[GRASS-SVN] r36466 - in grass/trunk/lib/vector: Vlib diglib
Tue Mar 24 05:39:27 EDT 2009
Author: mmetz
Date: 2009-03-24 05:39:25 -0400 (Tue, 24 Mar 2009)
New Revision: 36466
Added:
   grass/trunk/lib/vector/diglib/rbtree.c
   grass/trunk/lib/vector/Vlib/break_polygons.c
   grass/trunk/lib/vector/diglib/poly.c
new binary search tree, faster and lighter Vect_break_polygons
Modified: grass/trunk/lib/vector/Vlib/break_polygons.c
--- grass/trunk/lib/vector/Vlib/break_polygons.c	2009-03-24 09:37:29 UTC (rev 36465)
+++ grass/trunk/lib/vector/Vlib/break_polygons.c	2009-03-24 09:39:25 UTC (rev 36466)
@@ -5,14 +5,14 @@
    Higher level functions for reading/writing/manipulating vectors.
-   (C) 2001-2008 by the GRASS Development Team
+   (C) 2001-2009 by the GRASS Development Team
    This program is free software under the
    GNU General Public License (>=v2).
    Read the file COPYING that comes with GRASS
    for details.
-   \author Radim Blazek
+   \author Radim Blazek, update for GRASS 7 Markus Metz
    \date 2001-2008
@@ -21,6 +21,7 @@
 #include <math.h>
 #include <grass/gis.h>
 #include <grass/Vect.h>
+#include <grass/vect/rbtree.h>
 #include <grass/glocale.h>
 /* TODO: 3D support
@@ -52,16 +53,36 @@
 typedef struct
+    double x, y;		/* coords */
     double a1, a2;		/* angles */
     char cross;			/* 0 - do not break, 1 - break */
 } XPNT;
-static int fpoint;
+/* function used by binary tree to compare items */
+extern int compare_xpnts(const void *Xpnta, const void *Xpntb);
-/* Function called from RTreeSearch for point found */
-void srch(int id, int *arg)
+int compare_xpnts(const void *Xpnta, const void *Xpntb)
-    fpoint = id;
+    XPNT *a, *b;
+    a = (XPNT *)Xpnta;
+    b = (XPNT *)Xpntb;
+    if (a->x > b->x)
+	return 0;
+    else if (a->x < b->x)
+	return 1;
+    else {
+	if (a->y > b->y)
+	    return 0;
+	else if (a->y < b->y)
+	    return 1;
+	else
+	    return 2;
+    G_warning("Break polygons: Bug in binary tree!");
+    return 1;
@@ -81,6 +102,7 @@
    \return
 void
 Vect_break_polygons(struct Map_info *Map, int type, struct Map_info *Err)
@@ -88,14 +110,13 @@
     struct line_cats *Cats, *ErrCats;
     int i, j, k, ret, ltype, broken, last, nlines;
     int nbreaks;
-    struct Node *RTree;
+    struct RB_TREE *RBTree;
     int apoints, npoints, nallpoints, nmarks;
-    XPNT *XPnts;
-    struct Rect rect;
+    XPNT *XPnt_found, XPnt_search;
     double dx, dy, a1 = 0, a2 = 0;
     int closed, last_point, cross;
-    RTree = RTreeNewIndex();
+    RBTree = rbtree_create(compare_xpnts, sizeof(XPNT));
     BPoints = Vect_new_line_struct();
@@ -112,7 +133,6 @@
     nmarks = 0;
     npoints = 1;		/* index starts from 1 ! */
     nallpoints = 0;
-    XPnts = NULL;
     for (i = 1; i <= nlines; i++) {
 	G_percent(i, nlines, 1);
@@ -145,18 +165,11 @@
 	    if (j == last_point && closed)
 		continue;	/* do not register last of close polygon */
-	    /* Box */
-	    rect.boundary[0] = Points->x[j];
-	    rect.boundary[3] = Points->x[j];
-	    rect.boundary[1] = Points->y[j];
-	    rect.boundary[4] = Points->y[j];
-	    rect.boundary[2] = 0;
-	    rect.boundary[5] = 0;
+	    XPnt_search.x = Points->x[j];
+	    XPnt_search.y = Points->y[j];
 	    /* Already in DB? */
-	    fpoint = -1;
-	    RTreeSearch(RTree, &rect, (void *)srch, 0);
-	    G_debug(3, "fpoint =  %d", fpoint);
+	    XPnt_found = rbtree_find(RBTree, &XPnt_search);
 	    if (Points->n_points <= 2 ||
 		(!closed && (j == 0 || j == last_point))) {
@@ -182,48 +195,43 @@
-	    if (fpoint > 0) {	/* Found */
-		if (XPnts[fpoint].cross == 1)
+	    if (XPnt_found) {	/* found */
+		if (XPnt_found->cross == 1)
 		    continue;	/* already marked */
-		/* Check angles */
+		/* check angles */
 		if (cross) {
-		    XPnts[fpoint].cross = 1;
+		    XPnt_found->cross = 1;
 		    nmarks++;
 		else {
 		    G_debug(3, "a1 = %f xa1 = %f a2 = %f xa2 = %f", a1,
-			    XPnts[fpoint].a1, a2, XPnts[fpoint].a2);
-		    if ((a1 == XPnts[fpoint].a1 && a2 == XPnts[fpoint].a2) || (a1 == XPnts[fpoint].a2 && a2 == XPnts[fpoint].a1)) {	/* identical */
+			    XPnt_found->a1, a2, XPnt_found->a2);
+		    if ((a1 == XPnt_found->a1 && a2 == XPnt_found->a2) ||
+		        (a1 == XPnt_found->a2 && a2 == XPnt_found->a1)) {	/* identical */
 		    else {
 			nmarks++;
 	    else {
-		/* Add to tree and to structure */
-		RTreeInsertRect(&rect, npoints, &RTree, 0);
-		if (npoints >= apoints) {
-		    apoints += 10000;
-		    XPnts =
-			(XPNT *) G_realloc(XPnts,
-					   (apoints + 1) * sizeof(XPNT));
 		if (j == 0 || j == (Points->n_points - 1) ||
 		    Points->n_points < 3) {
-		    XPnts[npoints].a1 = 0;
-		    XPnts[npoints].a2 = 0;
-		    XPnts[npoints].cross = 1;
+		    XPnt_search.a1 = 0;
+		    XPnt_search.a2 = 0;
+		    XPnt_search.cross = 1;
 		    nmarks++;
 		else {
-		    XPnts[npoints].a1 = a1;
-		    XPnts[npoints].a2 = a2;
-		    XPnts[npoints].cross = 0;
+		    XPnt_search.a1 = a1;
+		    XPnt_search.a2 = a2;
+		    XPnt_search.cross = 0;
+		/* Add to tree */
+		rbtree_insert(RBTree, &XPnt_search);
 		npoints++;
@@ -235,6 +243,10 @@
     nbreaks = 0;
     nallpoints = 0;
+    /* uncomment to check if search tree is healthy */
+    /* if (rbtree_debug(RBTree, RBTree->root) == 0)
+	G_warning("Break polygons: RBTree not ok"); */
     /* Second loop through lines (existing when loop is started, no need to process lines written again)
      * and break at points marked for break */
@@ -262,26 +274,24 @@
 	    G_debug(3, "j =  %d", j);
 	    nallpoints++;
-	    /* Box */
 	    if (Points->n_points <= 1 ||
 		(j == (Points->n_points - 1) && !broken))
 		break;
 	    /* One point only or
 	     * last point and line is not broken, do nothing */
+	    /* all points must be in the search tree, without duplicates */
+	    if (XPnt_found == NULL)
+		G_fatal_error(_("Point not in search tree!"));
 	    /* break or write last segment of broken line */
 	    if ((j == (Points->n_points - 1) && broken) ||
-		XPnts[fpoint].cross) {
+		XPnt_found->cross) {
 		Vect_reset_line(BPoints);
 		for (k = last; k <= j; k++) {
 		    Vect_append_point(BPoints, Points->x[k], Points->y[k],
@@ -330,7 +340,6 @@
-    G_free(XPnts);
-    RTreeDestroyNode(RTree);
-    G_verbose_message("Breaks: %d", nbreaks);
+    rbtree_destroy(RBTree);
+    G_verbose_message(_("Breaks: %d"), nbreaks);
Modified: grass/trunk/lib/vector/diglib/poly.c
--- grass/trunk/lib/vector/diglib/poly.c	2009-03-24 09:37:29 UTC (rev 36465)
+++ grass/trunk/lib/vector/diglib/poly.c	2009-03-24 09:39:25 UTC (rev 36466)
@@ -99,7 +99,8 @@
     double *x, *y;
     double tot_area;
-    /* prune first with Vect_line_prune(Points) for speed? */
+    /* TODO: check if results are still accurate without pruning *Points first
+     * consecutive duplicate vertices should in theory result in wrong area size */
     x = Points->x;
     y = Points->y;
Added: grass/trunk/lib/vector/diglib/rbtree.c
--- grass/trunk/lib/vector/diglib/rbtree.c	                        (rev 0)
+++ grass/trunk/lib/vector/diglib/rbtree.c	2009-03-24 09:39:25 UTC (rev 36466)
@@ -0,0 +1,488 @@
+ * MODULE:       Vector library
+ * AUTHOR(S):    Markus Metz
+ * PURPOSE:      Lower level functions for reading/writing/manipulating vectors.
+ * COPYRIGHT:    (C) 2009 by the GRASS Development Team
+ *               This program is free software under the GNU General Public
+ *               License (>=v2). Read the file COPYING that comes with GRASS
+ *               for details.
+/* balanced binary search tree implementation
+ * this one is a Red Black Tree, the bare version, no parent pointers, no threads
+ * The core code comes from Julienne Walker's tutorials on
+ * binary search trees: insert, remove, balance
+ * support for any kind of data structures comes from libavl (GPL >= 2)
+ * I could have used some off-the-shelf solution, but that's boring
+ * Red Black Trees are used to maintain a data structure that allows
+ * search, insertion and deletion in O(log N) time
+ * This is needed for large vectors with many features
+#include <assert.h>
+#include <stdio.h>
+#include <stdlib.h>
+#include <string.h>
+#include <grass/gis.h>
+#include <grass/glocale.h>
+/* internal functions */
+void rbtree_destroy2(struct RB_NODE *);
+struct RB_NODE *rbtree_single(struct RB_NODE *, int);
+struct RB_NODE *rbtree_double(struct RB_NODE *, int);
+void *rbtree_first(struct RB_TRAV *);
+void *rbtree_next(struct RB_TRAV *);
+struct RB_NODE *rbtree_make_node(size_t, void *);
+int is_red(struct RB_NODE *);
+/* create new tree and initialize
+ * return pointer to new tree or NULL for memory allocation error
+struct RB_TREE *rbtree_create(rb_compare_fn *compare, size_t rb_datasize)
+    struct RB_TREE *tree = malloc(sizeof(*tree));
+    if (tree == NULL) {
+	G_warning("RB Search Tree: Out of memory!");
+	return NULL;
+    tree->datasize = rb_datasize;
+    tree->rb_compare = compare;
+    tree->count = 0;
+    tree->root = NULL;
+    return tree;
+/* add an item to a tree
+ * returns 1 on success, 0 on failure
+ * non-recursive top-down insertion
+ * the algorithm does not allow duplicates and also does not warn about a duplicate
+int rbtree_insert(struct RB_TREE *tree, void *data)
+    if (tree->root == NULL) {
+	/* create a new root node for tree */
+	tree->root = rbtree_make_node(tree->datasize, data);
+	    return 0;
+    else {
+	struct RB_NODE head = {0}; /* False tree root */
+	struct RB_NODE *g, *t;     /* Grandparent & parent */
+	struct RB_NODE *p, *q;     /* Iterator & parent */
+	int dir = 0, last = 0;
+	/* Set up helpers */
+	t = &head;
+	g = p = NULL;
+	q = t->link[1] = tree->root;
+	/* Search down the tree */
+	for ( ; ; ) {
+	    if (q == NULL) {
+		/* Insert new node at the bottom */
+		p->link[dir] = q = rbtree_make_node(tree->datasize, data);
+		if (q == NULL)
+		    return 0;
+	    else if (is_red(q->link[0]) && is_red(q->link[1])) {
+		/* Color flip */
+		q->red = 1;
+		q->link[0]->red = 0;
+		q->link[1]->red = 0;
+	    /* Fix red violation */
+	    if (is_red(q) && is_red(p)) {
+		int dir2 = t->link[1] == g;
+		if (q == p->link[last])
+		    t->link[dir2] = rbtree_single(g, !last);
+		else
+		    t->link[dir2] = rbtree_double(g, !last);
+	    last = dir;
+	    dir = tree->rb_compare(q->data, data);
+	    /* Stop if found */
+	    if (dir == 2)
+		break;
+	    /* Update helpers */
+	    if (g != NULL)
+		t = g;
+	    g = p, p = q;
+	    q = q->link[dir];
+	/* Update root */
+	tree->root = head.link[1];
+    /* Make root black */
+    tree->root->red = 0;
+    tree->count++;
+    return 1;
+/* delete an item from a tree
+ * returns 1 on successful deletion
+ * returns 0 if data item was not found
+ * non-recursive top-down deletion
+int rbtree_remove(struct RB_TREE *tree, const void *data)
+    struct RB_NODE *q, *p, *g; /* Helpers */
+    struct RB_NODE *f = NULL;  /* Found item */
+    int dir = 1, found = 0;
+	return 0; /* empty tree, nothing to remove */
+    q = &head;
+    g = p = NULL;
+    q->link[1] = tree->root;
+    /* Search and push a red down */
+    while (q->link[dir] != NULL) {
+	int last = dir;
+	g = p, p = q;
+	q = q->link[dir];
+	/* Save found node */
+	if (dir == 2) {
+	    f = q;
+	    dir = 0;
+	/* Push the red node down */
+	if (!is_red(q) && !is_red(q->link[dir])) {
+	    if (is_red(q->link[!dir]))
+		p = p->link[last] = rbtree_single(q, dir);
+	    else if (!is_red(q->link[!dir])) {
+		struct RB_NODE *s = p->link[!last];
+		if (s != NULL) {
+		    if (!is_red(s->link[!last]) &&
+		        !is_red(s->link[last])) {
+			/* Color flip */
+			p->red = 0;
+			s->red = 1;
+			q->red = 1;
+		    else {
+			int dir2 = g->link[1] == p;
+			if (is_red(s->link[last]))
+			    g->link[dir2] = rbtree_double(p, last);
+			else if (is_red(s->link[!last]))
+			    g->link[dir2] = rbtree_single(p, last);
+			/* Ensure correct coloring */
+			q->red = g->link[dir2]->red = 1;
+			g->link[dir2]->link[0]->red = 0;
+			g->link[dir2]->link[1]->red = 0;
+    /* Replace and remove if found */
+    if (f != NULL) {
+	p->link[p->link[1] == q] = q->link[q->link[0] == NULL];
+	free(q->data);
+	free(q);
+	tree->count--;
+	found = 1;
+    else
+	G_debug(2, "data not found in search tree");
+    /* Update root and make it black */
+    if ( tree->root != NULL)
+    return found;
+/* find data item in tree
+ * return pointer to data item if found else NULL
+void *rbtree_find(struct RB_TREE *tree, const void *data)
+    struct RB_NODE *curr_node = tree->root;
+    int dir = 0;
+    assert(tree && data);
+    while (curr_node != NULL) {
+	dir = tree->rb_compare(curr_node->data, data);
+	if (dir == 2)
+	    return curr_node->data;
+	else {
+	    curr_node = curr_node->link[dir];
+    return NULL;
+/* initialize tree traversal
+ * (re-)sets trav structure
+ * return pointer to trav struct or NULL on memory allocation error
+void rbtree_init_trav(struct RB_TRAV *trav, struct RB_TREE *tree)
+    int i;
+    assert(trav && tree);
+    trav->tree = tree;
+    trav->curr_node = tree->root;
+    trav->first = 1;
+    for (i = 0; i < RBTREE_MAX_HEIGHT; i++)
+	trav->up[i] = NULL;
+/* traverse the tree in ascending order
+ * useful to get all items in the tree non-recursively
+ * struct RB_TRAV *trav needs to be initialized first
+void *rbtree_traverse(struct RB_TRAV *trav)
+    assert(trav);
+    if (trav->curr_node == NULL) {
+	if (trav->first)
+	    G_warning("empty tree");
+	else
+	    G_warning("finished traversing");
+	return NULL;
+    if (trav->first) {
+	trav->first = 0;
+	return rbtree_first(trav);
+    else
+	return rbtree_next(trav);
+/* two functions needed to fully traverse the tree: initialize and continue
+ * this one here uses a stack
+ * parent pointers or threads would also be possible
+ * but these would need to be added to RB_NODE
+ * -> more memory needed for standard operations
+/* start traversing the tree */
+void *rbtree_first(struct RB_TRAV *trav)
+    trav->top = 0;
+    /* get smallest item */
+    if (trav->curr_node != NULL) {
+	while (trav->curr_node->link[0] != NULL) {
+	    trav->up[trav->top++] = trav->curr_node;
+	    trav->curr_node = trav->curr_node->link[0];
+	return trav->curr_node->data; /* return smallest item */
+    else
+	return NULL; /* empty tree */
+/* continue traversing the tree */
+void *rbtree_next(struct RB_TRAV *trav)
+    if (trav->curr_node->link[1] != NULL) {
+	/* something on the right side: larger item */
+	trav->curr_node = trav->curr_node->link[1];
+	/* go down, find smallest item in this branch */
+    else {
+	/* at smallest item in this branch, go back up */
+	struct RB_NODE *last;
+	do {
+	    if (trav->top == 0) {
+		trav->curr_node = NULL;
+		break;
+	    last = trav->curr_node;
+	    trav->curr_node = trav->up[--trav->top];
+	} while (last == trav->curr_node->link[1]);
+    else
+	return NULL; /* finished traversing */
+/* destroy the tree */
+void rbtree_destroy(struct RB_TREE *tree) {
+    rbtree_destroy2(tree->root);
+void rbtree_destroy2(struct RB_NODE *root)
+    if (root != NULL) {
+	rbtree_destroy2(root->link[0]);
+	rbtree_destroy2(root->link[1]);
+	free(root->data);
+	free(root);
+ * internal funtions used for Red Black Tree maintenance
+/* add a new node to the tree */
+struct RB_NODE *rbtree_make_node(size_t datasize, void *data)
+    struct RB_NODE *new_node = malloc(sizeof(*new_node));
+    if (new_node != NULL) {
+	new_node->data = malloc(datasize);
+	if (new_node->data == NULL)
+	    G_fatal_error("RB Search Tree: Out of memory!");
+	memcpy(new_node->data, data, datasize);
+	new_node->red = 1; /* 1 is red, 0 is black */
+	new_node->link[0] = NULL;
+	new_node->link[1] = NULL;
+    else
+    return new_node;
+/* check for red violation */
+int is_red(struct RB_NODE *root)
+    if (root)
+	return root->red == 1;
+    return 0;
+/* single rotation */
+struct RB_NODE *rbtree_single(struct RB_NODE *root, int dir)
+    struct RB_NODE *newroot = root->link[!dir];
+    root->link[!dir] = newroot->link[dir];
+    newroot->link[dir] = root;
+    root->red = 1;
+    newroot->red = 0;
+    return newroot;
+/* double rotation */
+struct RB_NODE *rbtree_double(struct RB_NODE *root, int dir)
+    root->link[!dir] = rbtree_single(root->link[!dir], !dir);
+    return rbtree_single(root, dir);
+/* only used for debugging */
+/* check for errors */
+int rbtree_debug(struct RB_TREE *tree, struct RB_NODE *root)
+    int lh, rh;
+    if (root == NULL)
+	return 1;
+    else {
+	struct RB_NODE *ln = root->link[0];
+	struct RB_NODE *rn = root->link[1];
+	int lcmp, rcmp;
+	/* Consecutive red links */
+	if (is_red(root)) {
+	    if (is_red(ln) || is_red(rn)) {
+		G_warning("Red Black Tree debugging: Red violation");
+		return 0;
+	lh = rbtree_debug(tree, ln);
+	rh = rbtree_debug(tree, rn);
+	if (ln) {
+	    lcmp = tree->rb_compare(ln->data, root->data);
+	else {
+	    lcmp = 1;
+	if (rn) {
+	    rcmp = tree->rb_compare(rn->data, root->data);
+	else {
+	    rcmp = 1;
+	/* Invalid binary search tree */
+	if ((ln != NULL && (lcmp == 0 || lcmp == 2))
+	 || (rn != NULL && (rcmp == 1 || rcmp == 2))) {
+	    G_warning("Red Black Tree debugging: Binary tree violation" );
+	    return 0;
+	/* Black height mismatch */
+	if (lh != 0 && rh != 0 && lh != rh) {
+	    G_warning("Red Black Tree debugging: Black violation");
+	    return 0;
+	/* Only count black links */
+	if (lh != 0 && rh != 0)
+	    return is_red(root) ? lh : lh + 1;
+	else
+	    return 0;
