[GRASS-SVN] r35260 - grass/branches/develbranch_6/gui/wxpython/gui_modules
Wed Jan 7 09:36:01 EST 2009
Author: martinl
Date: 2009-01-07 09:36:01 -0500 (Wed, 07 Jan 2009)
New Revision: 35260
   grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
wxGUI synchronized with trunk
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/colorrules.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -374,7 +374,7 @@
                                    map = self.inmap)
             if info:
-                for line in info.split('\n'):
+                for line in info.splitlines():
                     if 'min' in line:
                         self.rast['min'] = float(line.split('=')[1])
                     elif 'max' in line:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/dbm.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -1136,9 +1136,7 @@
                                          where = where)
                 region = {}
-                for line in select.split('\n'):
-                    if '=' not in line:
-                        continue
+                for line in select.splitlines():
                     key, value = line.split('=')
                     region[key.strip()] = float(value.strip())
@@ -2146,7 +2144,7 @@
                                   flags = 'p')
         self.listOfDrivers = []
-        for drv in drivers.split('\n'):
+        for drv in drivers.splitlines():
             self.listOfDrivers.append(drv.strip())
@@ -2158,9 +2156,7 @@
                                   read = True,
                                   quiet = True)
-        for line in connect.split('\n'):
-            if ':' not in line:
-                continue
+        for line in connect.splitlines():
             item, value = line.split(':')
             self.defaultConnect[item.strip()] = value.strip()
@@ -2573,9 +2569,8 @@
             return tables
-        for table in ret.split('\n'):
-            if len(table) > 0:
-                tables.append(table)
+        for table in ret.splitlines():
+            tables.append(table)
         return tables
@@ -2594,9 +2589,8 @@
         if ret == None:
             return columns
-        for column in ret.split('\n'):
-            if len(column) > 0:
-                columns.append(column)
+        for column in ret.splitlines():
+            columns.append(column)
         return columns
@@ -3361,10 +3355,7 @@
         data = {}
         if ret:
             readAttrb = False
-            for item in ret.split('\n'):
-                if len(item) < 1:
-                    continue
+            for item in ret.splitlines():
                 key, value = item.split(':', 1)
                 if key == 'Layer' and readAttrb:
@@ -3423,7 +3414,7 @@
         # self.tables[table][key][1] = str(cat)
         if ret:
-            for line in ret.split('\n'):
+            for line in ret.splitlines():
                 name, value = line.split('|')
                 # casting ...
                 if value:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/georect.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -1111,7 +1111,7 @@
         self.grwiz.SwitchEnv('original')
         if ret:
-            errlist = ret.split('\n')
+            errlist = ret.splitlines()
         if errlist == []:
             return
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -228,7 +228,7 @@
         p1 = self.cmd_output.GetEndStyled()
         self.cmd_output.GotoPos(p1)
-        for line in text.split('\n'):
+        for line in text.splitlines():
             # fill space
             if len(line) < self.lineWidth:
                 diff = 80 - len(line)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/gselect.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -488,9 +488,8 @@
                               database = database)
         if ret:
-                    items.append(table)
+                items.append(table)
         self.SetItems(items)
         self.SetValue('')
@@ -567,9 +566,8 @@
         columnchoices = []
         if ret:
-                if len(item) < 1:
-                    columnchoices.append(item)
+                columnchoices.append(item)
         # columnchoices.sort()
         self.SetItems(columnchoices)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/location_wizard.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -2035,7 +2035,7 @@
         dtoptions = {}
         if ret:
-            line = ret.split('\n')
+            line = ret.splitlines()
             i = 0
             while i < len(line):
                 if line[i] == '---':
@@ -2211,11 +2211,8 @@
         ret = gcmd.RunCommand('g.gisenv',
                               read = True)
         if ret:
-            output = ret.split('\n')
-            for line in output:
-                line = line.strip()
-                if '=' in line:
-                    key, val = line.split('=')
+                key, val = line.split('=')
                 envval[key] = val
             self.currlocation = envval['LOCATION_NAME'].strip("';")
             self.currmapset = envval['MAPSET'].strip("';")
@@ -2241,11 +2238,8 @@
                               read = True,
                               flags = 'gp3')
         if ret:
-                if '=' in line:
                 region[key] = float(val)
         else:
             dlg = wx.MessageBox(parent=self,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -2342,9 +2342,7 @@
             dlg.Destroy()
             return
-        for line in region.split('\n'):
-                continue
+        for line in region.splitlines():
             zoomreg[key.strip()] = float(val.strip())
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -2424,9 +2424,7 @@
             return
         npoints = nprimitives = 0
-        for line in vInfo.split('\n'):
-                continue
+        for line in vInfo.splitlines():
             if key == 'map3d':
                 mapIs3D = int(value)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/preferences.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -1689,7 +1689,7 @@
         if not ret:
             return fontlist
-        dfonts = ret.split('\n')
+        dfonts = ret.splitlines()
         dfonts.sort(lambda x,y: cmp(x.lower(), y.lower()))
         for item in range(len(dfonts)):
            # ignore duplicate fonts and those starting with #
@@ -1796,7 +1796,7 @@
         mapsets = []
         if ret:
-            mapsets = ret.split('\n')
+            mapsets = ret.splitlines()
         for mapset in mapsets:
             index = self.InsertStringItem(sys.maxint, mapset)
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/profile.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -289,7 +289,7 @@
                                   map = r['name'])
             if ret:
-                r['units'] = p.split('\n')[0].split('=')[1]
+                r['units'] = p.splitlines()[0].split('=')[1]
             # update title
             self.ptitle += ' %s and' % r['name']
@@ -325,9 +325,9 @@
                                       read = True,
                                       input = self.raster[0]['name'],
                                       east_north = '%d,%d' % (point[0],point[1]))
-                outlist = ret.split('\n')
-                val = outlist[0].split('|')[3]
+                val = ret.splitlines()[0].split('|')[3]
                 # calculate distance between coordinate points
                 if lasteast and lastnorth:
                     dist = math.sqrt(math.pow((lasteast-point[0]),2) + math.pow((lastnorth-point[1]),2))
@@ -413,15 +413,20 @@
         import subprocess
         try:
-            p = grass.read_command("r.profile",
-                       input=raster,
-                       profile=coords,
-                       null="nan",
-                       quiet=True
-            for outline in p.strip().split('\n'):
+            ret = RunCommand("r.profile",
+                             input=raster,
+                             profile=coords,
+                             null="nan",
+                             quiet=True,
+                             read = True)
+            if not ret:
+                return dataset
                 dist, elev = outline.split(' ')
-                if elev != 'nan': datalist.append((dist,elev))
+                if elev != 'nan':
+                    datalist.append((dist,elev))
             return datalist
         except gcmd.CmdError, e:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -746,7 +746,7 @@
         if not ret:
             return projinfo
             if ':' in line:
                 key,val = line.split(':')
                 key = key.strip()
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/utils.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -46,7 +46,7 @@
                           read = True,
                           pid = os.getpid())
-    tempfile = tempfileCmd.split('\n')[0].strip()
+    tempfile = tempfileCmd.splitlines()[0].strip()
     # FIXME
     # ugly hack for MSYS (MS Windows)
@@ -257,7 +257,7 @@
     if not ret:
         return layers
         if not 'Layer' in line:
             continue
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2009-01-07 14:35:16 UTC (rev 35259)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/vdigit.py	2009-01-07 14:36:01 UTC (rev 35260)
@@ -195,7 +195,7 @@
         if not ret:
             return ids
-        output = ret.split('\n')[0] # first line
+        output = ret.splitlines()[0] # first line
         ids = output.split(',')
         ids = map(int, ids) # str -> int
@@ -1991,7 +1991,7 @@
         if not ret:
             return False
             litem = item.lower()
             if "id:" in litem: # get line id
                 self.line = int(item.split(':')[1].strip())
