[GRASS-SVN] r33554 - grass/trunk/scripts/v.in.e00
Thu Sep 25 22:59:55 EDT 2008
Author: glynn
Date: 2008-09-25 22:59:55 -0400 (Thu, 25 Sep 2008)
New Revision: 33554
   grass/trunk/scripts/v.in.e00/v.in.e00.py
Fix bugs
Use more precise glob pattern (".e[0-9][0-9]" instead of ".e*")
Modified: grass/trunk/scripts/v.in.e00/v.in.e00.py
--- grass/trunk/scripts/v.in.e00/v.in.e00.py	2008-09-26 00:59:54 UTC (rev 33553)
+++ grass/trunk/scripts/v.in.e00/v.in.e00.py	2008-09-26 02:59:55 UTC (rev 33554)
@@ -53,9 +53,10 @@
 import sys
 import os
-import grass
 import shutil
 import subprocess
+import glob
+import grass
 def find_program(pgm):
     nuldev = file(os.devnull, 'w+')
@@ -126,7 +127,8 @@
 	pass
     os.mkdir(tmpdir)
-    for f in glob(e00name + '.e*') + glob(e00name + '.E*'):
+    files = glob.glob(e00name + '.e[0-9][0-9]') + glob.glob(e00name + '.E[0-9][0-9]')
+    for f in files:
 	shutil.copy(f, tmpdir)
     #change to temporary directory to later avoid removal problems (rm -r ...)
@@ -136,7 +138,6 @@
     #avcimport doesn't set exist status :-(
     if merging:
-	files = glob(e00name + '.e*') + glob(e00name + '.E*')
 	files.sort()
 	filename = "%s.cat.%s.e00" % (e00name, e00tmp)
 	outf = file(filename, 'wb')
@@ -172,7 +173,7 @@
     itype = dict(point = 'point', line = 'line', area = 'centroid')
     if grass.run_command('v.in.ogr', flags = 'o', dsn = e00shortname,
-			 layer = layer[type], type = intype[type],
+			 layer = layer[type], type = itype[type],
 			 output = name) != 0:
 	grass.fatal("An error occurred while running v.in.ogr")
