[GRASS-SVN] r32777 - in grass-addons/raster/r.rast4d: bin lib
Fri Aug 15 09:04:15 EDT 2008
Author: neteler
Date: 2008-08-15 09:04:15 -0400 (Fri, 15 Aug 2008)
New Revision: 32777
   grass-addons/raster/r.rast4d/bin/tg.list
   grass-addons/raster/r.rast4d/lib/insert_raster.sh
   grass-addons/raster/r.rast4d/lib/remove_raster.sh
generalized $GRAST4D_DBM call syntax
Modified: grass-addons/raster/r.rast4d/bin/tg.list
--- grass-addons/raster/r.rast4d/bin/tg.list	2008-08-15 12:59:10 UTC (rev 32776)
+++ grass-addons/raster/r.rast4d/bin/tg.list	2008-08-15 13:04:15 UTC (rev 32777)
@@ -70,7 +70,7 @@
 source ${GISBASE}/etc/r.rast4d/globals/defines.sh
 echo "select $GIS_OPT_SELECTION from $GRASTER_VIEW_NAME where $GIS_OPT_WHERE order by $GIS_OPT_ORDER"
-$GRAST4D_DBM $GRAST4D_DATABASE "select $GIS_OPT_SELECTION from $GRASTER_VIEW_NAME where $GIS_OPT_WHERE order by $GIS_OPT_ORDER"
+echo "select $GIS_OPT_SELECTION from $GRASTER_VIEW_NAME where $GIS_OPT_WHERE order by $GIS_OPT_ORDER;" | $GRAST4D_DBM $GRAST4D_DATABASE
 exit 0
Modified: grass-addons/raster/r.rast4d/lib/insert_raster.sh
--- grass-addons/raster/r.rast4d/lib/insert_raster.sh	2008-08-15 12:59:10 UTC (rev 32776)
+++ grass-addons/raster/r.rast4d/lib/insert_raster.sh	2008-08-15 13:04:15 UTC (rev 32777)
@@ -48,14 +48,14 @@
 CAT_NUM=`r.info $MAPNAME | grep "Categories:" | awk '{print $9}'`
 # create or update the database table
-STRING=`$GRAST4D_DBM $GRAST4D_DATABASE "select name from $GRASTER_TABLE_NAME where name='$MAPNAME'"`
+STRING=`echo "SELECT name FROM $GRASTER_TABLE_NAME WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE`
 if [ "$STRING" = "" ] ; then
   echo "INSERT NEW $GRASTER_TABLE_NAME ENTRY $MAPNAME"
   SQL_DATATYPE_STRING="(name, base_map, reference_table, color, group_table, temporal_table, metadata_table, category_table, category_num)"
   SQL_VALUE_STRING="('$MAPNAME', '$BASE_MAP', '$REFERENCE_TABLE','$COLOR', '$GROUP_TABLE', '$TEMPORAL_TABLE', '$METADATA_TABLE', '$CATEGORY_TABLE', '$CAT_NUM')"
-  $GRAST4D_DBM $GRAST4D_DATABASE "INSERT INTO $GRASTER_TABLE_NAME $SQL_DATATYPE_STRING values $SQL_VALUE_STRING"
+  echo "INSERT INTO $GRASTER_TABLE_NAME $SQL_DATATYPE_STRING values $SQL_VALUE_STRING;" | $GRAST4D_DBM $GRAST4D_DATABASE
   #create the raster map tables
   #cat $SQL_DIR/create_name_list_table.sql | sed s/TABLE_NAME/$REFERENCE_TABLE/ | $GRAST4D_DBM $GRAST4D_DATABASE
@@ -66,9 +66,9 @@
 else
   echo "UPDATE $GRASTER_TABLE_NAME ENTRY $MAPNAME"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TABLE_NAME SET base_map='$BASE_MAP' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TABLE_NAME SET color='$COLOR' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TABLE_NAME SET category_num='$CAT_NUM' WHERE name='$MAPNAME'"
+  echo "UPDATE $GRASTER_TABLE_NAME SET base_map='$BASE_MAP' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $GRASTER_TABLE_NAME SET color='$COLOR' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $GRASTER_TABLE_NAME SET category_num='$CAT_NUM' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
 fi
@@ -116,35 +116,35 @@
 # insert or update
-STRING=`$GRAST4D_DBM $GRAST4D_DATABASE "select name from $METADATA_TABLE where name='$MAPNAME'"`
+STRING=`echo "select name from $METADATA_TABLE where name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE`
   echo "INSERT NEW $METADATA_TABLE ENTRY $MAPNAME"
   SQL_DATATYPE_STRING="(name, projection, datatype, rows, cols, cell_num, north, south, west, east, ns_res,
 		      ew_res, min, max, mtime, creator, data_source, comments, description, additional_data)"
   SQL_VALUE_STRING="('$MAPNAME', '$PROJECTION', '$datatype', '$ROWS', '$COLS', '$CELLNUM', '$north', '$south', '$west', '$east',
 		   '$nsres' , '$ewres', '$min', '$max', $MTIME, '$CREATOR', '$DATA_SOURCE', '$COMMENTS', '$DESCRIPTION' , '$ADDITIONAL_DATA')"
-  $GRAST4D_DBM $GRAST4D_DATABASE "INSERT INTO $METADATA_TABLE $SQL_DATATYPE_STRING values $SQL_VALUE_STRING"
+  echo "INSERT INTO $METADATA_TABLE $SQL_DATATYPE_STRING values $SQL_VALUE_STRING;" | $GRAST4D_DBM $GRAST4D_DATABASE
 else
   echo "UPDATE $METADATA_TABLE ENTRY $MAPNAME"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET projection='$PROJECTION' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET datatype='$datatype' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET rows='$ROWS' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET cols='$COLS' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET cell_num='$CELLNUM' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET north='$north' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET south='$south' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET west='$west' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET east='$east' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET ns_res='$nsres' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET ew_res='$ewres' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET min='$min' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET max='$max' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET mtime=$MTIME WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET creator='$CREATOR' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET data_source='$DATA_SOURCE' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET comments='$COMMENTS' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET description='$DESCRIPTION' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $METADATA_TABLE SET additional_data='$ADDITIONAL_DATA' WHERE name='$MAPNAME'"
+  echo "UPDATE $METADATA_TABLE SET projection='$PROJECTION' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET datatype='$datatype' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET rows='$ROWS' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET cols='$COLS' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET cell_num='$CELLNUM' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET north='$north' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET south='$south' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET west='$west' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET east='$east' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET ns_res='$nsres' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET ew_res='$ewres' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET min='$min' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET max='$max' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET mtime=$MTIME WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET creator='$CREATOR' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET data_source='$DATA_SOURCE' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET comments='$COMMENTS' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET description='$DESCRIPTION' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $METADATA_TABLE SET additional_data='$ADDITIONAL_DATA' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
 fi
@@ -180,23 +180,23 @@
 #echo $VTIME_END
 # insert or update
-STRING=`$GRAST4D_DBM $GRAST4D_DATABASE "select name from $GRASTER_TIME_TABLE_NAME where name='$MAPNAME'"`
+STRING=`echo "select name from $GRASTER_TIME_TABLE_NAME where name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE`
   echo "INSERT NEW $GRASTER_TIME_TABLE_NAME ENTRY $MAPNAME"
   SQL_DATATYPE_STRING="(name, ctime, mtime, vtime_start, vtime_end)"
   SQL_VALUE_STRING="('$MAPNAME', '$CTIME', $MTIME, '$VTIME_START', $VTIME_END)"
-  $GRAST4D_DBM $GRAST4D_DATABASE "INSERT INTO $GRASTER_TIME_TABLE_NAME $SQL_DATATYPE_STRING values $SQL_VALUE_STRING"
+  echo "INSERT INTO $GRASTER_TIME_TABLE_NAME $SQL_DATATYPE_STRING values $SQL_VALUE_STRING;" | $GRAST4D_DBM $GRAST4D_DATABASE
 else
   echo "UPDATE $GRASTER_TIME_TABLE_NAME ENTRY $MAPNAME"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TIME_TABLE_NAME SET ctime='$CTIME' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TIME_TABLE_NAME SET mtime=$MTIME WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TIME_TABLE_NAME SET vtime_start='$VTIME_START' WHERE name='$MAPNAME'"
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TIME_TABLE_NAME SET vtime_end=$VTIME_END WHERE name='$MAPNAME'"
+  echo "UPDATE $GRASTER_TIME_TABLE_NAME SET ctime='$CTIME' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $GRASTER_TIME_TABLE_NAME SET mtime=$MTIME WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $GRASTER_TIME_TABLE_NAME SET vtime_start='$VTIME_START' WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
+  echo "UPDATE $GRASTER_TIME_TABLE_NAME SET vtime_end=$VTIME_END WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
  # difference in days
-  $GRAST4D_DBM $GRAST4D_DATABASE "UPDATE $GRASTER_TIME_TABLE_NAME SET vtime_duration=(strftime('%s',vtime_end) - (SELECT strftime('%s',vtime_start)))/86400.0"
+  echo "UPDATE $GRASTER_TIME_TABLE_NAME SET vtime_duration=(strftime('%s',vtime_end) - (SELECT strftime('%s',vtime_start)))/86400.0;" | $GRAST4D_DBM $GRAST4D_DATABASE
 fi
 exit
Modified: grass-addons/raster/r.rast4d/lib/remove_raster.sh
--- grass-addons/raster/r.rast4d/lib/remove_raster.sh	2008-08-15 12:59:10 UTC (rev 32776)
+++ grass-addons/raster/r.rast4d/lib/remove_raster.sh	2008-08-15 13:04:15 UTC (rev 32777)
@@ -23,7 +23,7 @@
 #$DBM $DATABASE "DROP TABLE $TEMPORAL_TABLE"
 echo "REMOVE $MAPNAME FROM $GRASTER_TABLE_NAME"
-$GRAST4D_DBM $GRAST4D_DATABASE "DELETE FROM $GRASTER_TABLE_NAME  WHERE name='$MAPNAME'"
+echo "DELETE FROM $GRASTER_TABLE_NAME  WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
@@ -31,12 +31,12 @@
 MAPNAME=$1
 echo "REMOVE $MAPNAME FROM $GRASTER_METADATA_TABLE_NAME"
-$GRAST4D_DBM $GRAST4D_DATABASE "DELETE FROM $GRASTER_METADATA_TABLE_NAME  WHERE name='$MAPNAME'"
+echo "DELETE FROM $GRASTER_METADATA_TABLE_NAME  WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
 remove_raster_map_time ()
 MAPNAME=$1
 echo "REMOVE $MAPNAME FROM $GRASTER_TIME_TABLE_NAME"
-$GRAST4D_DBM $GRAST4D_DATABASE "DELETE FROM $GRASTER_TIME_TABLE_NAME  WHERE name='$MAPNAME'"
+echo "DELETE FROM $GRASTER_TIME_TABLE_NAME  WHERE name='$MAPNAME';" | $GRAST4D_DBM $GRAST4D_DATABASE
