[GRASS-SVN] r38147 - grass-addons/vector/v.in.postgis.sqlquery
Wed Jul 1 12:56:48 EDT 2009
Author: mathieug
Date: 2009-07-01 12:56:48 -0400 (Wed, 01 Jul 2009)
New Revision: 38147
Added:
   grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py
beta python implementation + first unit test module
Added: grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py
--- grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py	                        (rev 0)
+++ grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py	2009-07-01 16:56:48 UTC (rev 38147)
@@ -0,0 +1,237 @@
+#!/usr/bin/python
+#-*- coding: utf-8 -*-
+# MODULE:       v_in_postgis_sqlquery_tests.py
+# AUTHOR(S):	Mathieu Grelier, 2009 (greliermathieu at gmail.com)
+# PURPOSE:		An attempt of a GRASS module unit test
+# COPYRIGHT:	(C) 2009 Mathieu Grelier
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+import sys
+import os
+##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
+from grass import core as grass
+##only needed to use debugger. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
+from dbgp.client import brk
+##see http://pyunit.sourceforge.net/
+import unittest
+##see http://initd.org/pub/software/psycopg/
+import psycopg2 as dbapi2
+importer = None
+db = None
+cursor = None
+host = None
+dbname = None
+user = None
+pwd = None
+testTableName = None
+queryTableName = None
+geometryField = None
+geoparams = None
+class v_in_postgis_sqlquery_tests(unittest.TestCase):
+    def setUp(self):
+        grass.run_command("db.connect", driver = 'pg', database = 'host=' + host + ",dbname=" + dbname)
+    def tearDown(self):
+        cleanUpQueryTable()
+    def testGetDbInfos(self):
+        Test if the importer is able to retrieve correctly the parameters dictionnary for current connection.
+        self.assertEqual(importer.dbparams['host'],host)
+        self.assertEqual(importer.dbparams['db'],dbname)
+        self.assertEqual(importer.dbparams['user'],user)
+        self.assertEqual(importer.dbparams['pwd'],pwd)
+    def testCheckLayers(self):
+        !Test if overwrite is working correctly
+        from v_in_postgis_sqlquery import GrassPostGisImporterError
+        os.environ['GRASS_OVERWRITE'] = '0'
+        createQueryTable()
+        importer.addGeometry(queryTableName, geometryField, geoparams, False)
+        importer.commitChanges()
+        importer.importToGrass(queryTableName, geometryField, geoparams, toDbf = False, overrideProj = True)
+        ##GRASS_OVERWRITE set to False, we can't import again the layer
+        self.assertRaises(GrassPostGisImporterError, importer.checkLayers, queryTableName)
+        ##now set to True, it should be possible
+        os.environ['GRASS_OVERWRITE'] = '1'
+        try:
+            importer.checkLayers(queryTableName)
+        except Exception:
+            self.fail("CheckLayers was expected to be successful with --o flag.")
+        pass
+    def testCheckComment(self):
+        !Test that we can't drop a table with the output name if it was not created by the importer.
+        ##a table that was not tagged by the importer should not be overwritten
+        self.assertRaises(GrassPostGisImporterError, importer.checkComment, testTableName)
+        pass
+    def testCreateTable(self):
+        pass
+    def testAddingCategoryWithPgDriverIsNecessary(self):
+        """!Test is the cat column addition is working and is still necessary with pg driver import
+        cat column is necessary for GRASS to store categories.
+        For now, the pg driver for v.in.ogr doesn't doesn't add automatically this
+        cat column, whereas the dbf driver does. So the importer has a specific addCategory()
+        method, which necessity is tested here.
+        ##starting with postgis to dbf import : no need to use the addCategory() method is expected
+        importer.importToGrass(queryTableName, geometryField, geoparams, toDbf = True, overrideProj = True)
+        cmd = importer.executeCommand("v.univar", map = queryTableName, column = 'value')
+        self.assertEqual(cmd['return_code'], 0)
+        ##now same operations with pg driver : error is expected when GRASS use the cat column.
+        importer.importToGrass(queryTableName, geometryField, geoparams, False, True)
+        self.assertNotEqual(cmd['return_code'], 0)
+        ##now same operations with pg driver, after adding category column
+        ##with the importer : error should not occur.
+        importer.addCategory(queryTableName)
+    def testGeometryDuplicationIsNecessary(self):
+        """!Test that we need to use the postGis' AddGeometryColumn function"""
+        self.assertRaises(GrassPostGisImporterError, importer.importToGrass, queryTableName, \
+                        geometryField, geoparams, False, True)
+        ##now addGeometry:
+        try:
+        except Exception:
+            self.fail("Both operations are for now expected to be necessary.")
+        pass
+def createQueryTable():
+    importer.createPostgresTableFromQuery(queryTableName, 'select * from ' + testTableName + ' where id=1')
+def cleanUpQueryTable():
+    db.rollback()
+    try:
+        importer.executeCommand("g.remove", vect = queryTableName, quiet = True)
+        cursor.execute('DROP TABLE ' + queryTableName)
+    except:
+        pass
+    try:
+        cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + queryTableName + "'")
+    except:
+        pass
+    db.commit()
+def cleanUp():
+    db.rollback()
+    try:
+        importer.executeCommand("g.remove", vect = testTableName, quiet = True)
+        cursor.execute('DROP TABLE ' + testTableName)
+    except:
+        pass
+    try:
+        cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + testTableName + "'")
+    except:
+        pass
+    db.commit()
+def suite():
+    alltests = unittest.TestSuite()
+    alltests.addTest(unittest.findTestCases(module))
+    return alltests
+if __name__ == '__main__':
+    ### DEBUG : uncomment to start local debugging session
+    #brk(host="localhost", port=9000)
+    currentDirectory = os.path.split(__file__)[0]
+    sys.path.append(currentDirectory)
+    ##test configuration
+    options = {'sqlquery':'', 'geometryfield':'', 'output':''}
+    flags = {'d':0, 'z':0, 'o':0, 'g':0, 'l':0}
+    importer = GrassPostGisImporter(options, flags)
+    module = __import__('v_in_postgis_sqlquery_tests')
+    host = 'localhost'
+    dbname = 'yourdb'
+    user = 'postgres'
+    pwd = 'yourpwd'
+    db = dbapi2.connect(host=host, database=dbname, user=user, password=pwd)
+    cursor = db.cursor()
+    testTableName = 'test_grass_import'
+    queryTableName = 'test_query'
+    geometryField = 'the_geom'
+    geoparams = {'type':'POLYGON', 'ndims':'2', 'srid':'-1'}
+    ##give access to test elements to module
+    module.importer = importer
+    module.db = db
+    module.cursor = cursor
+    module.host = host
+    module.dbname = dbname
+    module.user = user
+    module.pwd = pwd
+    module.testTableName = testTableName
+    module.queryTableName = queryTableName
+    module.geometryField = geometryField
+    module.geoparams = geoparams
+    ##test geo table
+    cursor.execute("CREATE TABLE " + testTableName + " ( id int4, label varchar(20), value real )")
+    cursor.execute("SELECT AddGeometryColumn('', '" + testTableName + "','" + geometryField + "',-1,'POLYGON',2)")
+    cursor.execute("INSERT INTO " + testTableName + " (id, label, value, " + geometryField + ") VALUES (1, 'A Geometry', 10, \
+                        GeomFromText('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))', -1))")
+    cursor.execute("INSERT INTO " + testTableName + " (id, label, value, " + geometryField + ") VALUES (2, 'Another Geometry', 20, \
+                        GeomFromText('POLYGON((0 0, 0 20, 20 20, 20 0, 0 0))', -1))")
+    cursor.execute("ALTER TABLE " + testTableName + " ADD CONSTRAINT test_pkey " + " PRIMARY KEY (id)")
+    db.commit()
+    os.environ['GRASS_VERBOSE'] = '0'
+    try:
+        unittest.main(defaultTest='suite')
+    finally:
+        module.cleanUp()
+        sys.exit(0)
Property changes on: grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery_tests.py
___________________________________________________________________
Added: svn:executable
