[GRASS-SVN] r36465 - grass/trunk/include/vect
Tue Mar 24 05:37:30 EDT 2009
Author: mmetz
Date: 2009-03-24 05:37:29 -0400 (Tue, 24 Mar 2009)
New Revision: 36465
Added:
   grass/trunk/include/vect/rbtree.h
header for new binary search tree
Added: grass/trunk/include/vect/rbtree.h
--- grass/trunk/include/vect/rbtree.h	                        (rev 0)
+++ grass/trunk/include/vect/rbtree.h	2009-03-24 09:37:29 UTC (rev 36465)
@@ -0,0 +1,96 @@
+ *                          USAGE
+ * NOTE: duplicates are not supported
+ * custom compare function
+ * extern int my_compare_fn(const void *, const void *);
+ * int my_compare_fn(const void *a, const void *b) {
+ *    if ((mydatastruct *) a > (mydatastruct *) b)
+ *      return 0;
+ *    else if ((mydatastruct *) a < (mydatastruct *) b)
+ *      return 1;
+ *    else if ((mydatastruct *) a == (mydatastruct *) b)
+ *      return 2;
+ * create and initialize tree:
+ * struct RB_TREE *mytree = rbtree_create(my_compare_fn, item_size);
+ * insert items to tree:
+ * struct mydatastruct data = <some data>;
+ * if (rbtree_insert(&mytree, &data) == 0)
+ * 	G_warning("could not insert data");
+ * find item in tree:
+ * if (rbtree_find(&mytree, &data) == 0)
+ * 	G_message("data not found");
+ * delete item from tree:
+ * if (rbtree_remove(&mytree, &data) == 0)
+ * 	G_warning("could not find data in tree");
+ * traverse tree (get all items in tree in ascending order):
+ * struct RB_TRAV trav;
+ * rbtree_init_trav(&trav, tree);
+ * while ((data = rbtree_traverse(&trav)) != NULL) {
+ *	if (my_compare_fn(data, threshold_data) == 0) break;
+ * 	<do something with data>;
+ * destroy tree:
+ * rbtree_destroy(mytree);
+/* structures and functions needed for Red Black Tree */
+#include <stddef.h>
+/* maximum RB Tree height */
+#define RBTREE_MAX_HEIGHT 64 /* allow 2^64 items */
+/* routine to compare data items */
+/* return 0 if rb_a > rb_b */
+/* return 1 if rb_a < rb_b */
+/* return 2 if rb_a == rb_b */
+typedef int rb_compare_fn(const void *rb_a, const void *rb_b);
+struct RB_NODE
+    unsigned char red;
+    void *data;
+    struct RB_NODE *link[2];
+struct RB_TREE
+    struct RB_NODE *root;
+    size_t datasize;                /* item size */
+    size_t count;                   /* Number of items in tree. */
+    rb_compare_fn *rb_compare;
+struct RB_TRAV
+    struct RB_TREE *tree;       /* tree being traversed */
+    struct RB_NODE *curr_node;
+    struct RB_NODE *up[RBTREE_MAX_HEIGHT];
+    int top;
+    int first;
+/* rbtree.c */
+struct RB_TREE *rbtree_create(rb_compare_fn *, size_t);
+int rbtree_insert(struct RB_TREE *, void *);
+void *rbtree_find(struct RB_TREE *, const void *);
+int rbtree_remove(struct RB_TREE *, const void *);
+void rbtree_init_trav(struct RB_TRAV *, struct RB_TREE *);
+void* rbtree_traverse(struct RB_TRAV *);
+void rbtree_destroy(struct RB_TREE *);
+int rbtree_debug(struct RB_TREE *, struct RB_NODE *);
