[GRASS-SVN] r33010 - grass/trunk/imagery/i.vpoints
Fri Aug 22 17:56:24 EDT 2008
Author: glynn
Date: 2008-08-22 17:56:24 -0400 (Fri, 22 Aug 2008)
New Revision: 33010
Removed:
   grass/trunk/imagery/i.vpoints/ask_lineclr.c
   grass/trunk/imagery/i.vpoints/open.c
   grass/trunk/imagery/i.vpoints/Makefile
Remove dead code
Modified: grass/trunk/imagery/i.vpoints/Makefile
--- grass/trunk/imagery/i.vpoints/Makefile	2008-08-22 16:35:08 UTC (rev 33009)
+++ grass/trunk/imagery/i.vpoints/Makefile	2008-08-22 21:56:24 UTC (rev 33010)
@@ -7,41 +7,6 @@
 EXTRA_INC = $(VECT_INC)
 EXTRA_CFLAGS = $(VECT_CFLAGS)
-MOD_OBJS =  main.o \
-        ask.o \
-        ask_mag.o \
-        analyze.o \
-        call.o \
-        cell.o \
-        cellhd.o \
-        conv.o \
-        colors.o \
-        curses.o \
-        crs.o \
-        debug.o \
-        digit.o \
-        dot.o \
-        drawcell.o \
-        drawvect.o \
-        driver.o \
-        equ.o \
-        find.o \
-        graphics.o \
-        group.o \
-        input.o \
-        mark.o \
-        mouse.o \
-        plot.o \
-        points.o \
-        setup.o \
-        target.o \
-        title.o \
-        view.o \
-        where.o \
-        zoom.o \
-        zoom_box.o \
-        zoom_pnt.o
 include $(MODULE_TOPDIR)/include/Make/Module.make
 default: cmd
Deleted: grass/trunk/imagery/i.vpoints/ask_lineclr.c
--- grass/trunk/imagery/i.vpoints/ask_lineclr.c	2008-08-22 16:35:08 UTC (rev 33009)
+++ grass/trunk/imagery/i.vpoints/ask_lineclr.c	2008-08-22 21:56:24 UTC (rev 33010)
@@ -1,356 +0,0 @@
-#include <grass/gis.h>
-#include "globals.h"
-#define NLINES 18
-struct box
-    int top, bottom, left, right;
-static int text_size;
-static int which;
-static struct box cancel, more, less;
-static int height, size, edge, count;
-static int page, npages;
-static struct
-    char name[100], mapset[100];
-    struct box box;
-} list[NLINES * 2];
-int ask_line_color(char *colors, int len1, char *xname, int position)
-    static int use = 1;
-    int pick();
-    static Objects objects[] = {
-	OTHER(pick, &use),
-	{0}
-    char msg[100];
-    int width;
-    int len2 = 0, len;
-    long offset;
-    long *page_offset;
-    int col, nlist;
-    int line;
-    int stat;
-    char buf[100];
-    int top, bottom, left, right, center;
-    int topx, bottomx, leftx, rightx, widthx;
-    char name[100], mapset[100], cur_mapset[100];
-    int new_mapset;
-    Menu_msg("");
-    sprintf(msg, "Double click on color to assign to vector layer");
-     * build a popup window at center of the screen.
-     * 35% the height and wide enough to hold 2 columms of file names
-     * the window is for choosing file names and will be laid out in 2 columns
-     *             |     CANCEL           | (MORE) | (LESS) |
-     *             |             mapset                     |
-     *             |      name1        |   name2            |
-     *             |      name3        |   name4            |
-     *             |      name5        |   name6            |
-    /* height of 1 line, based on NLINES taking up 35% vertical space */
-    height = (.35 * (SCREEN_BOTTOM - SCREEN_TOP)) / NLINES + 1;
-    /* size of text, 80% of line height */
-    text_size = .8 * height;
-    size = text_size - 1;	/* fudge for computing pixels width of text */
-    /* indent for the text */
-    edge = .1 * height + 1;
-    /* this is a fudge to determine the length of the largest text */
-    len1 = 2 * len1;		/* name in 2 columns */
-    len2 += strlen("mapset ");
-    len = (len1 > len2 ? len1 : len2);
-    /* width is for max chars plus sidecar for more/less */
-    width = len * size + height;
-    widthx = strlen(msg) * size;
-    if (widthx < width)
-	widthx = width;
-    /* define the window */
-    top = (SCREEN_TOP + SCREEN_BOTTOM - height * NLINES) / 2;
-    bottom = top + height * NLINES;
-    center = (SCREEN_LEFT + SCREEN_RIGHT) / 2;
-    if (position > 0) {
-	right = (center + SCREEN_RIGHT + width) / 2;
-	if (right >= SCREEN_RIGHT)
-	    right = SCREEN_RIGHT - 1;
-	left = right - width;
-    else if (position < 0) {
-	left = (center + SCREEN_LEFT - width) / 2;
-	if (left <= SCREEN_LEFT)
-	    left = SCREEN_LEFT + 1;
-	right = left + width;
-    else {
-	left = center + width / 2;
-    topx = top - 3 * height;
-    bottomx = topx + 2 * height;
-    leftx = (left + right - widthx) / 2;
-    if (leftx < SCREEN_LEFT)
-	leftx = SCREEN_LEFT;
-    rightx = leftx + widthx;
-    /* save what is under these areas, so they can be restored */
-    R_panel_save(tempfile1, top, bottom, left, right);
-    R_panel_save(tempfile2, topx, bottomx, leftx, rightx);
-    /* fill it top with GREY, pick area with white */
-    R_standard_color(WHITE);
-    R_box_abs(left, top, right, bottom);
-    R_standard_color(GREY);
-    R_box_abs(leftx, topx, rightx, bottomx);
-    R_standard_color(BLACK);
-    Outline_box(top, bottom, left, right);
-    right -= height;		/* reduce it to exclude sidecar */
-    /* print messages above the files */
-    dotext(msg, topx, topx + height, leftx, rightx, 1);
-    dotext("Double click here to cancel", topx + height, bottomx, leftx,
-	   rightx, 1);
-    cancel.top = topx;
-    cancel.bottom = bottomx;
-    cancel.left = leftx;
-    cancel.right = rightx;
-    /* start the mouse in the cancel box */
-    Set_mouse_xy((leftx + rightx) / 2, (topx + bottomx) / 2);
-    dobox(&less, "", WHITE, top, right, right + height, 0);
-    dobox(&more, "", WHITE, bottom - height, right, right + height, 0);
-    /* as we read the file of names, keep track of pages so we can
-     * page backward
-    page = 0;
-    page_offset = (long *)G_calloc(npages = 1, sizeof(long));
-    *page_offset = ftell(fd);
-    nlist = sizeof(list) / sizeof(list[0]);
-    for (stat = -1; stat < 0;) {
-	line = 0;
-	count = 0;
-	*cur_mapset = 0;
-	col = 0;
-	while (1) {
-	       offset = ftell (fd);
-	       if (fgets (buf, sizeof buf, fd) == NULL
-	       || sscanf (buf, "%s %s", name, mapset) != 2)
-	       break;
-	       if(new_mapset = (strcmp (cur_mapset,mapset) != 0))
-	       if(line) line++;
-	       if (col) line++;
-	       col = 0;
-	       if (count >= nlist || line+new_mapset >= NLINES)
-	       if (page+1 == npages)
-	       npages++;
-	       page_offset = (long *) G_realloc (page_offset, npages * sizeof (long));
-	       page_offset[npages-1] = offset;
-	       break;
-	       if (new_mapset)
-	       struct box dummy;
-	       char label[100];
-	       strcpy (cur_mapset, mapset);
-	       sprintf (label, "Mapset %s", mapset);
-	       dobox (&dummy, label, WHITE, top+line*height, left, right, 0);
-	       line++;
-	       if (col)
-	       dobox (&list[count].box, name, GREY, top+line*height, left+width/2, right, 0);
-	       line++;
-	       col = 0;
-	       else
-	       dobox (&list[count].box, name, GREY, top+line*height, left, left+width/2, 0);
-	       col = 1;
-	       strcpy (list[count].name, name);
-	       strcpy (list[count].mapset, mapset);
-	       count++;
-	       downarrow (&more, page+1 < npages ? BLACK : WHITE);
-	       uparrow   (&less, page   > 0      ? BLACK : WHITE);
-	       which = -1;
-	       switch(Input_pointer(objects))
-	       case -1: /* more or less */
-	    break;
-case -2:			/* cancel */
-	    stat = 0;
-	    continue;
-default:			/* file picked */
-	    strcpy(xname, list[which].name);
-	    stat = 1;
-	    continue;
-	fseek(fd, page_offset[page], 0);
-	R_box_abs(left + 1, top + 1, right - 1, bottom - 1);
-    /* all done. restore what was under the window */
-    right += height;		/* move it back over the sidecar */
-    R_panel_restore(tempfile1);
-    R_panel_restore(tempfile2);
-    R_panel_delete(tempfile1);
-    R_panel_delete(tempfile2);
-    R_flush();
-    G_free(page_offset);
-    return stat;
-static dobox(box, text, color, top, left, right, centered)
-     struct box *box;
-     char *text;
-    int bottom;
-    bottom = top + height;
-    /* fill inside of box with color */
-    R_standard_color(color);
-    /* draw box outline and text in black */
-    dotext(text, top, bottom, left, right, centered);
-    box->top = top;
-    box->bottom = bottom;
-    box->left = left;
-    box->right = right;
-static uparrow(box, color)
-     struct box *box;
-    Uparrow(box->top + edge, box->bottom - edge, box->left + edge,
-	    box->right - edge);
-static downarrow(box, color)
-     struct box *box;
-    Downarrow(box->top + edge, box->bottom - edge, box->left + edge,
-static pick(int x, int y, int button)
-    int n;
-    if (inbox(&more, x, y)) {
-	cancel_which();
-	if (page + 1 >= npages)
-	    return 0;
-	page++;
-	return -1;
-    if (inbox(&less, x, y)) {
-	cancel_which();
-	if (page == 0)
-	    return 0;
-	page--;
-	return -1;
-    if (inbox(&cancel, x, y)) {
-	if (which == -2)
-	    return -2;
-	cancel_which();
-	which = -2;
-	R_standard_color(RED);
-	Outline_box(cancel.top, cancel.bottom, cancel.left, cancel.right);
-	return 0;
-    /* search name list. handle double click */
-    for (n = 0; n < count; n++)
-	if (inbox(&list[n].box, x, y)) {
-	    if (n == which)	/* second click! */
-		return 1;
-	    cancel_which();
-	    which = n;
-	    Outline_box(list[n].box.top, list[n].box.bottom,
-			list[n].box.left, list[n].box.right);
-	    return 0;		/* ignore first click */
-    cancel_which();
-    return 0;
-static cancel_which(void)
-    if (which == -2) {
-    else if (which >= 0) {
-	Outline_box(list[which].box.top, list[which].box.bottom,
-		    list[which].box.left, list[which].box.right);
-    which = -1;
-static inbox(box, x, y)
-     struct box *box;
-    return (x > box->left && x < box->right && y > box->top &&
-	    y < box->bottom);
-static
-dotext(char *text, int top, int bottom, int left, int right, int centered)
-    R_text_size(text_size, text_size);
-    R_move_abs(left + 1 + edge, bottom - 1 - edge);
-    if (centered)
-	R_move_rel((right - left - strlen(text) * size) / 2, 0);
-    R_set_window(top, bottom, left, right);	/* for text clipping */
-    R_text(text);
-    R_set_window(SCREEN_TOP, SCREEN_BOTTOM, SCREEN_LEFT, SCREEN_RIGHT);
Deleted: grass/trunk/imagery/i.vpoints/open.c
--- grass/trunk/imagery/i.vpoints/open.c	2008-08-22 16:35:08 UTC (rev 33009)
+++ grass/trunk/imagery/i.vpoints/open.c	2008-08-22 21:56:24 UTC (rev 33010)
@@ -1,26 +0,0 @@
-/* open and close vector map for level one access */
-FILE *open_vect(char *name, char *mapset)
-    FILE *fd;
-    char msg[128];
-    fd = G_fopen_vector_old(name, mapset);
-    if (fd == NULL) {
-	sprintf(msg, "can't open vector map [%s]", name);
-	G_fatal_error(msg);
-    if (dig_init(fd) < 0) {
-	sprintf(msg, "can't initialize vector map [%s]", name);
-    return fd;
-int close_vect(FILE * fd)
-    dig_fini(fd);
-    fclose(fd);
