[GRASS-SVN] r35259 - grass/branches/develbranch_6/gui/wxpython/xml
Wed Jan 7 09:35:16 EST 2009
Author: martinl
Date: 2009-01-07 09:35:16 -0500 (Wed, 07 Jan 2009)
New Revision: 35259
   grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
fix some typos from r35249 use original module description as help text
Modified: grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml
--- grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2009-01-07 14:32:20 UTC (rev 35258)
+++ grass/branches/develbranch_6/gui/wxpython/xml/menudata.xml	2009-01-07 14:35:16 UTC (rev 35259)
@@ -190,8 +190,8 @@
 	      <command>v.in.gpsbabel</command>
 	    </menuitem>
 	    <menuitem>
-	      <label>Geoames import</label>
-	      <help>Imports Geonames country files into a GRASS vector points map.</help>
+	      <label>Geonames import</label>
+	      <help>Imports geonames.org country files into a GRASS vector points map.</help>
 	      <handler>self.OnMenuCmd</handler>
 	      <command>v.in.geonames</command>
 	    </menuitem>
@@ -415,7 +415,7 @@
 	      <label>Multiple export formats using OGR</label>
 	      <help>Exports attribute tables in various formats.</help>
-	      <command>db.in.ogr</command>
+	      <command>db.out.ogr</command>
 	    </menuitem>
 	  </items>
 	</menu>
@@ -947,8 +947,8 @@
 	    </menuitem>
 	    <separator/>
 	    <menuitem>
-	      <label>Horizon</label>
-	      <help>Calculate horizon angle.</help>
+	      <label>Horizon angle</label>
+	      <help>Horizon angle computation from a digital elevation model.</help>
 	      <command>r.horizon</command>
 	    </menuitem>
@@ -1411,7 +1411,7 @@
 	    </menuitem>
 	    <menuitem>
 	      <label>Quantiles for large data sets</label>
-	      <help>Calculate quantiles from large data sets.</help>
+	      <help>Compute quantiles using two passes.</help>
 	      <command>r.quantile</command>
 	    </menuitem>
