[GRASS-SVN] r32648 - in grass/trunk/lib: cairodriver driver htmldriver pngdriver psdriver raster
Fri Aug 8 19:02:24 EDT 2008
Author: glynn
Date: 2008-08-08 19:02:24 -0400 (Fri, 08 Aug 2008)
New Revision: 32648
Added:
   grass/trunk/lib/htmldriver/Polygon.c
Removed:
   grass/trunk/lib/cairodriver/Client.c
   grass/trunk/lib/driver/Client.c
   grass/trunk/lib/htmldriver/Polygn_abs.c
   grass/trunk/lib/pngdriver/Client.c
   grass/trunk/lib/psdriver/Client.c
   grass/trunk/lib/cairodriver/Box.c
   grass/trunk/lib/cairodriver/Driver.c
   grass/trunk/lib/cairodriver/Poly.c
   grass/trunk/lib/cairodriver/cairodriver.h
   grass/trunk/lib/driver/Box.c
   grass/trunk/lib/driver/Polydots.c
   grass/trunk/lib/driver/Polygon.c
   grass/trunk/lib/driver/Polyline.c
   grass/trunk/lib/driver/driver.h
   grass/trunk/lib/htmldriver/Driver.c
   grass/trunk/lib/htmldriver/htmlmap.h
   grass/trunk/lib/pngdriver/Box.c
   grass/trunk/lib/pngdriver/Driver.c
   grass/trunk/lib/pngdriver/Makefile
   grass/trunk/lib/pngdriver/pngdriver.h
   grass/trunk/lib/psdriver/Box.c
   grass/trunk/lib/psdriver/Driver.c
   grass/trunk/lib/psdriver/Polygon.c
   grass/trunk/lib/psdriver/Polyline.c
   grass/trunk/lib/psdriver/psdriver.h
   grass/trunk/lib/raster/raster.c
Remove Client_{Open,Close} methods
Remove *_rel methods, remove _abs suffix from *_abs methods
Modified: grass/trunk/lib/cairodriver/Box.c
--- grass/trunk/lib/cairodriver/Box.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/cairodriver/Box.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -2,7 +2,7 @@
 /* Box_abs: Draw a (filled) rectangle */
-void Cairo_Box_abs(int x1, int y1, int x2, int y2)
+void Cairo_Box(int x1, int y1, int x2, int y2)
     G_debug(3, "Cairo_Box_abs %d %d %d %d\n", x1, y1, x2, y2);
Deleted: grass/trunk/lib/cairodriver/Client.c
--- grass/trunk/lib/cairodriver/Client.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/cairodriver/Client.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,8 +0,0 @@
-#include "cairodriver.h"
-void Cairo_Client_Close(void)
-    G_debug(1, "Cairo_Client_Close");
-    if (auto_write)
-	write_image();
Modified: grass/trunk/lib/cairodriver/Driver.c
--- grass/trunk/lib/cairodriver/Driver.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/cairodriver/Driver.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -27,20 +27,14 @@
     if (initialized)
 	return &drv;
-    drv.Box_abs = Cairo_Box_abs;
-    drv.Box_rel = NULL;
-    drv.Client_Open = NULL;
-    drv.Client_Close = Cairo_Client_Close;
+    drv.Box = Cairo_Box;
     drv.Erase = Cairo_Erase;
     drv.Graph_set = Cairo_Graph_set;
     drv.Graph_close = Cairo_Graph_close;
     drv.Line_width = Cairo_Line_width;
-    drv.Polydots_abs = NULL;
-    drv.Polydots_rel = NULL;
-    drv.Polyline_abs = Cairo_Polyline_abs;
-    drv.Polyline_rel = NULL;
-    drv.Polygon_abs = Cairo_Polygon_abs;
-    drv.Polygon_rel = NULL;
+    drv.Polydots = NULL;
+    drv.Polyline = Cairo_Polyline;
+    drv.Polygon = Cairo_Polygon;
     drv.Set_window = Cairo_Set_window;
     drv.Begin_scaled_raster = Cairo_begin_scaled_raster;
     drv.Scaled_raster = Cairo_scaled_raster;
Modified: grass/trunk/lib/cairodriver/Poly.c
--- grass/trunk/lib/cairodriver/Poly.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/cairodriver/Poly.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -9,16 +9,16 @@
 	cairo_line_to(cairo, xarray[i], yarray[i]);
-void Cairo_Polygon_abs(const int *xarray, const int *yarray, int count)
+void Cairo_Polygon(const int *xarray, const int *yarray, int count)
-    G_debug(3, "Cairo_Polygon_abs (%d points)", count);
+    G_debug(3, "Cairo_Polygon (%d points)", count);
     do_polygon(xarray, yarray, count);
     cairo_fill(cairo);
-void Cairo_Polyline_abs(const int *xarray, const int *yarray, int count)
+void Cairo_Polyline(const int *xarray, const int *yarray, int count)
-    G_debug(3, "Cairo_Polyline_abs (%d points)", count);
+    G_debug(3, "Cairo_Polyline (%d points)", count);
     cairo_stroke(cairo);
Modified: grass/trunk/lib/cairodriver/cairodriver.h
--- grass/trunk/lib/cairodriver/cairodriver.h	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/cairodriver/cairodriver.h	2008-08-08 23:02:24 UTC (rev 32648)
@@ -49,7 +49,7 @@
 extern void Cairo_Client_Close(void);
 extern int Cairo_Graph_set(int, char **);
 extern void Cairo_Graph_close(void);
-extern void Cairo_Box_abs(int, int, int, int);
+extern void Cairo_Box(int, int, int, int);
 extern void Cairo_Set_window(int, int, int, int);
 extern void Cairo_draw_line(int, int, int, int);
 extern void Cairo_draw_bitmap(int, int, int, const unsigned char *);
@@ -63,8 +63,8 @@
 			       const unsigned char *, const unsigned char *);
 extern void Cairo_end_scaled_raster(void);
 extern void Cairo_Line_width(int);
-extern void Cairo_Polygon_abs(const int *, const int *, int);
-extern void Cairo_Polyline_abs(const int *, const int *, int);
+extern void Cairo_Polygon(const int *, const int *, int);
+extern void Cairo_Polyline(const int *, const int *, int);
 extern void Cairo_Respond(void);
 /* read.c */
Modified: grass/trunk/lib/driver/Box.c
--- grass/trunk/lib/driver/Box.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/driver/Box.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -5,8 +5,8 @@
     int x[4], y[4];
-    if (driver->Box_abs) {
-	(*driver->Box_abs) (x1, y1, x2, y2);
+    if (driver->Box) {
+	(*driver->Box) (x1, y1, x2, y2);
 	return;
@@ -24,10 +24,5 @@
 void COM_Box_rel(int x, int y)
-    if (driver->Box_rel) {
-	(*driver->Box_rel) (x, y);
-	return;
     COM_Box_abs(cur_x, cur_y, cur_x + x, cur_y + y);
Deleted: grass/trunk/lib/driver/Client.c
--- grass/trunk/lib/driver/Client.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/driver/Client.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,14 +0,0 @@
-#include "driver.h"
-#include "driverlib.h"
-void COM_Client_Open(void)
-    if (driver->Client_Open)
-	(*driver->Client_Open) ();
-void COM_Client_Close(void)
-    if (driver->Client_Close)
-	(*driver->Client_Close) ();
Modified: grass/trunk/lib/driver/Polydots.c
--- grass/trunk/lib/driver/Polydots.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/driver/Polydots.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -5,8 +5,8 @@
     int i;
-    if (driver->Polydots_abs) {
-	(*driver->Polydots_abs) (xarray, yarray, number);
+    if (driver->Polydots) {
+	(*driver->Polydots) (xarray, yarray, number);
 	return;
@@ -20,11 +20,6 @@
     int i;
-    if (driver->Polydots_rel) {
-	(*driver->Polydots_rel) (xarray, yarray, number);
-	return;
     for (i = 0; i < number; i++) {
 	COM_Move_rel(xarray[i], yarray[i]);
 	COM_Cont_rel(0, 0);
Modified: grass/trunk/lib/driver/Polygon.c
--- grass/trunk/lib/driver/Polygon.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/driver/Polygon.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -121,8 +121,8 @@
 void COM_Polygon_abs(const int *xarray, const int *yarray, int number)
-    if (driver->Polygon_abs) {
-	(*driver->Polygon_abs) (xarray, yarray, number);
+    if (driver->Polygon) {
+	(*driver->Polygon) (xarray, yarray, number);
 	return;
@@ -135,11 +135,6 @@
     static int nalloc;
     int i;
-    if (driver->Polygon_rel) {
-	(*driver->Polygon_rel) (xarray, yarray, number);
-	return;
     if (number > nalloc) {
 	nalloc = number;
 	xa = G_realloc(xa, (size_t) nalloc * sizeof(int));
Modified: grass/trunk/lib/driver/Polyline.c
--- grass/trunk/lib/driver/Polyline.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/driver/Polyline.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -5,8 +5,8 @@
     int i;
-    if (driver->Polyline_abs) {
-	(*driver->Polyline_abs) (xarray, yarray, number);
+    if (driver->Polyline) {
+	(*driver->Polyline) (xarray, yarray, number);
 	return;
@@ -20,11 +20,6 @@
     int i;
-    if (driver->Polyline_rel) {
-	(*driver->Polyline_rel) (xarray, yarray, number);
-	return;
     COM_Move_rel(xarray[0], yarray[0]);
     for (i = 1; i < number; i++)
Modified: grass/trunk/lib/driver/driver.h
--- grass/trunk/lib/driver/driver.h	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/driver/driver.h	2008-08-08 23:02:24 UTC (rev 32648)
@@ -24,20 +24,14 @@
 struct driver
-    void (*Box_abs) (int, int, int, int);
-    void (*Box_rel) (int, int);
-    void (*Client_Open) (void);
-    void (*Client_Close) (void);
+    void (*Box) (int, int, int, int);
     void (*Erase) (void);
     int (*Graph_set) (int, char **);
     void (*Graph_close) (void);
     void (*Line_width) (int);
-    void (*Polydots_abs) (const int *, const int *, int);
-    void (*Polydots_rel) (const int *, const int *, int);
-    void (*Polyline_abs) (const int *, const int *, int);
-    void (*Polyline_rel) (const int *, const int *, int);
-    void (*Polygon_abs) (const int *, const int *, int);
-    void (*Polygon_rel) (const int *, const int *, int);
+    void (*Polydots) (const int *, const int *, int);
+    void (*Polyline) (const int *, const int *, int);
+    void (*Polygon) (const int *, const int *, int);
     void (*Set_window) (int, int, int, int);
     void (*Begin_scaled_raster) (int, int[2][2], int[2][2]);
     int (*Scaled_raster) (int, int,
@@ -69,10 +63,6 @@
 extern void COM_Box_abs(int, int, int, int);
 extern void COM_Box_rel(int, int);
-/* Client.c */
-extern void COM_Client_Open(void);
-extern void COM_Client_Close(void);
 /* Color.c */
 extern void COM_Color_RGB(unsigned char, unsigned char, unsigned char);
 extern void COM_Standard_color(int);
Modified: grass/trunk/lib/htmldriver/Driver.c
--- grass/trunk/lib/htmldriver/Driver.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/htmldriver/Driver.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -25,20 +25,14 @@
     if (initialized)
 	return &drv;
-    drv.Box_abs = NULL;
-    drv.Client_Close = NULL;
+    drv.Box = NULL;
     drv.Erase = NULL;
     drv.Graph_set = HTML_Graph_set;
     drv.Graph_close = HTML_Graph_close;
     drv.Line_width = NULL;
-    drv.Polyline_abs = NULL;
-    drv.Polygon_abs = HTML_Polygon_abs;
+    drv.Polyline = NULL;
+    drv.Polygon = HTML_Polygon;
     drv.Set_window = NULL;
     drv.Begin_scaled_raster = NULL;
     drv.Scaled_raster = NULL;
Deleted: grass/trunk/lib/htmldriver/Polygn_abs.c
--- grass/trunk/lib/htmldriver/Polygn_abs.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/htmldriver/Polygn_abs.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,211 +0,0 @@
-#include <string.h>
-#include <stdlib.h>
-#include <math.h>
-#include <grass/gis.h>
-#include "htmlmap.h"
-#define RAD_DEG 57.29578
-/* max points & bbox minimum dimension defined in Graph_Set.c */
-extern int MAX_POINTS;
-extern int BBOX_MINIMUM;
-extern int MINIMUM_DIST;
-static void delete_point(int *x, int *y, int count)
-    int i;
-    for (i = 0; i < count; i++) {
-	x[i] = x[i + 1];
-	y[i] = y[i + 1];
-static double find_azimuth(double x1, double y1, double x2, double y2)
-    double xx, yy;
-    xx = x1 - x2;
-    yy = y1 - y2;
-    if (x1 == x2) {
-	return (y2 > y1) ? 90.0 : 270.0;
-    else {
-	if (y2 < y1) {
-	    if (x2 > x1) {
-		return 360.0 + (RAD_DEG * atan(yy / xx));
-	    else {
-		return 180.0 + (RAD_DEG * atan(yy / xx));
-	else {
-	    if (x2 > x1) {
-		return (RAD_DEG * atan(yy / xx));
-	    else {
-void HTML_Polygon_abs(const int *px, const int *py, int n)
-    struct MapPoly *new;
-    int i;
-    int delta_x, delta_y;
-    int min_x, max_x, min_y, max_y;
-    double min_azimuth = 1.0;
-    double azimuth1, azimuth2, diff1, diff2;
-    int *x = G_malloc(n * sizeof(int));
-    int *y = G_malloc(n * sizeof(int));
-    memcpy(x, px, n * sizeof(int));
-    memcpy(y, py, n * sizeof(int));
-     * remove points that have adjacent duplicates or have differences of
-     * less the the minimum allowed.  remove end points that are same as
-     * the begin point (ending point = starting point is added
-     * during Graph_Clse)
-    i = 0;
-    while (i < (n - 1)) {
-	delta_x = x[i] - x[i + 1];
-	if (delta_x < 0)
-	    delta_x = -delta_x;
-	delta_y = y[i] - y[i + 1];
-	if (delta_y < 0)
-	    delta_y = -delta_y;
-	if ((x[i] == x[i + 1] && y[i] == y[i + 1]) ||
-	    (delta_x <= MINIMUM_DIST && delta_y <= MINIMUM_DIST)) {
-	    delete_point(&x[i + 1], &y[i + 1], n - i - 1);
-	    --n;
-	else {
-	    ++i;
-    /* perform same checks for last point & first point */
-    while (1) {
-	delta_x = x[0] - x[n - 1];
-	if (delta_x < 0)
-	delta_y = y[0] - y[n - 1];
-	if (delta_y < 0)
-	if ((x[0] == x[n - 1] && y[0] == y[n - 1]) ||
-	    --n;
-	else {
-	    break;
-     * if a polygon has either x or y extents less than the bounding box
-     * minimum, ignore it
-    min_x = max_x = x[0];
-    min_y = max_y = y[0];
-    for (i = 0; i < n; i++) {
-	if (x[i] < min_x)
-	    min_x = x[i];
-	if (x[i] > max_x)
-	    max_x = x[i];
-	if (y[i] < min_y)
-	    min_y = y[i];
-	if (y[i] > max_y)
-	    max_y = y[i];
-    delta_x = max_x - min_x;
-    delta_y = max_y - min_y;
-    if (delta_x < BBOX_MINIMUM || delta_y < BBOX_MINIMUM) {
-	n = 0;
-     * remove points in excess of MAX_POINTS vertices
-    while (n > MAX_POINTS) {
-	for (i = 0; i < (n - 2); i++) {
-	     * see if middle point can be removed, by checking if the
-	     * relative bearing to the middle is less than our current tolerance
-	    azimuth1 = find_azimuth((double)x[i], (double)y[i],
-				    (double)x[i + 1], (double)y[i + 1]);
-	    azimuth2 = find_azimuth((double)x[i], (double)y[i],
-				    (double)x[i + 2], (double)y[i + 2]);
-	    diff1 = fmod(fabs((azimuth2 + 360.0) - azimuth1), 360.0);
-	    diff2 = fmod(fabs((azimuth1 + 360.0) - azimuth2), 360.0);
-	    if (diff1 <= min_azimuth || diff2 <= min_azimuth) {
-		--n;
-		++i;
-		/* either stop deleting points because we're less than 100,
-		   or keep deleting points with the same difference as this
-		   one (which might make a smaller polygon yet).
-		   if (n <= 100) {
-		   break;
-	/* increase minimum azimuth difference for next round */
-	min_azimuth += 1.0;
-     * copy remaining points into a new MapPoly
-    if (n >= 3) {
-	new = (struct MapPoly *)G_malloc(sizeof(struct MapPoly));
-	/* grab the last text string written as url */
-	new->url = G_store(last_text);
-	/* hook up new MapPoly into list */
-	new->next_poly = NULL;
-	*tail = new;
-	tail = &(new->next_poly);
-	new->num_pts = n;
-	new->x_pts = x;
-	new->y_pts = y;
-    else {
-	G_free(x);
-	G_free(y);
Copied: grass/trunk/lib/htmldriver/Polygon.c (from rev 32646, grass/trunk/lib/htmldriver/Polygn_abs.c)
--- grass/trunk/lib/htmldriver/Polygon.c	                        (rev 0)
+++ grass/trunk/lib/htmldriver/Polygon.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -0,0 +1,211 @@
+#include <string.h>
+#include <stdlib.h>
+#include <math.h>
+#include <grass/gis.h>
+#include "driverlib.h"
+#include "htmlmap.h"
+#define RAD_DEG 57.29578
+/* max points & bbox minimum dimension defined in Graph_Set.c */
+extern int MAX_POINTS;
+extern int BBOX_MINIMUM;
+extern int MINIMUM_DIST;
+static void delete_point(int *x, int *y, int count)
+    int i;
+    for (i = 0; i < count; i++) {
+	x[i] = x[i + 1];
+	y[i] = y[i + 1];
+static double find_azimuth(double x1, double y1, double x2, double y2)
+    double xx, yy;
+    xx = x1 - x2;
+    yy = y1 - y2;
+    if (x1 == x2) {
+	return (y2 > y1) ? 90.0 : 270.0;
+    else {
+	if (y2 < y1) {
+	    if (x2 > x1) {
+		return 360.0 + (RAD_DEG * atan(yy / xx));
+	    else {
+		return 180.0 + (RAD_DEG * atan(yy / xx));
+	else {
+	    if (x2 > x1) {
+		return (RAD_DEG * atan(yy / xx));
+	    else {
+void HTML_Polygon(const int *px, const int *py, int n)
+    struct MapPoly *new;
+    int i;
+    int delta_x, delta_y;
+    int min_x, max_x, min_y, max_y;
+    double min_azimuth = 1.0;
+    double azimuth1, azimuth2, diff1, diff2;
+    int *x = G_malloc(n * sizeof(int));
+    int *y = G_malloc(n * sizeof(int));
+    memcpy(x, px, n * sizeof(int));
+    memcpy(y, py, n * sizeof(int));
+     * remove points that have adjacent duplicates or have differences of
+     * less the the minimum allowed.  remove end points that are same as
+     * the begin point (ending point = starting point is added
+     * during Graph_Clse)
+    i = 0;
+    while (i < (n - 1)) {
+	delta_x = x[i] - x[i + 1];
+	if (delta_x < 0)
+	    delta_x = -delta_x;
+	delta_y = y[i] - y[i + 1];
+	if (delta_y < 0)
+	    delta_y = -delta_y;
+	if ((x[i] == x[i + 1] && y[i] == y[i + 1]) ||
+	    (delta_x <= MINIMUM_DIST && delta_y <= MINIMUM_DIST)) {
+	    delete_point(&x[i + 1], &y[i + 1], n - i - 1);
+	    --n;
+	else {
+	    ++i;
+    /* perform same checks for last point & first point */
+    while (1) {
+	delta_x = x[0] - x[n - 1];
+	if (delta_x < 0)
+	delta_y = y[0] - y[n - 1];
+	if (delta_y < 0)
+	if ((x[0] == x[n - 1] && y[0] == y[n - 1]) ||
+	    --n;
+	else {
+	    break;
+     * if a polygon has either x or y extents less than the bounding box
+     * minimum, ignore it
+    min_x = max_x = x[0];
+    min_y = max_y = y[0];
+    for (i = 0; i < n; i++) {
+	if (x[i] < min_x)
+	    min_x = x[i];
+	if (x[i] > max_x)
+	    max_x = x[i];
+	if (y[i] < min_y)
+	    min_y = y[i];
+	if (y[i] > max_y)
+	    max_y = y[i];
+    delta_x = max_x - min_x;
+    delta_y = max_y - min_y;
+    if (delta_x < BBOX_MINIMUM || delta_y < BBOX_MINIMUM) {
+	n = 0;
+     * remove points in excess of MAX_POINTS vertices
+    while (n > MAX_POINTS) {
+	for (i = 0; i < (n - 2); i++) {
+	     * see if middle point can be removed, by checking if the
+	     * relative bearing to the middle is less than our current tolerance
+	    azimuth1 = find_azimuth((double)x[i], (double)y[i],
+				    (double)x[i + 1], (double)y[i + 1]);
+	    azimuth2 = find_azimuth((double)x[i], (double)y[i],
+				    (double)x[i + 2], (double)y[i + 2]);
+	    diff1 = fmod(fabs((azimuth2 + 360.0) - azimuth1), 360.0);
+	    diff2 = fmod(fabs((azimuth1 + 360.0) - azimuth2), 360.0);
+	    if (diff1 <= min_azimuth || diff2 <= min_azimuth) {
+		--n;
+		++i;
+		/* either stop deleting points because we're less than 100,
+		   or keep deleting points with the same difference as this
+		   one (which might make a smaller polygon yet).
+		   if (n <= 100) {
+		   break;
+	/* increase minimum azimuth difference for next round */
+	min_azimuth += 1.0;
+     * copy remaining points into a new MapPoly
+    if (n >= 3) {
+	new = (struct MapPoly *)G_malloc(sizeof(struct MapPoly));
+	/* grab the last text string written as url */
+	new->url = G_store(last_text);
+	/* hook up new MapPoly into list */
+	new->next_poly = NULL;
+	*tail = new;
+	tail = &(new->next_poly);
+	new->num_pts = n;
+	new->x_pts = x;
+	new->y_pts = y;
+    else {
+	G_free(x);
+	G_free(y);
Modified: grass/trunk/lib/htmldriver/htmlmap.h
--- grass/trunk/lib/htmldriver/htmlmap.h	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/htmldriver/htmlmap.h	2008-08-08 23:02:24 UTC (rev 32648)
@@ -41,8 +41,8 @@
 /* Graph_Set.c */
 extern int HTML_Graph_set(int, char **);
-/* Polygn_abs.c */
-extern void HTML_Polygon_abs(const int *, const int *, int);
+/* Polygon.c */
+extern void HTML_Polygon(const int *, const int *, int);
 /* Text.c */
 extern void HTML_Text(const char *);
Modified: grass/trunk/lib/pngdriver/Box.c
--- grass/trunk/lib/pngdriver/Box.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/pngdriver/Box.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,7 +1,7 @@
 #include "pngdriver.h"
-void PNG_Box_abs(int x1, int y1, int x2, int y2)
+void PNG_Box(int x1, int y1, int x2, int y2)
     int tmp;
     int x, y;
Deleted: grass/trunk/lib/pngdriver/Client.c
--- grass/trunk/lib/pngdriver/Client.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/pngdriver/Client.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,8 +0,0 @@
-#include "pngdriver.h"
-void PNG_Client_Close(void)
-    if (auto_write)
-	write_image();
Modified: grass/trunk/lib/pngdriver/Driver.c
--- grass/trunk/lib/pngdriver/Driver.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/pngdriver/Driver.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -27,20 +27,14 @@
     if (initialized)
 	return &drv;
-    drv.Box_abs = PNG_Box_abs;
-    drv.Client_Close = PNG_Client_Close;
+    drv.Box = PNG_Box;
     drv.Erase = PNG_Erase;
     drv.Graph_set = PNG_Graph_set;
     drv.Graph_close = PNG_Graph_close;
     drv.Line_width = PNG_Line_width;
-    drv.Polygon_abs = NULL;
+    drv.Polygon = NULL;
     drv.Set_window = PNG_Set_window;
     drv.Begin_scaled_raster = PNG_begin_scaled_raster;
     drv.Scaled_raster = PNG_scaled_raster;
Modified: grass/trunk/lib/pngdriver/Makefile
--- grass/trunk/lib/pngdriver/Makefile	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/pngdriver/Makefile	2008-08-08 23:02:24 UTC (rev 32648)
@@ -11,7 +11,6 @@
 LIB_OBJS =	\
 	Box.o			\
-	Client.o		\
 	Color.o			\
 	Color_table.o		\
 	Draw_bitmap.o		\
Modified: grass/trunk/lib/pngdriver/pngdriver.h
--- grass/trunk/lib/pngdriver/pngdriver.h	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/pngdriver/pngdriver.h	2008-08-08 23:02:24 UTC (rev 32648)
@@ -44,7 +44,7 @@
 extern const struct driver *PNG_Driver(void);
-extern void PNG_Box_abs(int, int, int, int);
+extern void PNG_Box(int, int, int, int);
 extern void PNG_Client_Close(void);
 extern void PNG_Erase(void);
 extern void PNG_Graph_close(void);
Modified: grass/trunk/lib/psdriver/Box.c
--- grass/trunk/lib/psdriver/Box.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/psdriver/Box.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,7 +1,7 @@
 #include "psdriver.h"
-void PS_Box_abs(int x1, int y1, int x2, int y2)
+void PS_Box(int x1, int y1, int x2, int y2)
     output("%d %d %d %d BOX\n", x1, y1, x2, y2);
Deleted: grass/trunk/lib/psdriver/Client.c
--- grass/trunk/lib/psdriver/Client.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/psdriver/Client.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,7 +0,0 @@
-#include "psdriver.h"
-void PS_Client_Close(void)
-    fflush(outfp);
Modified: grass/trunk/lib/psdriver/Driver.c
--- grass/trunk/lib/psdriver/Driver.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/psdriver/Driver.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -27,20 +27,14 @@
     if (initialized)
 	return &drv;
-    drv.Box_abs = PS_Box_abs;
-    drv.Client_Close = PS_Client_Close;
+    drv.Box = PS_Box;
     drv.Erase = PS_Erase;
     drv.Graph_set = PS_Graph_set;
     drv.Graph_close = PS_Graph_close;
     drv.Line_width = PS_Line_width;
-    drv.Polyline_abs = PS_Polyline_abs;
-    drv.Polygon_abs = PS_Polygon_abs;
+    drv.Polyline = PS_Polyline;
+    drv.Polygon = PS_Polygon;
     drv.Set_window = PS_Set_window;
     drv.Begin_scaled_raster = PS_begin_scaled_raster;
     drv.Scaled_raster = PS_scaled_raster;
Modified: grass/trunk/lib/psdriver/Polygon.c
--- grass/trunk/lib/psdriver/Polygon.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/psdriver/Polygon.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,7 +1,7 @@
-void PS_Polygon_abs(const int *xarray, const int *yarray, int number)
+void PS_Polygon(const int *xarray, const int *yarray, int number)
     int i;
Modified: grass/trunk/lib/psdriver/Polyline.c
--- grass/trunk/lib/psdriver/Polyline.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/psdriver/Polyline.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -1,7 +1,7 @@
-void PS_Polyline_abs(const int *xarray, const int *yarray, int number)
+void PS_Polyline(const int *xarray, const int *yarray, int number)
     int i;
Modified: grass/trunk/lib/psdriver/psdriver.h
--- grass/trunk/lib/psdriver/psdriver.h	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/psdriver/psdriver.h	2008-08-08 23:02:24 UTC (rev 32648)
@@ -21,7 +21,7 @@
 extern const struct driver *PS_Driver(void);
-extern void PS_Box_abs(int, int, int, int);
+extern void PS_Box(int, int, int, int);
 extern void PS_Client_Close(void);
 extern void PS_Erase(void);
 extern void PS_Graph_close(void);
@@ -39,7 +39,7 @@
 			    const unsigned char *, const unsigned char *,
 extern void PS_end_scaled_raster(void);
-extern void PS_Polygon_abs(const int *, const int *, int);
-extern void PS_Polyline_abs(const int *, const int *, int);
+extern void PS_Polygon(const int *, const int *, int);
+extern void PS_Polyline(const int *, const int *, int);
 #endif /* __PSDRIVER_H__ */
Modified: grass/trunk/lib/raster/raster.c
--- grass/trunk/lib/raster/raster.c	2008-08-08 22:44:39 UTC (rev 32647)
+++ grass/trunk/lib/raster/raster.c	2008-08-08 23:02:24 UTC (rev 32648)
@@ -54,8 +54,6 @@
     init();
-    COM_Client_Open();
     return 0;
@@ -69,7 +67,6 @@
     char *cmd = getenv("GRASS_NOTIFY");
     COM_Respond();
-    COM_Client_Close();
     COM_Graph_close();
     if (cmd)
