[GRASS-SVN] r33555 - in grass/branches/develbranch_6/raster: r.resamp.interp r.resamp.stats
Fri Sep 26 02:08:37 EDT 2008
Author: hamish
Date: 2008-09-26 02:08:36 -0400 (Fri, 26 Sep 2008)
New Revision: 33555
   grass/branches/develbranch_6/raster/r.resamp.interp/description.html
   grass/branches/develbranch_6/raster/r.resamp.stats/description.html
hints from the ML
Modified: grass/branches/develbranch_6/raster/r.resamp.interp/description.html
--- grass/branches/develbranch_6/raster/r.resamp.interp/description.html	2008-09-26 02:59:55 UTC (rev 33554)
+++ grass/branches/develbranch_6/raster/r.resamp.interp/description.html	2008-09-26 06:08:36 UTC (rev 33555)
@@ -16,20 +16,24 @@
 This module is intended for reinterpolation of continuous data
 to a different resolution rather than for interpolation from scattered data
 (use the <em>v.surf.*</em> modules for that purpose).
-</p>
+<h2>NOTES</h2>
 <p>
+Resampling modules (<em>r.resample, r.resamp.stats, r.resamp.interp,
+r.resamp.rst</em>) resample the map to match the current region settings.
+</p>
+<p>
 Note that for bilinear and bicubic interpolation,
 cells of the output raster that cannot be bounded by the appropriate number
 of input cell centers are set to NULL (NULL propagation). This could occur
 due to the input cells being outside the current region, being NULL or MASKed.
 </p>
-<h2>NOTES</h2>
 <p>
-For longitude-latitude databases, the interpolation algorithm is based on
+For longitude-latitude locations, the interpolation algorithm is based on
 degree fractions, not on the absolute distances between cell centers.  Any
 attempt to implement the latter would violate the integrity of the
 interpolation method.
@@ -47,4 +51,5 @@
 Glynn Clements
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/branches/develbranch_6/raster/r.resamp.stats/description.html
--- grass/branches/develbranch_6/raster/r.resamp.stats/description.html	2008-09-26 02:59:55 UTC (rev 33554)
+++ grass/branches/develbranch_6/raster/r.resamp.stats/description.html	2008-09-26 06:08:36 UTC (rev 33555)
@@ -16,8 +16,15 @@
 is slower, but produces a more accurate result.
 </p>
 <h2>NOTES</h2>
+<p>
+</p>
 <h2>SEE ALSO</h2>
 <em><a href="g.region.html">g.region</a></em>,
@@ -29,4 +36,5 @@
 Glynn Clements
+<p>
