[GRASS-SVN] r38148 - grass-addons/vector/v.in.postgis.sqlquery
Wed Jul 1 12:57:07 EDT 2009
Author: mathieug
Date: 2009-07-01 12:57:07 -0400 (Wed, 01 Jul 2009)
New Revision: 38148
Added:
   grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery.py
beta python implementation + first unit test module
Added: grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery.py
--- grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery.py	                        (rev 0)
+++ grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery.py	2009-07-01 16:57:07 UTC (rev 38148)
@@ -0,0 +1,429 @@
+#!/usr/bin/python
+#-*- coding: utf-8 -*-
+# MODULE:       v_in_postgis_sqlquery
+# AUTHOR(S):	Mathieu Grelier, 2009 (greliermathieu at gmail.com)
+# PURPOSE:		postgis data manipulation in grass from arbitrary sql queries
+# COPYRIGHT:	(C) 2009 Mathieu Grelier
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#%  description: Create a grass layer from any sql query in postgis
+#%  keywords: postgis, grass layer, sql
+#%End
+#%option
+#% key: sqlquery
+#% type: string
+#% description: Any sql query returning a recordset with geometry for each row
+#% required : yes
+#%end
+#%option
+#% key: geometryfield
+#% type: string
+#% answer: the_geom
+#% description: Name of the source geometry field. Usually defaults to the_geom but needed if a geometry function was used (for example, centroid), or if the table has many geometry columns.
+#% required : yes
+#%end
+#%option
+#% key: output
+#% type: string
+#% answer: postgis_sqlquery
+#% description: Name of the geographic postgis table where to place the query results. Will be the name of the imported grass layer. If -d flag is set, this table is deleted and replaced by a dbf attribute table. Use a different name than the original. Do not use capital letters
+#% required : no
+#%end
+#%flag
+#% key: d
+#% description: Import result in grass dbf format (no new table in postgis). If not set, the grass layer will be directly connected to the postgis new table
+#%end
+#%flag
+#% key: o
+#% description: Use -o for v.in.ogr (override dataset projection)
+#%end
+#%flag
+#% key: g
+#% description: Add a gist index to the imported table in postgis (useless with the d flag)
+#%end
+#%flag
+#% key: l
+#% description: Log process info to v.in.postgis.sqlquery.py.log.
+#%end
+import sys
+import os
+import re
+from subprocess import Popen, PIPE
+import traceback
+##see http://initd.org/pub/software/psycopg/
+import psycopg2 as dbapi2
+##see http://trac.osgeo.org/grass/browser/grass/trunk/lib/python
+from grass import core as grass
+##only needed to use debugger. See http://aspn.activestate.com/ASPN/Downloads/Komodo/RemoteDebugging
+from dbgp.client import brk
+class GrassPostGisImporter():
+    def __init__(self, options, flags):
+        ##options
+        self.sqlquery = options['sqlquery']
+        self.geometryfield = options['geometryfield'] if options['geometryfield'].strip() != '' else 'the_geom'
+        self.output = options['output'] if options['output'].strip() != '' else 'postgis_import'
+        ##flags
+        self.dbfFlag = True if flags['d'] is True else False
+        self.overrideprojFlag = True if flags['o'] is True else False
+        self.gistindexFlag = True if flags['g'] is True else False
+        self.logOutput = True if flags['l'] is True else False
+        ##others
+        logfilename = 'v.in.postgis.sqlquery.py.log'
+        self.logfile = os.path.join(os.getenv('LOGDIR'),logfilename) if os.getenv('LOGDIR') else logfilename
+        grass.try_remove(self.logfile)
+        ##default for grass6 ; you may need to fix this path
+        self.grassloginfile = os.path.join(os.getenv('HOME'),'.grasslogin6')
+        ##retrieve connection parameters
+        self.dbparams = self.__getDbInfos()
+        ##set db connection
+        self.db = dbapi2.connect(host=self.dbparams['host'], database=self.dbparams['db'], \
+user=self.dbparams['user'], password=self.dbparams['pwd'])
+        self.cursor = self.db.cursor()
+        ## uncomment if not default
+        #dbapi2.paramstyle = 'pyformat'
+    def __execShellCommand(self, command, stderrRedirection=False, logFile=False):
+        """General purpose function, maybe should be added in some way to core.py """
+        if logFile is not False:
+            command = command + ' >> ' +  logFile
+        if stderrRedirection is True:
+            command = command + " 2>&1"
+        p = Popen(command, shell=True, stdout=PIPE)
+        retcode = p.wait()
+        com = p.communicate()
+        if retcode == 0:
+            return com[0]
+        else:
+            errorMessage = ''
+            for elem in com:
+                errorMessage += str(elem) + "\n"
+            raise GrassPostGisImporterError(errorMessage)
+    def __writeLog(self, log=''):
+        """Write the 'log' string to log file"""
+        if self.logfile is not None:
+            fileHandle = open(self.logfile, 'a')
+            log = log + '\n'
+            fileHandle.write(log)
+            fileHandle.close()
+    def __getDbInfos(self):
+        Create a dictionnary with all db params needed by v.in.ogr
+        try:
+            dbString = grass.parse_key_val(grass.read_command('db.connect', flags = 'p'), sep = ':')['database']
+            p = re.compile(',')
+            dbElems = p.split(dbString)
+            host = grass.parse_key_val(dbElems[0], sep = '=')['host']
+            db = grass.parse_key_val(dbElems[1], sep = '=')['dbname']
+            loginLine = self.__execShellCommand('sed -n "/pg ' + dbElems[0] + ',' + dbElems[1] + ' /p" ' + self.grassloginfile)
+            p = re.compile(' ')
+            loginElems = p.split(loginLine)
+            user = loginElems[-2].strip()
+            password = loginElems[-1].strip()
+            dbParamsDict = {'host':host, 'db':db, 'user':user, 'pwd':password}
+            return dbParamsDict
+        except:
+            raise GrassPostGisImporterError("Error while trying to retrieve database information.")
+    def printMessage(self, message, type = 'info'):
+        if type == 'error':
+            grass.error(message)
+        elif type == 'warning':
+            grass.warning(message)
+        elif type == 'info' and grass.gisenv()['GRASS_VERBOSE'] > 0:
+            grass.info(message)
+        if self.logOutput is True:
+            self.__writeLog(message)
+    def executeCommand(self, *args, **kwargs):
+        kwargs['stdout'] = PIPE
+        kwargs['stderr'] = PIPE
+        ps = grass.start_command(*args, **kwargs)
+        retcode = ps.wait()
+        log = ''
+        for item in ps.communicate():
+            log = log + item + '\n'
+            self.__writeLog(log)
+        result = {'return_code':retcode, 'output':log}
+        return result
+    def checkLayers(self, output):
+        !Preliminary checks before starting import.
+        Note : for this to work with grass6.3, in find_file function from core.py,
+        command should be (n flag removed because 6.4 specific):
+        s = read_command("g.findfile", element = element, file = name, mapset = mapset)
+        self.printMessage("Check layers:")
+        ##Test if output vector map already exists.
+        testOutput = grass.find_file(output, element = 'vector')
+        if testOutput['fullname'] != '':
+            if not grass.overwrite() is True:
+                raise GrassPostGisImporterError("Vector map " + output + " already exists in mapset search path. \
+#Use the --o flag to overwrite.")
+            else:
+                self.printMessage("Vector map " + output + " will be overwritten.", type = 'warning')
+        return True
+    def checkComment(self, output):
+        ##Previous script execution may have not removed temporary elements
+        ##test if a table with the 'output' name already exists in PostGis.
+        ##If so, was it created by this script ? If so, delete it.
+        testIfTableNameAlreadyExistsQuery = "SELECT CAST(tablename AS text) FROM pg_tables \
+                                            WHERE schemaname='public' \
+                                            AND CAST(tablename AS text)='" + output + "'"
+        self.cursor.execute(testIfTableNameAlreadyExistsQuery)
+        rows = self.cursor.fetchone()
+        if rows is not None and len(rows) > 0:
+            testCheckCommentQuery = "SELECT obj_description((SELECT c.oid FROM pg_catalog.pg_class c \
+                                    WHERE c.relname='" + output + "'), 'pg_class') AS comment"
+            self.cursor.execute(testCheckCommentQuery)
+            comment = self.cursor.fetchone()
+            if comment is not None and len(comment) == 1:
+                comment = comment[0]
+            if comment == "created_with_v_in_postgis_sqlquery.py":
+                self.cursor.execute("DROP TABLE " + output)
+            else:
+                raise GrassPostGisImporterError("ERROR: a table with the name " + output + " already exists \
+                                                and was not created by this script.")
+        return True
+    def createPostgresTableFromQuery(self, output, sqlquery):
+        Create a table in postgresql populated with results from the sql query, and comment it so we
+        will later be able to figure out if this table was created by this script (see checkLayers())
+        try:
+            createTableQuery = "CREATE TABLE " + str(output) + " AS " + str(sqlquery)
+                self.__writeLog("Try to import data:")
+                self.__writeLog(createTableQuery)
+            self.cursor.execute(createTableQuery)
+            addCommentQuery = "COMMENT ON TABLE " + output + " IS 'created_with_v_in_postgis_sqlquery.py'"
+            self.cursor.execute(addCommentQuery)
+        except:
+            raise GrassPostGisImporterError("An error occurred during sql import. Check your connection \
+                                            to the database and your sql query.")
+    def addCategory(self, output):
+        !Add a category column in the result table
+        With the pg driver (not the dbf one), v.in.ogr need a 'cat' column for index creation
+        if -d flag wasn't not selected, can't import if query result already have a cat column
+        todo : add cat_ column in this case, as v.in.ogr with dbf driver do
+        try:
+            self.printMessage("Adding category column.")
+            s = "ALTER TABLE " + str(output) + " ADD COLUMN cat serial NOT NULL"
+            self.cursor.execute("ALTER TABLE " + str(output) + " ADD COLUMN cat serial NOT NULL")
+            tmp_pkey_name = "tmp_pkey_" + str(output)
+            self.cursor.execute("ALTER TABLE " + str(output) + " ADD CONSTRAINT " \
+            + tmp_pkey_name + " PRIMARY KEY (cat)")
+        except:
+            raise GrassPostGisImporterError("Unable to add a 'cat' column. A column named 'CAT' \
+                                            or 'cat' may be present in your input data. \
+                                            This column is reserved for Grass to store categories.")
+    def getGeometryInfo(self, output, geometryfield):
+        !Retrieve geometry parameters of the result
+        We need to use the postgis AddGeometryColumn function so that v.in.ogr will work.
+        This method aims to retrieve necessary info for AddGeometryColumn to work.
+        Returns a dict with
+        self.printMessage("Retrieving geometry info.")
+        ##if there is more than one geometry type in the query result table, we use the
+        ##generic GEOMETRY type
+        type="GEOMETRY"
+        self.cursor.execute("SELECT DISTINCT GeometryType(" + geometryfield + ") FROM " + output)
+        rows = self.cursor.fetchall()
+        if rows is not None and len(rows) == 1:
+            type = str(rows[0][0])
+        if rows is None or len(rows) == 0:
+            raise GrassPostGisImporterError("Unable to retrieve geometry type")
+        ##same thing with number of dimensions. If the query is syntactically correct but returns
+        ##no geometry, this step will cause an error.
+        ndims = 0
+        self.cursor.execute("SELECT DISTINCT ndims(" + geometryfield + ") FROM " + output)
+            ndims = str(rows[0][0])
+                self.__writeLog("ndims=" + ndims)
+        else:
+            raise GrassPostGisImporterError("unable to retrieve a unique coordinates dimension for \
+                                            this query or no geometry is present. Check your sql query.")
+        ##srid
+        srid="-1"
+        self.cursor.execute("SELECT DISTINCT srid(" + geometryfield + ") FROM " + output)
+        if rows is not None and len(rows[0]) == 1:
+            srid = str(rows[0][0])
+                self.__writeLog("srid=" + srid)
+        elif rows is not None and len(rows[0]) > 1:
+                self.__writeLog("Unable to retrieve a unique geometry srid for this query. \
+                             Using undefined srid.")
+        else:
+            raise GrassPostGisImporterError("Unable to retrieve geometry parameters.")
+        geoParamsDict = {'type':type, 'ndims':ndims, 'srid':srid}
+        return geoParamsDict
+    def addGeometry(self, output, geometryField, geoParams, addGistIndex=False):
+        """!Create geometry for result"""
+        try:
+            ##first we must remove other geometry columns than selected one that may be present in the query result,
+            ##because v.in.ogr does not allow geometry columns selection
+            ##v.in.ogr takes the first geometry column found in the table so if another geometry is present,
+            ##as we use AddGeometryColumn fonction to copy selected geometry (see below), our geometry will
+            ##appear after other geometries in the column list. In this case, v.in.ogr would not import the
+            ##right geometry.
+            self.printMessage("Checking for other geometries.")
+            self.cursor.execute("SELECT column_name FROM(SELECT ordinal_position, column_name, udt_name \
+                                FROM INFORMATION_SCHEMA.COLUMNS \
+                                WHERE (TABLE_NAME='" + output + "') ORDER BY ordinal_position) AS info \
+                                WHERE udt_name='geometry' AND NOT column_name='" + geometryField + "'")
+            if rows is not None and len(rows) >= 1:
+                for otherGeoColumn in rows:
+                        self.__writeLog("Found another geometry in the query result than selected one: "\
+                                        + str(otherGeoColumn) + ". Column will be dropped.")
+                    self.cursor.execute("ALTER TABLE " + output + " DROP COLUMN " + otherGeoColumn)
+            ##we already inserted the geometry so we will recopy it in the newly created geometry column
+                self.__writeLog("Create geometry column.")
+            self.cursor.execute("ALTER TABLE " + output + " RENAME COLUMN " + geometryField + " TO the_geom_tmp")
+            self.cursor.execute("SELECT AddGeometryColumn('', '" + output + "','" + geometryField + "',\
+                                "+ geoParams['srid'] + ",'" + geoParams['type'] + "'," + geoParams['ndims'] + ");")
+            self.cursor.execute("UPDATE " + output + " SET " + geometryField + " = the_geom_tmp")
+            self.cursor.execute("ALTER TABLE " + output + " DROP COLUMN  the_geom_tmp")
+            if addGistIndex is True:
+                self.cursor.execute("CREATE INDEX " + output + "_index ON " + output + " \
+                                    USING GIST (" + geometryField + " GIST_GEOMETRY_OPS);")
+        except:
+            raise GrassPostGisImporterError("An error occured during geometry insertion.")
+    def importToGrass(self, output, geometryField, geoParams, toDbf = False, overrideProj = False):
+        """!Wrapper for import and db connection of the result
+        Note : for grass.gisenv() to work with grass6.3, in gisenv function from core.py,
+        ##dbf driver
+        flags = ''
+        outputname = output
+        if toDbf is True:
+            #we need
+            #outputname="tmpoutput"
+            env = grass.gisenv()
+            dbfFolderPath = os.path.join(env['GISDBASE'].strip(";'"), env['LOCATION_NAME'].strip(";'"), \
+                                         env['MAPSET'].strip(";'"), 'dbf')
+            if not os.path.exists(dbfFolderPath):
+                os.mkdir(dbfFolderPath)
+            grass.run_command("db.connect", driver = 'dbf', database = dbfFolderPath)
+        else:
+            flags += 't'
+        if overrideProj is True:
+            flags += 'o'
+        ##finally call v.in.ogr
+        self.printMessage("call v.in.ogr...")
+        dsn="PG:host=" + self.dbparams['host'] + " dbname=" + self.dbparams['db'] \
+        + " user=" + self.dbparams['user'] + " password=" + self.dbparams['pwd']
+        layername = output
+        cmd = self.executeCommand("v.in.ogr", dsn = dsn, output = outputname, layer = layername, \
+                          flags = flags, overwrite=True, quiet = False)
+        if cmd['return_code'] != 0:
+            raise GrassPostGisImporterError("v.in.ogr error:\n" + cmd['output'])
+        ##if we import to grass dbf format, we must rename the dbf layer to match the given output name
+        if toDbf is True:
+            grass.run_command("db.connect", driver = 'pg', database = 'host=' + self.dbparams['host'] + \
+                              ",dbname=" + self.dbparams['db'])
+            self.cursor.execute('DROP TABLE ' + output)
+        ##else we work directly with postgis so the connection between imported grass layer
+        ##and postgres attribute table must be explicit
+        else:
+            ##can cause segfaults if mapset name is too long:
+            cmd = self.executeCommand("v.db.connect", map = output, table = output, flags = 'o')
+                raise GrassPostGisImporterError("v.db.connect error:\n" + cmd['output'])
+        ##delete temporary data in geometry_columns table
+        self.cursor.execute("DELETE FROM geometry_columns WHERE f_table_name = '" + output + "'")
+        pass
+    def commitChanges(self):
+        """!Commit current transaction"""
+        self.db.commit()
+    def makeSqlImport(self):
+        """!GrassPostGisImporter main sequence"""
+        ##1)check layers before starting
+        self.checkLayers(self.output)
+        ##2)query
+        self.createPostgresTableFromQuery(self.output, self.sqlquery)
+        ##3)cats
+        if self.dbfFlag is False:
+            self.addCategory(self.output)
+        ##4)geometry parameters
+        geoparams = self.getGeometryInfo(self.output, self.geometryfield)
+        ##5)new geometry
+        self.addGeometry(self.output, self.geometryfield, geoparams, self.gistindexFlag)
+        self.commitChanges()
+        ##6)v.in.ogr
+        self.importToGrass(self.output, self.geometryfield, geoparams, toDbf = self.dbfFlag, \
+                           overrideProj = self.overrideprojFlag)
+        ##7)post-import operations
+class GrassPostGisImporterError(Exception):
+    """Errors specific to GrassPostGisImporter class"""
+    def __init__(self, message=''):
+        self.details = '\nDetails:\n'
+        exceptionType, exceptionValue, exceptionTraceback = sys.exc_info()
+        self.details += repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
+        self.message = message + "\n" + self.details
+def main():
+    exitStatus = 0
+    try:
+        postgisImporter = GrassPostGisImporter(options, flags)
+        postgisImporter.makeSqlImport()
+    except GrassPostGisImporterError, e1:
+        postgisImporter.printMessage(e1.message, type = 'error')
+        exitStatus = 1
+    except:
+        errorMessage = "Unexpected error \n:" + \
+                       repr(traceback.format_exception(exceptionType, exceptionValue, exceptionTraceback))
+        postgisImporter.printMessage(errorMessage, type = 'error')
+        exitStatus = 1
+    else:
+        postgisImporter.printMessage("Done", type = 'info')
+    finally:
+        sys.exit(exitStatus)
+if __name__ == "__main__":
+    ### DEBUG : uncomment to start local debugging session
+    #brk(host="localhost", port=9000)
+    options, flags = grass.parser()
+    main()
Property changes on: grass-addons/vector/v.in.postgis.sqlquery/v_in_postgis_sqlquery.py
___________________________________________________________________
Added: svn:executable
