[GRASS-SVN] r40045 - in grass/trunk: gui/wxpython gui/wxpython/gui_modules gui/wxpython/support gui/wxpython/xml scripts scripts/v.krige
Fri Dec 18 10:04:47 EST 2009
Author: martinl
Date: 2009-12-18 10:04:47 -0500 (Fri, 18 Dec 2009)
New Revision: 40045
Added:
   grass/trunk/scripts/v.krige/
   grass/trunk/scripts/v.krige/v.krige.html
Removed:
   grass/trunk/scripts/v.krige/description.html
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/support/update_menudata.py
   grass/trunk/gui/wxpython/wxgui.py
   grass/trunk/gui/wxpython/xml/menudata.xml
   grass/trunk/scripts/Makefile
   grass/trunk/scripts/v.krige/Makefile
   grass/trunk/scripts/v.krige/v.krige.py
v.krige moved from add-ons to trunk (GSoC)
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2009-12-18 14:35:21 UTC (rev 40044)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2009-12-18 15:04:47 UTC (rev 40045)
@@ -411,7 +411,7 @@
                     if os.environ.has_key("GRASS_REGION"):
                         del os.environ["GRASS_REGION"]
-                if len(cmdlist) == 1:
+                if len(cmdlist) == 1 and cmdlist[0] not in ('v.krige'):
                     import menuform
                     # process GRASS command without argument
                     menuform.GUI().ParseCommand(cmdlist, parentframe=self)
Modified: grass/trunk/gui/wxpython/support/update_menudata.py
--- grass/trunk/gui/wxpython/support/update_menudata.py	2009-12-18 14:35:21 UTC (rev 40044)
+++ grass/trunk/gui/wxpython/support/update_menudata.py	2009-12-18 15:04:47 UTC (rev 40045)
@@ -1,4 +1,4 @@
 @brief Support script for wxGUI - only for developers needs. Updates
 menudata.xml file.
@@ -12,7 +12,7 @@
 License (>=v2). Read the file COPYING that comes with GRASS
 for details.
-Usage: python update_menudata.py
+Usage: python support/update_menudata.py
 @author Martin Landa <landa.martin gmail.com>
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2009-12-18 14:35:21 UTC (rev 40044)
+++ grass/trunk/gui/wxpython/wxgui.py	2009-12-18 15:04:47 UTC (rev 40045)
@@ -454,7 +454,7 @@
         if event:
             cmd = self.GetMenuCmd(event)
         self.goutput.RunCmd(cmd, switchPage=True)
     def OnMenuCmd(self, event, cmd = ''):
         """!Parse command selected from menu"""
         if event:
Modified: grass/trunk/gui/wxpython/xml/menudata.xml
--- grass/trunk/gui/wxpython/xml/menudata.xml	2009-12-18 14:35:21 UTC (rev 40044)
+++ grass/trunk/gui/wxpython/xml/menudata.xml	2009-12-18 15:04:47 UTC (rev 40045)
@@ -1584,6 +1584,14 @@
 	    </menuitem>
 	    <separator />
 	    <menuitem>
+	      <label>Ordinary or block kriging</label>
+	      <help>Performs ordinary or block kriging.</help>
+	      <keywords>vector,interpolation,kriging</keywords>
+              <handler>self.RunMenuCmd</handler>
+	      <command>v.krige</command>
+	    </menuitem>
+	    <separator />
+	    <menuitem>
 	      <label>Fill NULL cells</label>
 	      <help>Fills no-data areas in raster maps using v.surf.rst splines interpolation</help>
 	      <keywords>raster,elevation,interpolation</keywords>
@@ -2030,7 +2038,7 @@
 	    </menuitem>
 	    <menuitem>
 	      <label>Patch vector maps</label>
-	      <help>Creates a vector map by combining other vector maps.</help>
+	      <help>Creates a new vector map by combining other vector maps.</help>
 	      <keywords>vector,geometry</keywords>
               <handler>self.OnMenuCmd</handler>
 	      <command>v.patch</command>
@@ -2735,7 +2743,7 @@
 	    <separator />
 	    <menuitem>
 	      <label>Add columns</label>
-	      <help>Adds one or more columns to the attribute table connected to a given vector map</help>
+	      <help>Adds one or more columns to the attribute table connected to a given vector map.</help>
 	      <keywords>vector,database,attribute table</keywords>
 	      <command>v.db.addcolumn</command>
Modified: grass/trunk/scripts/Makefile
--- grass/trunk/scripts/Makefile	2009-12-18 14:35:21 UTC (rev 40044)
+++ grass/trunk/scripts/Makefile	2009-12-18 15:04:47 UTC (rev 40045)
@@ -60,7 +60,8 @@
 	v.rast.stats \
 	v.report \
 	v.out.gps \
-	v.what.vect
+	v.what.vect \
+	v.krige
 #	d.vect.thematic \
 #	d.out.gpsdrive \
Modified: grass/trunk/scripts/v.krige/Makefile
--- grass-addons/vector/v.krige/Makefile	2009-09-18 06:25:02 UTC (rev 39246)
+++ grass/trunk/scripts/v.krige/Makefile	2009-12-18 15:04:47 UTC (rev 40045)
@@ -1,6 +1,6 @@
 MODULE_TOPDIR = ../..
-PGM = v.krige.py
+PGM = v.krige
 include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass/trunk/scripts/v.krige/description.html
--- grass-addons/vector/v.krige/description.html	2009-09-18 06:25:02 UTC (rev 39246)
+++ grass/trunk/scripts/v.krige/description.html	2009-12-18 15:04:47 UTC (rev 40045)
@@ -1,224 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>v.krige</em> allows to perform kriging operations in GRASS
-environment, using R software functions in background.
-<h2>NOTES</h2>
-<em>v.krige</em> is just a front-end to R. The options and parameters are the same offered by packages <i>automap</i> and <i>gstat</i>.
-<p>
-Kriging, like other interpolation methods, is fully dependent on input
-data features. Exploratory analysis of data is encouraged to find out
-outliers, trends, anisotropies, uneven distributions and consequently
-choose the kriging algorithm that will give the most acceptable
-result. Good knowledge of the dataset is more valuable than hundreds
-of parameters or powerful hardware. See Isaaks and Srivastava's book,
-exhaustive and clear even if a bit outdated.
-<h3>Dependencies</h3>
-<dl>
-<dt><b>GRASS 6.5 with wxPython support</b></dt>
-<dd></dd>
-<dt><b>R software >= 2.x</b></dt>
-<dd></dd>
-<dt><b>rpy2</b></dt>
-<dd>Python binding to R. Note! rpy is not supported.</dd>
-<dt><b>R packages automap and gstat. </b></dt>
-<dd>automap is optional (provides automatic variogram fit).</dd>
-</dl>
-<h3>Install</h3>
-<h4>Easy way: g.extension</h4>
-Simply run:
-<div class="code"><pre>
-  g.extension v.krige
-<pre></div>
-<h4>Less easy way: manual install</h4>
-It is sufficient to copy it into the (GRASS binaries) path
-somewhere. Alternatively, install addons into a separate GRASS addons
-binaries/scripts directory which is easier to maintain. It avoids
-getting clobbered every time you reinstall GRASS. To use these
-separately stored scripts, set and export the GRASS_ADDON_PATH
-environment variable before starting GRASS and it will automatically
-be added to the module search path. To simplify this, do for example:
-  # add in $HOME/.bashrc:
-  GRASS_ADDON_PATH=/usr/local/grass/addons/
-  export GRASS_ADDON_PATH
-<pre></div>
-Make sure that the script is executable, then just call it in GRASS
-typing the filename. Python scripts need to be called writing the
-extension as well, like:
-  GRASS 6.5.svn (spearfish60):~ &gt; v.krige.py
-<pre></div>
-<h4>Notes for Debian GNU/Linux</h4>
-Install the dependiencies. <b>Attention! python-rpy IS NOT
-SUITABLE.</b>:
-  aptitude install R python-rpy2
-<pre></div>
-To install R packages, use either R's function (as root):
-  install.packages("gstat", dep=T)
-  install.packages("spgrass6", dep=T)
-<pre></div>
-either the brand new Debian packages [5], add to repositories' list
-for 32bit or 64bit (pick up the suitable line):
-  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-i386">http://debian.cran.r-project.org/cran2deb/debian-i386</a> testing/
-  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-amd64">http://debian.cran.r-project.org/cran2deb/debian-amd64</a> testing/
-<pre></div>
-and get the packages via aptitude:
-  aptitude install r-cran-gstat r-cran-spgrass6
-<pre></div>
-<h4>Notes for Windows</h4>
-At this very moment, v.krige is developed against GRASS 6.5
-(6_develbranch) and no backward compatibility with OSGeo4W's packaged
-GRASS 6.4svn2 is provided, nor with WinGRASS.
-<p>
-If you really need to run v.krige right now on Windows, I suggest to
-compile GRASS following this
-<a href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">guide</a>.
-You could also use Linux in a virtual machine. Or install Linux in a
-separate partition of the HD. This is not as painful as it appears,
-there are lots of guides over the Internet to help you.
-<h3>Computation time issues</h3>
-Please note that kriging calculation is slown down both by high number
-of input data points and/or high region resolution, even if they both
-contribute to a better output.
-<h2>EXAMPLES</h2>
-Kriging example based on elevation map (Spearfish data set).
-<p>
-<b>Part 1: random sampling</b> of 2000 vector points from known
-elevation map. Each point will receive the elevation value from the
-elevation raster, as if it came from a point survey.
- g.region rast=elevation.10m -p
- v.random output=rand2k_elev n=2000
- v.db.addtable map=rand2k_elev column="elevation double precision"
- v.what.rast vect=rand2k_elev rast=elevation.10m column=elevation
-<pre></div>
-<p>
-<b>Part 2: remove points lacking elevation attributes</b>. Points
-sampled at the border of the elevation map didn't receive any
-value. v.krige has no preferred action to cope with no data values, so
-the user must check for them and decide what to do (remove points,
-fill with the value of the nearest point, fill with the global/local
-mean...). In the following line of code, points with no data are
-removed from the map.
- v.extract rand2k_elev output=rand2k_elev_filt where="elevation not NULL"
-<pre></div>
-Check the result of previous line ("number of NULL attributes" must be
-0):
- v.univar rand2k_elev_filt type=point column=elevation
-<pre></div>
-<p>
-<b>Part 3: reconstruct DEM through kriging</b>. Using automatic
-variogram fit is the simplest way to run v.krige from CLI (note:
-requires R's automap package). Output map name is optional, the
-modules creates it automatically appending "_kriging" the the input
-map name and also checks for overwrite. If output_var is specified,
-the variance map is also created. Automatic variogram fit is provided
-by R package automap, the variogram models tested by the fitting
-functions are: exponential, spherical, Gaussian, Matern, M.Stein's
-parametrisation. A wider range of models is available from gstat
-package and can be tested on the GUI via the variogram plotting. If
-model is specified in the CLI, also sill, nugget and range values are
-to be provided, otherwise an error is raised (see second example of
-v.krige command).
- v.krige.py input=rand2k_elev_filt column=elevation output=rand2k_elev_kriging \
-               output_var=rand2k_elev_kriging_var
-               output_var=rand2k_elev_kriging_var model=Lin sill=2500 nugget=0 range=1000 \
-               --overwrite
-<pre></div>
-Or run wxGUI, to interactively fit the variogram and explore options:
-  v.krige.py
-</pre></div>
-<b>Calculate prediction error</b>:
- r.mapcalc "rand2k_elev_kriging_pe = sqrt(rand2k_elev_kriging_var)"
- r.univar elevation.10m
- r.univar rand2k_elev_kriging
- r.univar rand2k_elev_kriging_pe
-<pre></div>
-The results show high errors, as the kriging techniques (ordinary and
-block kriging) are unable to handle a dataset with a trend, like the
-one used in this example: elevation is higher in the southwest corner
-and lower on northeast corner. Universal kriging can give far better
-results in these cases as it can handle the trend. It is available in
-R package gstat and will be part of a future v.krige release.
-<h2>SEE ALSO</h2>
-R package <a href="http://cran.r-project.org/web/packages/gstat/index.html">gstat</a>,
-mantained by Edzer J. Pebesma and others
-<br>
-R
-package <a href="http://cran.r-project.org/web/packages/spgrass6/index.html">spgrass6</a>,
-mantained by Roger Bivand
-<br><br>
-v.krige's <a href="http://grass.osgeo.org/wiki/V.krige_GSoC_2009">wiki page</a>
-<h2>REFERENCES</h2>
-Isaaks and Srivastava, 1989: "An Introduction to Applied Geostatistics" (ISBN 0-19-505013-4)
-<h2>AUTHOR</h2>
-Anne Ghisla, Google Summer of Code 2009
-<p>
-<i>Last changed: $Date$</i>
Copied: grass/trunk/scripts/v.krige/v.krige.html (from rev 39246, grass-addons/vector/v.krige/description.html)
--- grass/trunk/scripts/v.krige/v.krige.html	                        (rev 0)
+++ grass/trunk/scripts/v.krige/v.krige.html	2009-12-18 15:04:47 UTC (rev 40045)
@@ -0,0 +1,178 @@
+<h2>DESCRIPTION</h2>
+<em>v.krige</em> allows to perform kriging operations in GRASS
+environment, using R software functions in background.
+<h2>NOTES</h2>
+<em>v.krige</em> is just a front-end to R. The options and parameters
+are the same offered by packages <i>automap</i> and <i>gstat</i>.
+<p>
+Kriging, like other interpolation methods, is fully dependent on input
+data features. Exploratory analysis of data is encouraged to find out
+outliers, trends, anisotropies, uneven distributions and consequently
+choose the kriging algorithm that will give the most acceptable
+result. Good knowledge of the dataset is more valuable than hundreds
+of parameters or powerful hardware. See Isaaks and Srivastava's book,
+exhaustive and clear even if a bit outdated.
+<h3>Dependencies</h3>
+<dl>
+<dt><b>R software >= 2.x</b></dt>
+<dd></dd>
+<dt><b>rpy2</b></dt>
+<dd>Python binding to R. Note! rpy is not supported.</dd>
+<dt><b>R packages automap and gstat. </b></dt>
+<dd>automap is optional (provides automatic variogram fit).</dd>
+</dl>
+<h4>Notes for Debian GNU/Linux</h4>
+Install the dependiencies. <b>Attention! python-rpy IS NOT
+SUITABLE.</b>:
+<div class="code"><pre>
+  aptitude install R python-rpy2
+<pre></div>
+To install R packages, use either R's function (as root):
+  install.packages("gstat", dep=T)
+  install.packages("spgrass6", dep=T)
+<pre></div>
+either the brand new Debian packages [5], add to repositories' list
+for 32bit or 64bit (pick up the suitable line):
+  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-i386">http://debian.cran.r-project.org/cran2deb/debian-i386</a> testing/
+  deb <a href="http://debian.cran.r-project.org/cran2deb/debian-amd64">http://debian.cran.r-project.org/cran2deb/debian-amd64</a> testing/
+<pre></div>
+and get the packages via aptitude:
+  aptitude install r-cran-gstat r-cran-spgrass6
+<pre></div>
+<h4>Notes for Windows</h4>
+Compile GRASS following this
+<a href="http://trac.osgeo.org/grass/wiki/CompileOnWindows">guide</a>.
+You could also use Linux in a virtual machine. Or install Linux in a
+separate partition of the HD. This is not as painful as it appears,
+there are lots of guides over the Internet to help you.
+<h3>Computation time issues</h3>
+Please note that kriging calculation is slown down both by high number
+of input data points and/or high region resolution, even if they both
+contribute to a better output.
+<h2>EXAMPLES</h2>
+Kriging example based on elevation map (Spearfish data set).
+<p>
+<b>Part 1: random sampling</b> of 2000 vector points from known
+elevation map. Each point will receive the elevation value from the
+elevation raster, as if it came from a point survey.
+ g.region rast=elevation.10m -p
+ v.random output=rand2k_elev n=2000
+ v.db.addtable map=rand2k_elev column="elevation double precision"
+ v.what.rast vect=rand2k_elev rast=elevation.10m column=elevation
+<pre></div>
+<b>Part 2: remove points lacking elevation attributes</b>. Points
+sampled at the border of the elevation map didn't receive any
+value. v.krige has no preferred action to cope with no data values, so
+the user must check for them and decide what to do (remove points,
+fill with the value of the nearest point, fill with the global/local
+mean...). In the following line of code, points with no data are
+removed from the map.
+ v.extract rand2k_elev output=rand2k_elev_filt where="elevation not NULL"
+<pre></div>
+Check the result of previous line ("number of NULL attributes" must be
+0):
+ v.univar rand2k_elev_filt type=point column=elevation
+<pre></div>
+<b>Part 3: reconstruct DEM through kriging</b>. Using automatic
+variogram fit is the simplest way to run v.krige from CLI (note:
+requires R's automap package). Output map name is optional, the
+modules creates it automatically appending "_kriging" the the input
+map name and also checks for overwrite. If output_var is specified,
+the variance map is also created. Automatic variogram fit is provided
+by R package automap, the variogram models tested by the fitting
+functions are: exponential, spherical, Gaussian, Matern, M.Stein's
+parametrisation. A wider range of models is available from gstat
+package and can be tested on the GUI via the variogram plotting. If
+model is specified in the CLI, also sill, nugget and range values are
+to be provided, otherwise an error is raised (see second example of
+v.krige command).
+ v.krige input=rand2k_elev_filt column=elevation output=rand2k_elev_kriging \
+         output_var=rand2k_elev_kriging_var
+         output_var=rand2k_elev_kriging_var model=Lin sill=2500 nugget=0 range=1000 \
+         --overwrite
+<pre></div>
+Or run wxGUI, to interactively fit the variogram and explore options:
+  v.krige
+</pre></div>
+<b>Calculate prediction error</b>:
+ r.mapcalc "rand2k_elev_kriging_pe = sqrt(rand2k_elev_kriging_var)"
+ r.univar elevation.10m
+ r.univar rand2k_elev_kriging
+ r.univar rand2k_elev_kriging_pe
+<pre></div>
+The results show high errors, as the kriging techniques (ordinary and
+block kriging) are unable to handle a dataset with a trend, like the
+one used in this example: elevation is higher in the southwest corner
+and lower on northeast corner. Universal kriging can give far better
+results in these cases as it can handle the trend. It is available in
+R package gstat and will be part of a future v.krige release.
+<h2>SEE ALSO</h2>
+R package <a href="http://cran.r-project.org/web/packages/gstat/index.html">gstat</a>,
+mantained by Edzer J. Pebesma and others
+<br>
+R
+package <a href="http://cran.r-project.org/web/packages/spgrass6/index.html">spgrass6</a>,
+mantained by Roger Bivand
+<br><br>
+v.krige's <a href="http://grass.osgeo.org/wiki/V.krige_GSoC_2009">wiki page</a>
+<h2>REFERENCES</h2>
+Isaaks and Srivastava, 1989: "An Introduction to Applied Geostatistics" (ISBN 0-19-505013-4)
+<h2>AUTHOR</h2>
+Anne Ghisla, Google Summer of Code 2009
+<p>
+<i>Last changed: $Date$</i>
Modified: grass/trunk/scripts/v.krige/v.krige.py
--- grass-addons/vector/v.krige/v.krige.py	2009-09-18 06:25:02 UTC (rev 39246)
+++ grass/trunk/scripts/v.krige/v.krige.py	2009-12-18 15:04:47 UTC (rev 40045)
@@ -1,4 +1,5 @@
 #!/usr/bin/env python
 MODULE:    v.krige
@@ -19,7 +20,7 @@
 #%module
 #% description: Performs ordinary or block kriging.
-#% keywords: vector, kriging
+#% keywords: vector, interpolation, kriging
 #%end
 #%option
@@ -32,7 +33,8 @@
 #%option
 #% key: column
 #% type: string
-#% description: Column with numerical value to be interpolated
+#% gisprompt: old,dbcolumn,dbcolumn
+#% description: Name of attribute column with numerical value to be interpolated
 #% required : yes
 #%end
 #%option
@@ -122,7 +124,7 @@
 ### i18N
 import gettext
-gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode=True)
+gettext.install('grasswxpy', os.path.join(os.getenv("GISBASE"), 'locale'), unicode = True)
 ### dependencies to be checked once, as they are quite time-consuming. cfr. grass.parser.
 # GRASS binding
@@ -153,29 +155,29 @@
         Checks for NULL values in the provided column and exits if they are present."""
         #@NOTE: it alters original data. Is it correct? Shall I remove those columns
         # if they were absent from original data?
-        cols = grass.vector_columns(map=map, layer=1)
+        cols = grass.vector_columns(map = map, layer = 1)
         if not cols.has_key('x') and not cols.has_key('y'):
-            grass.run_command('v.db.addcol', map = map,
+            grass.run_command('v.db.addcolumn', map = map,
                               columns = 'x double precision, y double precision')
             grass.run_command('v.to.db', map = map, option = 'coor', col = 'x,y')
-        nulls = int(grass.parse_command('v.univar', map=map, column=column, type='point', \
-                                     parse = (grass.parse_key_val, \
+        nulls = int(grass.parse_command('v.univar', map = map, column = column, type = 'point', \
+                                            parse = (grass.parse_key_val, \
                                      {'sep':': '}))['number of NULL attributes'])
         if nulls > 0:
             grass.fatal(_("%d NULL value(s) in the selected column - unable to perform kriging.") % nulls)
-        return robjects.r.readVECT6(map, type= 'point')
+        return robjects.r.readVECT6(map, type =  'point')
     def CreateGrid(self, inputdata):
         Grid = robjects.r.gmeta2grd()
         # addition of coordinates columns into dataframe.
         coordinatesDF = robjects.r['as.data.frame'](robjects.r.coordinates(Grid))
-        data=robjects.r['data.frame'](x=coordinatesDF.r['s1'][0],
-                                      y=coordinatesDF.r['s2'][0],
-                                      k=robjects.r.rep(1, Region['cols']*Region['rows']))
+        data = robjects.r['data.frame'](x = coordinatesDF.r['s1'][0],
+                                        y = coordinatesDF.r['s2'][0],
+                                        k = robjects.r.rep(1, Region['cols']*Region['rows']))
         GridPredicted = robjects.r.SpatialGridDataFrame(Grid,
                                                         data,
-                                                        proj4string= robjects.r.CRS(robjects.r.proj4string(inputdata)))
+                                                        proj4string =  robjects.r.CRS(robjects.r.proj4string(inputdata)))
         return GridPredicted
     def ComposeFormula(self, column, isblock, inputdata):
@@ -291,13 +293,13 @@
         self.border = 4
         #    1. Input data
-        InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Input Data")),
-                                          orient=wx.HORIZONTAL)
+        InputBoxSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Input Data")),
+                                          orient = wx.HORIZONTAL)
-        flexSizer = wx.FlexGridSizer(cols=3, hgap=5, vgap=5)
+        flexSizer = wx.FlexGridSizer(cols = 3, hgap = 5, vgap = 5)
         flexSizer.AddGrowableCol(1)
-        flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Point dataset:")),
+        flexSizer.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Point dataset:")),
                       flag = wx.ALIGN_CENTER_VERTICAL)
         self.InputDataMap = gselect.VectorSelect(parent = self,
                                                  ftype = 'points',
@@ -305,13 +307,13 @@
         self.InputDataMap.SetFocus()
         flexSizer.Add(item = self.InputDataMap, flag = wx.ALIGN_CENTER_VERTICAL)
-        RefreshButton = wx.Button(self, id=wx.ID_REFRESH)
+        RefreshButton = wx.Button(self, id = wx.ID_REFRESH)
         RefreshButton.Bind(wx.EVT_BUTTON, self.OnButtonRefresh)
         flexSizer.Add(item = RefreshButton, flag = wx.ALIGN_CENTER_VERTICAL)
-        flexSizer.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Numeric column:")),
-                      flag=wx.ALIGN_CENTER_VERTICAL)
-        self.InputDataColumn = gselect.ColumnSelect(self, id=wx.ID_ANY)
+        flexSizer.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Numeric column:")),
+                      flag = wx.ALIGN_CENTER_VERTICAL)
+        self.InputDataColumn = gselect.ColumnSelect(self, id = wx.ID_ANY)
         self.InputDataColumn.SetSelection(0)
         flexSizer.Add(item = self.InputDataColumn)
@@ -320,10 +322,10 @@
         InputBoxSizer.Add(item = flexSizer)
         #    2. Kriging. In book pages one for each R package. Includes variogram fit.
-        KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Kriging")), wx.HORIZONTAL)
+        KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Kriging")), wx.HORIZONTAL)
-        self.RPackagesBook = FN.FlatNotebook(parent=self, id=wx.ID_ANY,
-                                        style=FN.FNB_BOTTOM |
+        self.RPackagesBook = FN.FlatNotebook(parent = self, id = wx.ID_ANY,
+                                        style = FN.FNB_BOTTOM |
                                         FN.FNB_NO_NAV_BUTTONS |
                                         FN.FNB_FANCY_TABS | FN.FNB_NO_X_BUTTON)
@@ -331,29 +333,29 @@
             self.CreatePage(package = Rpackage)
         ## Command output. From menuform module, cmdPanel class
-        self.goutput = goutput.GMConsole(parent=self, margin=False,
-                                         pageid=self.RPackagesBook.GetPageCount(),
+        self.goutput = goutput.GMConsole(parent = self, margin = False,
+                                         pageid = self.RPackagesBook.GetPageCount(),
                                          notebook = self.RPackagesBook)
         self.goutputId = self.RPackagesBook.GetPageCount()
-        self.outpage = self.RPackagesBook.AddPage(self.goutput, text=_("Command output"))
+        self.outpage = self.RPackagesBook.AddPage(self.goutput, text = _("Command output"))
         self.RPackagesBook.SetSelection(0)
-        KrigingSizer.Add(self.RPackagesBook, proportion=1, flag=wx.EXPAND)
+        KrigingSizer.Add(self.RPackagesBook, proportion = 1, flag = wx.EXPAND)
         #    3. Output Parameters.
-        OutputSizer = wx.StaticBoxSizer(wx.StaticBox(self, id=wx.ID_ANY, label=_("Output")), wx.HORIZONTAL)
+        OutputSizer = wx.StaticBoxSizer(wx.StaticBox(self, id = wx.ID_ANY, label = _("Output")), wx.HORIZONTAL)
-        OutputParameters = wx.GridBagSizer(hgap=5, vgap=5)
+        OutputParameters = wx.GridBagSizer(hgap = 5, vgap = 5)
         OutputParameters.AddGrowableCol(1)
-        OutputParameters.Add(item = wx.StaticText(self, id=wx.ID_ANY, label=_("Name for the output raster map:")),
+        OutputParameters.Add(item = wx.StaticText(self, id = wx.ID_ANY, label = _("Name for the output raster map:")),
                              flag = wx.ALIGN_CENTER_VERTICAL,
                              pos = (0, 0))
         self.OutputMapName = gselect.Select(parent = self, id = wx.ID_ANY,
                                             type = 'raster',
                                             mapsets = [grass.gisenv()['MAPSET']])
-        OutputParameters.Add(item=self.OutputMapName, flag=wx.EXPAND | wx.ALL,
+        OutputParameters.Add(item = self.OutputMapName, flag = wx.EXPAND | wx.ALL,
                              pos = (0, 1))
-        self.VarianceRasterCheckbox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Export variance map as well: "))
+        self.VarianceRasterCheckbox = wx.CheckBox(self, id = wx.ID_ANY, label = _("Export variance map as well: "))
         self.VarianceRasterCheckbox.SetValue(state = True)
         OutputParameters.Add(item = self.VarianceRasterCheckbox,
@@ -362,36 +364,36 @@
                                             type = 'raster',
         self.VarianceRasterCheckbox.Bind(wx.EVT_CHECKBOX, self.OnVarianceCBChecked)
-        OutputParameters.Add(item=self.OutputVarianceMapName, flag=wx.EXPAND | wx.ALL,
+        OutputParameters.Add(item = self.OutputVarianceMapName, flag = wx.EXPAND | wx.ALL,
                              pos = (1, 1))
-        self.OverwriteCheckBox = wx.CheckBox(self, id=wx.ID_ANY,
-                                             label=_("Allow output files to overwrite existing files"))
+        self.OverwriteCheckBox = wx.CheckBox(self, id = wx.ID_ANY,
+                                             label = _("Allow output files to overwrite existing files"))
         self.OverwriteCheckBox.SetValue(state = False)
         OutputParameters.Add(item = self.OverwriteCheckBox,
                              pos = (2, 0), span = (1, 2))
-        OutputSizer.Add(OutputParameters, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
+        OutputSizer.Add(OutputParameters, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
         #    4. Run Button and Quit Button
         ButtonSizer = wx.BoxSizer(wx.HORIZONTAL)
-        HelpButton = wx.Button(self, id=wx.ID_HELP)
+        HelpButton = wx.Button(self, id = wx.ID_HELP)
         HelpButton.Bind(wx.EVT_BUTTON, self.OnHelpButton)
-        QuitButton = wx.Button(self, id=wx.ID_EXIT)
+        QuitButton = wx.Button(self, id = wx.ID_EXIT)
         QuitButton.Bind(wx.EVT_BUTTON, self.OnCloseWindow)
-        self.RunButton = wx.Button(self, id=wx.ID_ANY, label=_("Run")) # no stock ID for Run button..
+        self.RunButton = wx.Button(self, id = wx.ID_ANY, label = _("&Run")) # no stock ID for Run button..
         self.RunButton.Bind(wx.EVT_BUTTON, self.OnRunButton)
         self.RunButton.Enable(False) # disable it on loading the interface, as input map is not set
-        ButtonSizer.Add(HelpButton, proportion=0, flag=wx.ALIGN_LEFT | wx.ALL, border=self.border)
-        ButtonSizer.Add(QuitButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
-        ButtonSizer.Add(self.RunButton, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
+        ButtonSizer.Add(HelpButton, proportion = 0, flag = wx.ALIGN_LEFT | wx.ALL, border = self.border)
+        ButtonSizer.Add(QuitButton, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
+        ButtonSizer.Add(self.RunButton, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
         #    Main Sizer. Add each child sizer as soon as it is ready.
         Sizer = wx.BoxSizer(wx.VERTICAL)
-        Sizer.Add(InputBoxSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
-        Sizer.Add(KrigingSizer, proportion=1, flag=wx.EXPAND | wx.ALL, border=self.border)
-        Sizer.Add(OutputSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=self.border)
-        Sizer.Add(ButtonSizer, proportion=0, flag=wx.ALIGN_RIGHT | wx.ALL, border=self.border)
+        Sizer.Add(InputBoxSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
+        Sizer.Add(KrigingSizer, proportion = 1, flag = wx.EXPAND | wx.ALL, border = self.border)
+        Sizer.Add(OutputSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = self.border)
+        Sizer.Add(ButtonSizer, proportion = 0, flag = wx.ALIGN_RIGHT | wx.ALL, border = self.border)
         self.SetSizerAndFit(Sizer)
         # last action of __init__: update imput data list.
@@ -403,8 +405,8 @@
         """ Creates the three notebook pages, one for each R package """
         for package in ["gstat"]:
             classobj = eval("RBook"+package+"Panel")
-            setattr(self, "RBook"+package+"Panel", (classobj(self, id=wx.ID_ANY)))
-            self.RPackagesBook.AddPage(page=getattr(self, "RBook"+package+"Panel"), text=package)
+            setattr(self, "RBook"+package+"Panel", (classobj(self, id = wx.ID_ANY)))
+            self.RPackagesBook.AddPage(page = getattr(self, "RBook"+package+"Panel"), text = package)
     def OnButtonRefresh(self, event):
         """ Forces refresh of list of available layers. """
@@ -416,16 +418,16 @@
         event.Skip()
     def OnHelpButton(self, event):
-        # file = os.path.join(os.getenv("GISBASE"), "docs", "html", "v.krige.py.html")
+        # file = os.path.join(os.getenv("GISBASE"), "docs", "html", "v.krige.html")
         # file = os.path.join(os.path.curdir, "description.html")
         # @TODO fix HelpWindow
         # helpFrame = help.HelpWindow(parent=self, id=wx.ID_ANY,
-        #                            title=_("GRASS - Help page for v.krige.py"),
+        #                            title=_("GRASS - Help page for v.krige"),
         #                            size=(640, 480),
         #                            file=file)
         # helpFrame.Show(True)
-        grass.run_command('g.manual', entry = 'v.krige.py')
+        grass.run_command('g.manual', entry = 'v.krige')
         event.Skip()
@@ -459,10 +461,10 @@
             return False # no break invoked by above function
         # mount command string as it would have been written on CLI
-        command = ["v.krige.py", "input=" + self.InputDataMap.GetValue(),
-                                 "column=" + self.InputDataColumn.GetValue(),
-                                 "output=" + self.OutputMapName.GetValue(),
-                                 "package=" + '%s' % self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection())]
+        command = ["v.krige", "input=" + self.InputDataMap.GetValue(),
+                   "column=" + self.InputDataColumn.GetValue(),
+                   "output=" + self.OutputMapName.GetValue(),
+                   "package=" + '%s' % self.RPackagesBook.GetPageText(self.RPackagesBook.GetSelection())]
         if not hasattr(SelectedPanel, 'VariogramCheckBox') or not SelectedPanel.VariogramCheckBox.IsChecked():
             command.append("model=" + '%s' % SelectedPanel.ModelChoicebox.GetStringSelection().split(" ")[0])
@@ -518,36 +520,36 @@
         self.parent = parent
         self.VariogramSizer = wx.StaticBoxSizer(wx.StaticBox(self,
-                                                             id=wx.ID_ANY,
-                                                             label=_("Variogram fitting")),
+                                                             id = wx.ID_ANY,
+                                                             label = _("Variogram fitting")),
                                                 wx.HORIZONTAL)
         self.LeftSizer = wx.BoxSizer(wx.VERTICAL)
         self.RightSizer = wx.BoxSizer(wx.VERTICAL)
-        self.ParametersSizer = wx.GridBagSizer(vgap=5, hgap=5)
+        self.ParametersSizer = wx.GridBagSizer(vgap = 5, hgap = 5)
-        self.VariogramSizer.Add(self.LeftSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
-        self.VariogramSizer.Add(self.RightSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
+        self.VariogramSizer.Add(self.LeftSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+        self.VariogramSizer.Add(self.RightSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
         # left side of Variogram fitting. The checkboxes and spinctrls.
-        self.PlotButton = wx.Button(self, id=wx.ID_ANY, label=_("Plot/refresh variogram")) # no stock ID for Run button..
+        self.PlotButton = wx.Button(self, id = wx.ID_ANY, label = _("Plot/refresh variogram")) # no stock ID for Run button..
         self.PlotButton.Bind(wx.EVT_BUTTON, self.OnPlotButton)
         self.PlotButton.Enable(False) # grey it out until a suitable layer is available
-        self.LeftSizer.Add(self.PlotButton, proportion=0, flag= wx.ALL, border=parent.border)
-        self.LeftSizer.Add(self.ParametersSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
+        self.LeftSizer.Add(self.PlotButton, proportion = 0, flag =  wx.ALL, border = parent.border)
+        self.LeftSizer.Add(self.ParametersSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
         self.ParametersList = ["Sill", "Nugget", "Range"]
         MinValues = [0,0,1]
         for n in self.ParametersList:
             setattr(self, n+"ChextBox", wx.CheckBox(self,
-                                                    id=self.ParametersList.index(n),
-                                                    label=_(n + ":")))
+                                                    id = self.ParametersList.index(n),
+                                                    label = _(n + ":")))
             setattr(self, n+"Ctrl", (wx.SpinCtrl(self,
                                                  id = wx.ID_ANY,
                                                  min = MinValues[self.ParametersList.index(n)],
-                                                 max=maxint)))
+                                                 max = maxint)))
             getattr(self, n+"ChextBox").Bind(wx.EVT_CHECKBOX,
                                              self.UseValue,
-                                             id=self.ParametersList.index(n))
+                                             id = self.ParametersList.index(n))
             setattr(self, n+"Sizer", (wx.BoxSizer(wx.HORIZONTAL)))
             self.ParametersSizer.Add(getattr(self, n+"ChextBox"),
@@ -564,31 +566,31 @@
         #self.RightSizer.Add(PlotPanel, proportion=0, flag= wx.EXPAND|wx.ALL, border=parent.border)
         self.KrigingSizer = wx.StaticBoxSizer(wx.StaticBox(self,
-                                                             id=wx.ID_ANY,
-                                                             label=_("Kriging techniques")),
+                                                             id = wx.ID_ANY,
+                                                             label = _("Kriging techniques")),
                                                 wx.VERTICAL)
         KrigingList = ["Ordinary kriging", "Block kriging"]#, "Universal kriging"] #@FIXME: i18n on the list?
         self.KrigingRadioBox = wx.RadioBox(self,
-                                           id=wx.ID_ANY,
-                                           choices=KrigingList,
-                                           majorDimension=1,
-                                           style=wx.RA_SPECIFY_COLS)
+                                           id = wx.ID_ANY,
+                                           choices = KrigingList,
+                                           majorDimension = 1,
+                                           style = wx.RA_SPECIFY_COLS)
         self.KrigingRadioBox.Bind(wx.EVT_RADIOBOX, self.HideBlockOptions)
-        self.KrigingSizer.Add(self.KrigingRadioBox, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
+        self.KrigingSizer.Add(self.KrigingRadioBox, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
         # block kriging parameters. Size.
         BlockSizer = wx.BoxSizer(wx.HORIZONTAL)
-        BlockLabel = wx.StaticText(self, id= wx.ID_ANY, label = _("Block size:"))
-        self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min=1, max=maxint)
+        BlockLabel = wx.StaticText(self, id = wx.ID_ANY, label = _("Block size:"))
+        self.BlockSpinBox = wx.SpinCtrl(self, id = wx.ID_ANY, min = 1, max = maxint)
         self.BlockSpinBox.Enable(False) # default choice is Ordinary kriging so block param is disabled
-        BlockSizer.Add(BlockLabel, flag= wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=parent.border)
-        BlockSizer.Add(self.BlockSpinBox, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=parent.border)
-        self.KrigingSizer.Add(BlockSizer, flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border=parent.border)
+        BlockSizer.Add(BlockLabel, flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
+        BlockSizer.Add(self.BlockSpinBox, flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
+        self.KrigingSizer.Add(BlockSizer, flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL, border = parent.border)
         self.Sizer = wx.BoxSizer(wx.VERTICAL)
-        self.Sizer.Add(self.VariogramSizer, proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
-        self.Sizer.Add(self.KrigingSizer,  proportion=0, flag=wx.EXPAND | wx.ALL, border=parent.border)
+        self.Sizer.Add(self.VariogramSizer, proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
+        self.Sizer.Add(self.KrigingSizer,  proportion = 0, flag = wx.EXPAND | wx.ALL, border = parent.border)
     def HideBlockOptions(self, event):
         self.BlockSpinBox.Enable(event.GetInt() == 1)
@@ -608,12 +610,12 @@
         RBookPanel.__init__(self, parent, *args, **kwargs)
         if robjects.r.require('automap')[0]:
-            self.VariogramCheckBox = wx.CheckBox(self, id=wx.ID_ANY, label=_("Auto-fit variogram"))
+            self.VariogramCheckBox = wx.CheckBox(self, id = wx.ID_ANY, label = _("Auto-fit variogram"))
             self.LeftSizer.Insert(0,
                                   self.VariogramCheckBox,
-                                  proportion=0,
-                                  flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
-                                  border=4)
+                                  proportion = 0,
+                                  flag = wx.EXPAND | wx.ALIGN_CENTER_VERTICAL | wx.ALL,
+                                  border = 4)
             self.SetSizerAndFit(self.Sizer)
             self.VariogramCheckBox.Bind(wx.EVT_CHECKBOX, self.HideOptions)
             self.VariogramCheckBox.SetValue(state = True) # check it by default
@@ -622,7 +624,7 @@
         ModelList = robjects.r.levels(ModelFactor[0])
         #@FIXME: no other way to let the Python pick it up..
         # and this is te wrong place where to load this list. should be at the very beginning.
-        self.ModelChoicebox = wx.Choice(self, id=wx.ID_ANY, choices=ModelList)
+        self.ModelChoicebox = wx.Choice(self, id = wx.ID_ANY, choices = ModelList)
         # disable model parameters' widgets by default
         for n in ["Sill", "Nugget", "Range"]:
@@ -630,16 +632,16 @@
         self.ModelChoicebox.Enable(False)
         VariogramSubSizer = wx.BoxSizer(wx.HORIZONTAL)
-        VariogramSubSizer.Add(item=wx.StaticText(self,
-                                                 id= wx.ID_ANY,
+        VariogramSubSizer.Add(item = wx.StaticText(self,
+                                                 id =  wx.ID_ANY,
                                                  label = _("Model: ")),
-                              flag=wx.ALIGN_CENTER_VERTICAL | wx.ALL,
-                              border=4)
-        VariogramSubSizer.Add(item=self.ModelChoicebox,
-                              border=4)
+                              flag = wx.ALIGN_CENTER_VERTICAL | wx.ALL,
+                              border = 4)
+        VariogramSubSizer.Add(item = self.ModelChoicebox,
+                              border = 4)
-        self.LeftSizer.Insert(2, item= VariogramSubSizer)
+        self.LeftSizer.Insert(2, item = VariogramSubSizer)
@@ -744,10 +746,10 @@
         #@TODO: change these two lines as soon as geoR f(x)s are integrated.
         for n in self.GetChildren():
             n.Hide()
-        self.Sizer.Add(wx.StaticText(self, id= wx.ID_ANY, label = _("Work in progress! No functionality provided.")))
+        self.Sizer.Add(wx.StaticText(self, id = wx.ID_ANY, label = _("Work in progress! No functionality provided.")))
-def main(argv=None):
+def main(argv = None):
     #@FIXME: solve this double ifelse. the control should not be done twice.
     if argv is None:
@@ -755,7 +757,7 @@
         argv = sys.argv[1:] #stripping first item, the full name of this script
         # wxGUI call.
         app = wx.App()
-        KrigingFrame = KrigingModule(parent=None)
+        KrigingFrame = KrigingModule(parent = None)
         KrigingFrame.Centre()
         KrigingFrame.Show()
         app.MainLoop()
@@ -775,7 +777,7 @@
                 options['input'] = options['input'].split("@")[0]
             except:
                 pass
-            options['output'] =  options['input'] + '_kriging'
+            options['output'] = options['input'] + '_kriging'
         # check for output map with same name. g.parser can't handle this, afaik.
         if grass.find_file(options['output'], element = 'cell')['fullname'] and os.getenv("GRASS_OVERWRITE") == None:
@@ -850,11 +852,11 @@
     # R packages check.
     # @FIXME: it leaves a Rtmpxxxx folder into the make tempfolder and causes make complain. [markus]
     for each in ["gstat", "spgrass6"]:
-        if not robjects.r.require(each, quietly=True)[0]:
+        if not robjects.r.require(each, quietly = True)[0]:
             sys.exit(_("R package " + each + " is missing. Install it and re-run v.krige."))
 if __name__ == '__main__':
     if len(sys.argv) > 1:
-        sys.exit(main(argv=grass.parser()))
+        sys.exit(main(argv = grass.parser()))
     else:
         main()
