[GRASS-SVN] r32353 - grass-addons/gipe/i.eb.h_SEBAL95
Mon Jul 28 19:39:56 EDT 2008
Author: ychemin
Date: 2008-07-28 19:39:54 -0400 (Mon, 28 Jul 2008)
New Revision: 32353
   grass-addons/gipe/i.eb.h_SEBAL95/main.c
   grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
   grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c
Bugfixing
Modified: grass-addons/gipe/i.eb.h_SEBAL95/main.c
--- grass-addons/gipe/i.eb.h_SEBAL95/main.c	2008-07-28 22:22:28 UTC (rev 32352)
+++ grass-addons/gipe/i.eb.h_SEBAL95/main.c	2008-07-28 23:39:54 UTC (rev 32353)
@@ -98,7 +98,7 @@
 	/* Define different options */
 	input_T = G_define_standard_option(G_OPT_R_INPUT);
-	input_T->key	= "T";
+	input_T->key	= "tempk";
 	input_T->description = _("Name of Surface Skin Temperature input map [K]");
 	input_dT = G_define_standard_option(G_OPT_R_INPUT);
@@ -412,7 +412,7 @@
 			//d_ndvi	= ((DCELL *) inrast_ndvi)[col];
 			if(G_is_d_null_value(&d_ndvi)){
 				/* do nothing */
-			} else if ((d_ndvi)>d_ndvi_max&&(d_ndvi)<0.98){
+			} else if ((d_ndvi)>d_ndvi_max&&(d_ndvi)<0.999){
 				d_ndvi_max	= d_ndvi;
@@ -1110,6 +1110,7 @@
 						d_dT = -1.0;
 						d_dT_dry = -1.0;
+//					printf("iteration=%i\nd_tempk_wet=%f\nd_tempk_dry=%f\nd_t0dem=%f\nd_tempk=%f\nd_z0m=%f\nd_dT=%f\nd_dem=%f\nd_Rn_dry=%f\nd_g0_dry=%f\nd_t0dem_dry=%f\nd_u_hu=%f\nd_hu=%f\nd_dem_dry=%f\nd_dT_dry=%f\n",iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_z0m,d_dT,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry,d_dT_dry);
 					d = sensi_h_z0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_z0m,d_dT,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry,d_dT_dry);
 				} else {
 					if(input_dT->answer){
@@ -1120,7 +1121,24 @@
 						d_dT = -1.0;
 						d_dT_dry = -1.0;
-					d = sensi_h_noz0m(iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_dT,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry,d_dT_dry);
+//					printf("***************\n");
+//					printf("iteration=%i\nd_tempk_wet=%f\nd_tempk_dry=%f\nd_t0dem=%f\nd_tempk=%f\nd_dT=%f\nd_ndvi=%f\nd_ndvi_max=%f\nd_dem=%f\nd_Rn_dry=%f\nd_g0_dry=%f\nd_t0dem_dry=%f\nd_u_hu=%f\nd_hu=%f\nd_dem_dry=%f\nd_dT_dry=%f\n",iteration,d_tempk_wet,d_tempk_dry,d_t0dem,d_tempk,d_dT,d_ndvi,d_ndvi_max,d_dem,d_Rn_dry,d_g0_dry,d_t0dem_dry,d_u_hu,d_hu,d_dem_dry,d_dT_dry);
+					d = sensi_h_noz0m(iteration,
+							d_tempk_wet,
+							d_tempk_dry,
+							d_t0dem,
+							d_tempk,
+							d_dT,
+							d_ndvi,
+							d_ndvi_max,
+							d_dem,
+							d_Rn_dry,
+							d_g0_dry,
+							d_t0dem_dry,
+							d_u_hu,
+							d_hu,
+							d_dem_dry,
+							d_dT_dry);
 		//		G_message(" d_h0=%5.3f",d);
 				if (zero->answer && d<0.0){
Modified: grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c
--- grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c	2008-07-28 22:22:28 UTC (rev 32352)
+++ grass-addons/gipe/i.eb.h_SEBAL95/sensi_h_noz0m.c	2008-07-28 23:39:54 UTC (rev 32353)
@@ -37,35 +37,47 @@
 	if(t0_dem<250.0)
 		t0_dem=250.0;
-// 	printf("*****************************dtair = %5.3f\n",dtair[0]);
 	roh_air[0] 	= roh_air_0(tempk);
-// 	printf("*****************************rohair=%5.3f\n",roh_air[0]);
+ 	//printf("*****************************rohair=%5.3f\n",roh_air[0]);
 	roh_air_desert 	= roh_air_0(tempk_desert);
-// 	printf("**rohairdesert = %5.3f\n",roh_air_desert);
+ 	//printf("**rohairdesert = %5.3f\n",roh_air_desert);
 	zom0 		= zom_0(ndvi, ndvi_max);
-// 	printf("*****************************zom = %5.3f\n",zom0);
+ 	//printf("*****************************zom = %5.3f\n",zom0);
 	u_0 		= U_0(zom0, u_hu, hu);
-// 	printf("*****************************u0\n");
+ 	//printf("*****************************u0 = %5.3f\n",u_0);
 	rah[0] 		= rah_0(zom0, u_hu, hu);
-// 	printf("*****************************rah = %5.3f\n",rah[0]);
+ 	//printf("*****************************rah = %5.3f\n",rah[0]);
+	h_desert= rnet_desert - g0_desert;
+ 	//printf("*****************************h_desert = %5.3f\n",h_desert);
 	if(dtair_desert < 0.0){
-		h_desert= rnet_desert - g0_desert;
 		zom_desert= 0.002;
+ 		//printf("*****************************zom_desert = %5.3f\n",zom_desert);
 		ustar_desert= u_star(t0_dem_desert,h_desert,u_0,roh_air_desert,zom_desert,u_hu,hu);
-		psih_desert= psi_h(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
-		psim_desert= psi_m(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
-		rah_desert = rah1(zom_desert,psih_desert,psim_desert,ustar_desert);
-// 		printf("*****************************rah_desert = %5.3f\n",rah_desert);
+		//psih_desert= psi_h(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
+ 		//printf("*****************************psih_desert = %5.3f\n",psih_desert);
+		//psim_desert= psi_m(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
+ 		//printf("*****************************psim_desert = %5.3f\n",psim_desert);
+		//rah_desert= rah1(zom_desert,psih_desert,psim_desert,ustar_desert);
+		rah_desert= rah_0(zom_desert,u_hu,hu);
+ 		//printf("*****************************rah_desert = %5.3f\n",rah_desert);
 		dtair_desert = dt_air_desert(h_desert, roh_air_desert, rah_desert);
+ 		//printf("*****************************dtair_desert = %5.3f\n",dtair_desert);
 	if(dtair0 < 0.0){
 		dtair[0] = dt_air(t0_dem,tempk_water,tempk_desert,dtair_desert);
+		if(dtair[0]<0.0)
+			dtair[0]=0.0;
+ 		//printf("*****************************dtair[0] = %5.3f\n",dtair[0]);
 	} else {
 		dtair[0] = dtair0;
 	h[0] 		= h_0(roh_air[0], rah[0], dtair[0]);
 // 	printf("*****************************h\n");
 	if(debug==1){
+		printf("h_desert 	= %5.3f W/m2\n", h_desert);
+		printf("rah_desert	= %5.3f s/m\n", rah_desert);
+		printf("dtair_desert	= %5.3f K\n", dtair_desert);
 		printf("dtair[0]	= %5.3f K\n", dtair[0]);
 		printf("roh_air[0] 	= %5.3f kg/m3\n", roh_air[0]);
 		printf("roh_air_desert0 = %5.3f kg/m3\n", roh_air_desert);
@@ -94,7 +106,7 @@
 		ustar_desertold = ustar_desert;
 		ustar_desert	= u_star(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,zom_desert,u_hu,hu);
 		psih_desert 	= psi_h(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,hu);
-		psim_desert 	= psi_m(t0_dem_desert,h_desert,ustar_desert,roh_air_desert,hu);
+		psim_desert 	= psi_m(t0_dem_desert,h_desert,ustar_desertold,roh_air_desert,hu);
 		/* This should find the new dtair from inversed h equation...*/
Modified: grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c
--- grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c	2008-07-28 22:22:28 UTC (rev 32352)
+++ grass-addons/gipe/i.eb.h_SEBAL95/zom_0.c	2008-07-28 23:39:54 UTC (rev 32353)
@@ -5,14 +5,14 @@
 double zom_0(double ndvi, double ndvi_max)
 	double a, b, zom;
-	double hv_ndvimax=1.5; /* crop vegetation height (m) */
+	double hv_ndvimax=1.2; /* crop vegetation height (m) */
 	double hv_desert=0.002; /* desert base vegetation height (m) */
 	a = (log(hv_desert)-((log(hv_ndvimax/7)-log(hv_desert))/(ndvi_max-0.02)*0.02));
-	b = (log(hv_ndvimax/7)-log(hv_desert))/(ndvi_max-0.02)* ndvi;
+	b = ((log(hv_ndvimax/7)-log(hv_desert))/(ndvi_max-0.02)) * ndvi;
 	zom = exp(a+b);
-//	printf("zom = %5.3f\n", zom);
+//	printf("****************zom = %5.3f\n", zom);
 	return (zom);
