[GRASS-SVN] r40046 - in grass/trunk/vector: v.out.vtk v.patch
Fri Dec 18 10:05:41 EST 2009
Author: martinl
Date: 2009-12-18 10:05:41 -0500 (Fri, 18 Dec 2009)
New Revision: 40046
   grass/trunk/vector/v.out.vtk/main.c
   grass/trunk/vector/v.patch/main.c
v.patch & v.out.vtk: more keywords, cosmetics
Modified: grass/trunk/vector/v.out.vtk/main.c
--- grass/trunk/vector/v.out.vtk/main.c	2009-12-18 15:04:47 UTC (rev 40045)
+++ grass/trunk/vector/v.out.vtk/main.c	2009-12-18 15:05:41 UTC (rev 40046)
@@ -45,8 +45,9 @@
     module = G_define_module();
     G_add_keyword(_("vector"));
+    G_add_keyword(_("export"));
     module->description =
-	_("Converts a GRASS binary vector map to VTK ASCII output.");
+	_("Converts a vector map to VTK ASCII output.");
     input = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.patch/main.c
--- grass/trunk/vector/v.patch/main.c	2009-12-18 15:04:47 UTC (rev 40045)
+++ grass/trunk/vector/v.patch/main.c	2009-12-18 15:05:41 UTC (rev 40046)
@@ -66,8 +66,9 @@
-    module->description = _("Create a new vector map layer "
-			    "by combining other vector map layers.");
+    G_add_keyword(_("geometry"));
+    module->description = _("Creates a new vector map "
+			    "by combining other vector maps.");
     old = G_define_standard_option(G_OPT_V_INPUTS);
@@ -359,7 +360,7 @@
     if (bbox_name) {
 	Vect_set_map_name(&BBoxMap, "Output from v.patch (bounding boxes)");
 	Vect_set_person(&BBoxMap, G_whoami());
-	G_important_message("");
+	G_important_message(" ");
 	G_important_message(_("Building topology for vector map <%s>..."),
 			    bbox_name);
 	Vect_build(&BBoxMap);
