.cmdThread.requestId)
         else:
             try:
                 # Process results here
-                self.WriteCmdLog(_('Command finished (%d sec)') % (time.time() - event.time),
-                                 pid=event.pid)
+                self.WriteCmdLog('(%s) %s (%d sec)' % (str(time.ctime()),
+                                                       _('Command finished'),
+                                                       (time.time() - event.time)))
+                # pid=event.pid)
             except KeyError:
                 # stopped deamon
                 pass
@@ -704,6 +713,3 @@
         else:
             self.parent.linePos = self.GetCurrentPos()
             self.AddText(txt)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -626,7 +626,7 @@
         # if len(self.Map.GetListOfLayers()) == 0:
         #    return False
         if self.img is None:
             render = True
@@ -689,8 +689,12 @@
             # draw map
             self.pdcVector.Clear()
             self.pdcVector.RemoveAll()
-            item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
-            if self.tree.IsItemChecked(item):
+            try:
+                item = self.tree.FindItemByData('maplayer', digitToolbar.GetLayer())
+            except TypeError:
+                item = None
+            if item and self.tree.IsItemChecked(item):
                 self.parent.digit.driver.DrawMap()
@@ -1156,7 +1160,9 @@
                 self.moveIds   = []
                 if digitToolbar.action in ["moveVertex", "editLine"]:
                     # set pen
-                    self.pen = self.polypen = wx.Pen(colour=UserSettings.Get(group='vdigit', key="symbolHighlight", subkey='color'),
+                    pcolor = UserSettings.Get(group='vdigit', key="symbol",
+                                              subkey=["highlight", "color"])
+                    self.pen = self.polypen = wx.Pen(colour=pcolor,
                                                      width=2, style=wx.SHORT_DASH)
                     self.pdcTmp.SetPen(self.polypen)
@@ -1549,7 +1555,8 @@
                     # copy features from background map
                     self.copyIds = digitClass.SelectLinesFromBackgroundMap(pos1, pos2)
                     if len(self.copyIds) > 0:
-                        color = UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')
+                        color = UserSettings.Get(group='vdigit', key='symbol',
+                                                 subkey=['highlight', 'color'])
                         colorStr = str(color[0]) + ":" + \
                             str(color[1]) + ":" + \
                             str(color[2]) + ":"
@@ -2573,7 +2580,9 @@
                               CloseButton(False).Layer(2))
         # vector digitizer
         elif name == "vdigit":
-            self.toolbars['vdigit'] = toolbars.VDigitToolbar(self, self.Map, self.tree)
+            self.toolbars['vdigit'] = toolbars.VDigitToolbar(parent=self, map=self.Map,
+                                                             layerTree=self.tree,
+                                                             log=self.gismanager.goutput)
             for toolRow in range(0, self.toolbars['vdigit'].numOfRows):
                 self._mgr.AddPane(self.toolbars['vdigit'].toolbar[toolRow],
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -142,9 +142,31 @@
                 'verbosity' : {
                     'selection' : 'grassenv'
+                # d.rast
                 'rasterOverlay' : {
                     'enabled' : False
+                # d.vect
+                'showType': {
+                    'point' : {
+                        'enabled' : True
+                    'line' : {
+                        'enabled' : True
+                    'centroid' : {
+                        'enabled' : True
+                    'boundary' : {
+                        'enabled' : True
+                    'area' : {
+                        'enabled' : True
+                    'face' : {
+                        'enabled' : True
                 'addNewLayer' : {
                     'enabled' : False
@@ -165,66 +187,68 @@
             'vdigit' : {
                 # symbology
-                'symbolHighlight' : {
-                    'enabled' : None,
-                    'color' : (255, 255, 0, 255)
-                    }, # yellow
-                'symbolHighlightDupl' : {
-                    'enabled' : None,
-                    'color' : (255, 72, 0, 255)
-                    }, # red
-                'symbolPoint' : {
-                    'enabled' : True,
-                    'color' : (0, 0, 0, 255)
-                    }, # black
-                'symbolLine' : {
-                    'enabled' : True,
-                    }, # black
-                'symbolBoundaryNo' : {
-                    'enabled' : True,
-                    'color' : (126, 126, 126, 255)
-                    }, # grey
-                'symbolBoundaryOne' : {
-                    'enabled' : True,
-                    'color' : (0, 255, 0, 255)
-                    }, # green
-                'symbolBoundaryTwo' : {
-                    'enabled' : True,
-                    'color' : (255, 135, 0, 255)
-                    }, # orange
-                'symbolCentroidIn' : {
-                    'enabled' : True,
-                    'color' : (0, 0, 255, 255)
-                    }, # blue
-                'symbolCentroidOut' : {
-                    'enabled' : True,
-                    'color' : (165, 42, 42, 255)
-                    }, # brown
-                'symbolCentroidDup' : {
-                    'enabled' : True,
-                    'color' : (156, 62, 206, 255)
-                    }, # violet
-                'symbolNodeOne' : {
-                    'enabled' : True,
-                    'color' : (255, 0, 0, 255)
-                    }, # red
-                'symbolNodeTwo' : {
-                    'enabled' : True,
-                    'color' : (0, 86, 45, 255)
-                    }, # dark green
-                'symbolVertex' : {
-                    'enabled' : False,
-                    'color' : (255, 20, 147, 255)
-                    }, # deep pink
-                'symbolArea' : {
-                    'color' : (217, 255, 217, 255)
-                    }, # green
-                'symbolDirection' : {
-                    }, # red
+                'symbol' : {
+                    'highlight' : {
+                        'enabled' : None,
+                        'color' : (255, 255, 0, 255)
+                        }, # yellow
+                    'highlightDupl' : {
+                        'enabled' : None,
+                        'color' : (255, 72, 0, 255)
+                        }, # red
+                    'point' : {
+                        'enabled' : True,
+                        'color' : (0, 0, 0, 255)
+                        }, # black
+                    'line' : {
+                        'enabled' : True,
+                        }, # black
+                    'boundaryNo' : {
+                        'enabled' : True,
+                        'color' : (126, 126, 126, 255)
+                        }, # grey
+                    'boundaryOne' : {
+                        'enabled' : True,
+                        'color' : (0, 255, 0, 255)
+                        }, # green
+                    'boundaryTwo' : {
+                        'enabled' : True,
+                        'color' : (255, 135, 0, 255)
+                        }, # orange
+                    'centroidIn' : {
+                        'enabled' : True,
+                        'color' : (0, 0, 255, 255)
+                        }, # blue
+                    'centroidOut' : {
+                        'enabled' : True,
+                        'color' : (165, 42, 42, 255)
+                        }, # brown
+                    'centroidDup' : {
+                        'enabled' : True,
+                        'color' : (156, 62, 206, 255)
+                        }, # violet
+                    'nodeOne' : {
+                        'enabled' : True,
+                        'color' : (255, 0, 0, 255)
+                        }, # red
+                    'nodeTwo' : {
+                        'enabled' : True,
+                        'color' : (0, 86, 45, 255)
+                        }, # dark green
+                    'vertex' : {
+                        'enabled' : False,
+                        'color' : (255, 20, 147, 255)
+                        }, # deep pink
+                    'area' : {
+                        'color' : (217, 255, 217, 255)
+                        }, # green
+                    'direction' : {
+                        }, # red
                 # display
                 'lineWidth' : {
                     'value' : 2,
@@ -272,18 +296,20 @@
                     'thresh' : 0
                 # select feature (point, line, centroid, boundary)
-                'selectFeaturePoint' : {
-                    'enabled' : True
+                'selectType': {
+                    'point' : {
+                        'enabled' : True
+                    'line' : {
+                        'enabled' : True
+                    'centroid' : {
+                        'enabled' : True
+                    'boundary' : {
+                        'enabled' : True
-                'selectFeatureLine' : {
-                    'enabled' : True
-                'selectFeatureCentroid' : {
-                    'enabled' : True
-                'selectFeatureBoundary' : {
-                    'enabled' : True
                 'selectThresh' : {
                     'value' : 10,
                     'units' : 'screen pixels'
@@ -613,7 +639,7 @@
        'detail' : e })
         file.close()
         return filePath
     def __parseValue(self, value, read=False):
@@ -676,8 +702,10 @@
                     return settings[group][key][subkey]
         except KeyError:
-            raise gcmd.SettingsError("%s %s:%s:%s." % (_("Unable to get value"),
-                                                       group, key, subkey))
+            #raise gcmd.SettingsError("%s %s:%s:%s." % (_("Unable to get value"),
+            #                                           group, key, subkey))
+            print >> sys.stderr, "Settings: unable to get value '%s:%s:%s'\n" % \
+                (group, key, subkey)
     def Set(self, group, value, key=None, subkey=None, internal=False):
         """Set value of key/subkey
@@ -1013,14 +1041,14 @@
         """Create notebook page for commad dialog settings"""
         panel = wx.Panel(parent=notebook, id=wx.ID_ANY)
         notebook.AddPage(page=panel, text=_("Command"))
         border = wx.BoxSizer(wx.VERTICAL)
         box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Command dialog settings"))
         sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
         gridSizer = wx.GridBagSizer (hgap=3, vgap=3)
         gridSizer.AddGrowableCol(0)
         # command dialog settings
@@ -1031,7 +1059,7 @@
                                 name="IsChecked")
         overwrite.SetValue(self.settings.Get(group='cmd', key='overwrite', subkey='enabled'))
         self.winId['cmd:overwrite:enabled'] = overwrite.GetId()
         gridSizer.Add(item=overwrite,
                       pos=(row, 0), span=(1, 2))
         row += 1
@@ -1041,7 +1069,7 @@
                             name="IsChecked")
         close.SetValue(self.settings.Get(group='cmd', key='closeDlg', subkey='enabled'))
         self.winId['cmd:closeDlg:enabled'] = close.GetId()
         gridSizer.Add(item=close,
         row += 1
@@ -1051,7 +1079,7 @@
                           name="IsChecked")
         add.SetValue(self.settings.Get(group='cmd', key='addNewLayer', subkey='enabled'))
         self.winId['cmd:addNewLayer:enabled'] = add.GetId()
         gridSizer.Add(item=add,
         row += 1
@@ -1066,22 +1094,22 @@
                               name="GetStringSelection")
         verbosity.SetStringSelection(self.settings.Get(group='cmd', key='verbosity', subkey='selection'))
         self.winId['cmd:verbosity:selection'] = verbosity.GetId()
         gridSizer.Add(item=verbosity,
                       pos=(row, 1))
         sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
         border.Add(item=sizer, proportion=0, flag=wx.ALL | wx.EXPAND, border=3)
         # raster settings
         box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Raster settings"))
         # raster overlay
@@ -1091,13 +1119,33 @@
                                     name='IsChecked')
         rasterOverlay.SetValue(self.settings.Get(group='cmd', key='rasterOverlay', subkey='enabled'))
         self.winId['cmd:rasterOverlay:enabled'] = rasterOverlay.GetId()
         gridSizer.Add(item=rasterOverlay,
         border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
+        # vector settings
+        box   = wx.StaticBox (parent=panel, id=wx.ID_ANY, label=" %s " % _("Vector settings"))
+        sizer = wx.StaticBoxSizer(box, wx.VERTICAL)
+        gridSizer = wx.FlexGridSizer (cols=6, hgap=3, vgap=3)
+        for type in ('point', 'line', 'centroid', 'boundary',
+                        'area', 'face'):
+            chkbox = wx.CheckBox(parent=panel, label=type)
+            checked = self.settings.Get(group='cmd', key='showType',
+                                        subkey=[type, 'enabled'])
+            chkbox.SetValue(checked)
+            self.winId['cmd:showType:%s:enabled' % type] = chkbox.GetId()
+            gridSizer.Add(item=chkbox)
+        sizer.Add(item=gridSizer, proportion=1, flag=wx.ALL | wx.EXPAND, border=5)
+        border.Add(item=sizer, proportion=0, flag=wx.LEFT | wx.RIGHT | wx.BOTTOM | wx.EXPAND, border=3)
         panel.SetSizer(border)
         return panel
@@ -1407,7 +1455,12 @@
     def __UpdateSettings(self):
         """Update user settings"""
         for item in self.winId.keys():
-            group, key, subkey = item.split(':')
+            try:
+                group, key, subkey = item.split(':')
+                subkey1 = None
+            except ValueError:
+                group, key, subkey, subkey1 = item.split(':')
             id = self.winId[item]
             win = self.FindWindowById(id)
             if win.GetName() == 'GetValue':
@@ -1422,9 +1475,12 @@
                 value = tuple(win.GetValue())
             else:
                 value = win.GetValue()
-            self.settings.Set(group, value, key, subkey)
+            if subkey1:
+                self.settings.Set(group, value, key, [subkey, subkey1])
+            else:
+                self.settings.Set(group, value, key, subkey)
         # update default window dimension
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -353,11 +353,12 @@
     Toolbar for digitization
-    def __init__(self, parent, map, layerTree=None):
+    def __init__(self, parent, map, layerTree=None, log=None):
         self.mapcontent    = map       # Map class instance
         self.parent        = parent    # MapFrame
         self.layerTree     = layerTree # reference to layer tree associated to map display
+        self.log           = log       # log area
         # currently selected map layer for editing (reference to MapLayer instance)
         self.mapLayer = None
         # list of vector layers from Layer Manager (only in the current mapset)
@@ -769,7 +770,8 @@
             else:
                 openVectorMap = None
             mapName = gdialogs.CreateNewVector(self.parent,
-                                               exceptMap=openVectorMap)
+                                               exceptMap=openVectorMap, log=self.log,
+                                               cmdDef=(['v.edit', 'tool=create'], "map"))
             if mapName:
                 # add layer to map layer tree
                 if self.layerTree:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -191,11 +191,12 @@
         Used by SelectLinesByBox() and SelectLinesByPoint()"""
         type = 0
-        for feature in (('Point', wxvdigit.GV_POINT),
-                        ('Line', wxvdigit.GV_LINE),
-                        ('Centroid', wxvdigit.GV_CENTROID),
-                        ('Boundary', wxvdigit.GV_BOUNDARY)):
-            if UserSettings.Get(group='vdigit', key='selectFeature'+feature[0], subkey='enabled') is True:
+        for feature in (('point', wxvdigit.GV_POINT),
+                        ('line', wxvdigit.GV_LINE),
+                        ('centroid', wxvdigit.GV_CENTROID),
+                        ('boundary', wxvdigit.GV_BOUNDARY)):
+            if UserSettings.Get(group='vdigit', key='selectType',
+                                subkey=[feature[0], 'enabled']) is True:
                 type |= feature[1]
         return type
@@ -1521,81 +1522,75 @@
         if not self.__display:
             return
-        self.__display.UpdateSettings (wx.Color(UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolHighlight', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='checkForDupl', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolHighlightDupl', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolHighlightDupl', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolHighlightDupl', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolPoint', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolPoint', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolLine', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolLine', subkey='color')[2],
-                                           255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryNo', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryOne', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolBoundaryTwo', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidIn', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidOut', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolCentroidDup', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeOne', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolNodeTwo', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolVertex', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolVertex', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolArea', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolArea', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolArea', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolArea', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='symbolDirection', subkey='enabled'),
-                                       wx.Color(UserSettings.Get(group='vdigit', key='symbolDirection', subkey='color')[0],
-                                                UserSettings.Get(group='vdigit', key='symbolDirection', subkey='color')[1],
-                                                UserSettings.Get(group='vdigit', key='symbolDirection', subkey='color')[2],
-                                                255).GetRGB(),
-                                       UserSettings.Get(group='vdigit', key='lineWidth', subkey='value'))
+        color = {}
+        for symbol in ("highlight",
+                       "highlightDupl",
+                       "point",
+                       "line",
+                       "boundaryNo",
+                       "boundaryOne",
+                       "boundaryTwo",
+                       "centroidIn",
+                       "centroidOut",
+                       "centroidDup",
+                       "nodeOne",
+                       "nodeTwo",
+                       "vertex",
+                       "area",
+                       "direction"):
+            color[symbol] = wx.Color(UserSettings.Get(group='vdigit', key='symbol',
+                                                      subkey=[symbol, 'color'])[0],
+                                     UserSettings.Get(group='vdigit', key='symbol',
+                                                      subkey=[symbol, 'color'])[1],
+                                                      subkey=[symbol, 'color'])[2],
+                                     255).GetRGB()
+        self.__display.UpdateSettings (color['highlight'],
+                                       UserSettings.Get(group='vdigit', key='checkForDupl',
+                                                        subkey='enabled'),
+                                       color['highlightDupl'],
+                                                        subkey=['point', 'enabled']),
+                                       color['point'],
+                                                        subkey=['line', 'enabled']),
+                                       color['line'],
+                                                        subkey=['boundaryNo', 'enabled']),
+                                       color['boundaryNo'],
+                                                        subkey=['boundaryOne', 'enabled']),
+                                       color['boundaryOne'],
+                                                        subkey=['boundaryTwo', 'enabled']),
+                                       color['boundaryTwo'],
+                                                        subkey=['centroidIn', 'enabled']),
+                                       color['centroidIn'],
+                                                        subkey=['centroidOut', 'enabled']),
+                                       color['centroidOut'],
+                                                        subkey=['centroidDup', 'enabled']),
+                                       color['centroidDup'],
+                                                        subkey=['nodeOne', 'enabled']),
+                                       color['nodeOne'],
+                                                        subkey=['nodeTwo', 'enabled']),
+                                       color['nodeTwo'],
+                                                        subkey=['vertex', 'enabled']),
+                                       color['vertex'],
+                                                        subkey=['area', 'enabled']),
+                                       color['area'],
+                                                        subkey=['direction', 'enabled']),
+                                       color['direction'],
+                                       UserSettings.Get(group='vdigit', key='lineWidth',
+                                                        subkey='value'))
 class VDigitSettingsDialog(wx.Dialog):
@@ -1661,8 +1656,10 @@
         for label, key in self.__SymbologyData():
             textLabel = wx.StaticText(panel, wx.ID_ANY, label)
             color = csel.ColourSelect(panel, id=wx.ID_ANY,
-                                      colour=UserSettings.Get(group='vdigit', key=key, subkey='color'), size=(25, 25))
-            isEnabled = UserSettings.Get(group='vdigit', key=key, subkey='enabled')
+                                      colour=UserSettings.Get(group='vdigit', key='symbol',
+                                                              subkey=[key, 'color']), size=(25, 25))
+            isEnabled = UserSettings.Get(group='vdigit', key='symbol',
+                                         subkey=[key, 'enabled'])
             if isEnabled is not None:
                 enabled = wx.CheckBox(panel, id=wx.ID_ANY, label="")
                 enabled.SetValue(isEnabled)
@@ -1782,11 +1779,12 @@
         inSizer = wx.BoxSizer(wx.HORIZONTAL)
         self.selectFeature = {}
-        for feature in ('Point', 'Line',
-                        'Centroid', 'Boundary'):
+        for feature in ('point', 'line',
+                        'centroid', 'boundary'):
             chkbox = wx.CheckBox(parent=panel, label=feature)
             self.selectFeature[feature] = chkbox.GetId()
-            chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectFeature'+feature, subkey='enabled'))
+            chkbox.SetValue(UserSettings.Get(group='vdigit', key='selectType',
+                                             subkey=[feature, 'enabled']))
             inSizer.Add(item=chkbox, proportion=0,
                         flag=wx.EXPAND | wx.ALL, border=5)
         sizer.Add(item=inSizer, proportion=0, flag=wx.EXPAND)
@@ -2025,21 +2023,21 @@
         return (
             #            ("Background", "symbolBackground"),
-            (_("Highlight"), "symbolHighlight"),
-            (_("Highlight (duplicates)"), "symbolHighlightDupl"),
-            (_("Point"), "symbolPoint"),
-            (_("Line"), "symbolLine"),
-            (_("Boundary (no area)"), "symbolBoundaryNo"),
-            (_("Boundary (one area)"), "symbolBoundaryOne"),
-            (_("Boundary (two areas)"), "symbolBoundaryTwo"),
-            (_("Centroid (in area)"), "symbolCentroidIn"),
-            (_("Centroid (outside area)"), "symbolCentroidOut"),
-            (_("Centroid (duplicate in area)"), "symbolCentroidDup"),
-            (_("Node (one line)"), "symbolNodeOne"),
-            (_("Node (two lines)"), "symbolNodeTwo"),
-            (_("Vertex"), "symbolVertex"),
-            (_("Area (closed boundary + centroid)"), "symbolArea"),
-            (_("Direction"), "symbolDirection"),)
+            (_("Highlight"), "highlight"),
+            (_("Highlight (duplicates)"), "highlightDupl"),
+            (_("Point"), "point"),
+            (_("Line"), "line"),
+            (_("Boundary (no area)"), "boundaryNo"),
+            (_("Boundary (one area)"), "boundaryOne"),
+            (_("Boundary (two areas)"), "boundaryTwo"),
+            (_("Centroid (in area)"), "centroidIn"),
+            (_("Centroid (outside area)"), "centroidOut"),
+            (_("Centroid (duplicate in area)"), "centroidDup"),
+            (_("Node (one line)"), "nodeOne"),
+            (_("Node (two lines)"), "nodeTwo"),
+            (_("Vertex"), "vertex"),
+            (_("Area (closed boundary + centroid)"), "area"),
+            (_("Direction"), "direction"),)
     def OnChangeCategoryMode(self, event):
         """Change category mode"""
@@ -2132,11 +2130,14 @@
         fileSettings = {}
         UserSettings.ReadSettingsFile(settings=fileSettings)
         fileSettings['vdigit'] = UserSettings.Get(group='vdigit')
         file = UserSettings.SaveToFile(fileSettings)
         self.parent.gismanager.goutput.WriteLog(_('Vector digitizer settings saved to file <%s>.') % file)
+        self.Destroy()
-        self.Close()
+        event.Skip()
     def OnApply(self, event):
         """Button 'Apply' clicked"""
         self.UpdateSettings()
@@ -2144,7 +2145,7 @@
     def OnCancel(self, event):
         """Button 'Cancel' clicked"""
         self.parent.toolbars['vdigit'].settingsDialog = None
-        self.Close()
+        self.Destroy()
         if event:
             event.Skip()
@@ -2155,12 +2156,15 @@
         # symbology
         for key, (enabled, color) in self.symbology.iteritems():
             if enabled:
-                UserSettings.Set(group='vdigit', key=key, subkey='enabled',
+                UserSettings.Set(group='vdigit', key='symbol',
+                                 subkey=[key, 'enabled'],
                                  value=enabled.IsChecked())
-                UserSettings.Set(group='vdigit', key=key, subkey='color',
+                                 subkey=[key, 'color'],
                                  value=tuple(color.GetColour()))
             else:
         # display
         UserSettings.Set(group='vdigit', key="lineWidth", subkey='value',
@@ -2210,10 +2214,11 @@
                          value=int(self.queryDangleValue.GetValue()))
         # select features
-            UserSettings.Set(group='vdigit', key='selectFeature'+feature, subkey='enabled',
-                                           value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
+            UserSettings.Set(group='vdigit', key='selectType',
+                             subkey=[feature, 'enabled'],
+                             value=self.FindWindowById(self.selectFeature[feature]).IsChecked())
         UserSettings.Set(group='vdigit', key="selectThresh", subkey='value',
                          value=int(self.selectThreshValue.GetValue()))
         UserSettings.Set(group='vdigit', key="checkForDupl", subkey='enabled',
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxgui_utils.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -742,8 +742,15 @@
             menuform.GUI().ParseCommand(['d.rast.num'], completed=(self.GetOptData,layer,params),
                                         parentframe=self)
         elif ltype == 'vector':
-            menuform.GUI().ParseCommand(['d.vect'], completed=(self.GetOptData,layer,params),
-                                        parentframe=self)
+            types = ''
+            for type in UserSettings.Get(group='cmd', key='showType').keys():
+                if UserSettings.Get(group='cmd', key='showType', subkey=[type, 'enabled']):
+                    types += type + ','
+            types = types.rstrip(',')
+            menuform.GUI().ParseCommand(['d.vect', 'type=%s' % types],
+                                         completed=(self.GetOptData,layer,params),
+                                         parentframe=self)
         elif ltype == 'thememap':
             # -s flag requested, otherwise only first thematic category is displayed
             # should be fixed by C-based d.thematic.* modules
Modified: grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp
--- grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/vdigit/driver.cpp	2008-08-08 22:44:39 UTC (rev 32647)
@@ -377,9 +377,9 @@
     dc->SetId(dcId); /* 0 | 1 (selected) */
-    dc->SetPen(*pen);
     if (draw) {
+	dc->SetPen(*pen);
 	if (type & GV_POINTS) {
 	    DrawCross(line, (const wxPoint *) pointsScreen->GetFirst()->GetData());
@@ -821,13 +821,13 @@
 				   int lineWidth)
     settings.highlight.Set(highlight);
     settings.highlightDupl.enabled = ehighlightDupl;
     settings.highlightDupl.color.Set(chighlightDupl);
     settings.point.enabled = ePoint;
     settings.point.color.Set(cPoint);
     settings.line.enabled = eLine;
     settings.line.color.Set(cLine);
@@ -865,7 +865,7 @@
     settings.direction.color.Set(cDirection);
     settings.lineWidth = lineWidth;
     return;
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2008-08-08 14:25:18 UTC (rev 32646)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2008-08-08 22:44:39 UTC (rev 32647)
@@ -456,9 +456,8 @@
     def OnNewVector(self, event):
         """Create new vector map layer"""
-        name = gdialogs.CreateNewVector(self)
-        if name:
-            self.goutput.WriteCmdLog('New vector map <%s> created' % name)
+        name = gdialogs.CreateNewVector(self, log=self.goutput,
     def OnAboutGRASS(self, event):
         """Display 'About GRASS' dialog"""
@@ -1101,7 +1100,7 @@
                                               title="%s - <%s>" % (_("GRASS GIS Attribute Table Manager"),
        mapname),
                                               size=wx.Size(500,300), vectmap=mapname,
-                                              pointdata=pointdata)
+                                              pointdata=pointdata, log=self.goutput)
         busy.Destroy()
