[GRASS-SVN] r43026 - in grass/trunk/gui/wxpython: . gui_modules icons
Mon Aug 9 14:16:57 EDT 2010
Author: martinl
Date: 2010-08-09 18:16:56 +0000 (Mon, 09 Aug 2010)
New Revision: 43026
   grass/trunk/gui/wxpython/gui_modules/goutput.py
   grass/trunk/gui/wxpython/gui_modules/layertree.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp.py
   grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
   grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
   grass/trunk/gui/wxpython/gui_modules/render.py
   grass/trunk/gui/wxpython/gui_modules/toolbars.py
   grass/trunk/gui/wxpython/icons/icon.py
   grass/trunk/gui/wxpython/wxgui.py
wxGUI/nviz: fix volumes
Modified: grass/trunk/gui/wxpython/gui_modules/goutput.py
--- grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/gui_modules/goutput.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -460,7 +460,7 @@
                 try:
                     layertype = {'d.rast'         : 'raster',
-                                 'd.rast3d'       : 'raster3d',
+                                 'd.rast3d'       : '3d-raster',
                                  'd.rgb'          : 'rgb',
                                  'd.his'          : 'his',
                                  'd.shaded'       : 'shaded',
Modified: grass/trunk/gui/wxpython/gui_modules/layertree.py
--- grass/trunk/gui/wxpython/gui_modules/layertree.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/gui_modules/layertree.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -279,7 +279,7 @@
             self.popupMenu.Append(self.popupID3, text=_("Properties"))
             self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
-            if ltype in ('raster', 'vector', 'raster3d') and self.mapdisplay.toolbars['nviz']:
+            if ltype in ('raster', 'vector', '3d-raster') and self.mapdisplay.toolbars['nviz']:
                 self.popupMenu.Append(self.popupID11, _("3D view properties"))
                 self.Bind (wx.EVT_MENU, self.OnNvizProperties, id=self.popupID11)
@@ -618,7 +618,7 @@
             self.lmgr.nviz.SetPage('surface')
         elif ltype == 'vector':
             self.lmgr.nviz.SetPage('vector')
-        elif ltype == 'raster3d':
+        elif ltype == '3d-raster':
             self.lmgr.nviz.SetPage('volume')
     def RenameLayer (self, event):
@@ -812,11 +812,7 @@
             # run properties dialog if no properties given
             if len(cmd) == 0:
                 self.PropertiesDialog(layer, show=True)
-            if ltype == '3d-raster' and \
-                    not self.mapdisplay.toolbars['nviz']:
-                self.EnableItem(layer, False)
         else: # group
             self.SetPyData(layer, ({'cmd': None,
                                     'type' : ltype,
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -395,10 +395,6 @@
             self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
             self.toolbars['map'].Enable2D(False)
-            # update layer tree (-> enable 3d-rasters)
-            if self.tree:
-                self.tree.EnableItemType(type='3d-raster', enable=True)
             # update status bar
             self.statusbarWin['toggle'].Enable(False)
@@ -479,11 +475,6 @@
             # remove nviz notebook page
             self._layerManager.RemoveNviz()
-            # update layer tree (-> disable 3d-rasters)
-            if self.tree:
-                self.tree.EnableItemType(type='3d-raster', enable=False)
             self.MapWindow.UpdateMap()
         self.toolbars['map'].combo.SetValue (_("2D view"))
Modified: grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/gui_modules/mapdisp_window.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -762,18 +762,22 @@
         if self.tree:
             self.tree.rerender = False
-        if render:
-            # update display size
-            self.Map.ChangeMapSize(self.GetClientSize())
-            if self.parent.statusbarWin['resolution'].IsChecked():
-                # use computation region resolution for rendering
-                windres = True
+        try:
+            if render:
+                # update display size
+                self.Map.ChangeMapSize(self.GetClientSize())
+                if self.parent.statusbarWin['resolution'].IsChecked():
+                    # use computation region resolution for rendering
+                    windres = True
+                else:
+                    windres = False
+                self.mapfile = self.Map.Render(force = True, mapWindow = self.parent,
+                                               windres = windres)
             else:
-                windres = False
-            self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
-                                           windres=windres)
-        else:
-            self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+                self.mapfile = self.Map.Render(force = False, mapWindow = self.parent)
+        except gcmd.GException, e:
+            gcmd.GError(message = e)
+            self.mapfile = None
         self.img = self.GetImage() # id=99
Modified: grass/trunk/gui/wxpython/gui_modules/nviz_tools.py
--- grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/gui_modules/nviz_tools.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -886,9 +886,9 @@
         # selection
         box = wx.StaticBox (parent = panel, id = wx.ID_ANY,
-                            label = " %s " % (_("3D Raster map")))
+                            label = " %s " % (_("3D raster map")))
         boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        rmaps = gselect.Select(parent = panel, type = 'raster3d',
+        rmaps = gselect.Select(parent = panel, type = 'raster3D',
                                onPopup = self.GselectOnPopup)
         rmaps.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnSetRaster3D)
         self.win['volume']['map'] = rmaps.GetId()
@@ -1326,7 +1326,7 @@
         elif nvizType == 'vector':
             return self.mapWindow.GetLayerByName(name, mapType = 'vector', dataType = 'nviz')
         elif nvizType == 'volume':
-            return self.mapWindow.GetLayerByName(name, mapType = 'raster3d', dataType = 'nviz')
+            return self.mapWindow.GetLayerByName(name, mapType = '3d-raster', dataType = 'nviz')
         return None
@@ -1521,12 +1521,12 @@
         """!3D Raster map selected, update surface page"""
         name = event.GetString()
         try:
-            data = self.mapWindow.GetLayerByName(name, mapType = 'raster3d', dataType = 'nviz')['surface']
+            data = self.mapWindow.GetLayerByName(name, mapType = '3d-raster', dataType = 'nviz')['volume']
         except:
             self.EnablePage('volume', False)
             return
-        layer = self.mapWindow.GetLayerByName(name, mapType = 'raster3d')
+        layer = self.mapWindow.GetLayerByName(name, mapType = '3d-raster')
         self.EnablePage('volume', True)
         self.UpdateVolumePage(layer, data, updateName = False)
@@ -1665,7 +1665,7 @@
                                                    'value' : str(value),
                                                    'update' : None }
         else: # volume / isosurface
             list = self.FindWindowById(self.win['volume']['isosurfs'])
             id = list.GetSelection()
             data[nvizType]['isosurface'][id][attrb] = { 'map' : useMap,
@@ -1760,12 +1760,13 @@
                                                        'update' : None }
             else:
-                data[nvizType]['isosurface'][id][attrb] = { 'map' : useMap,
-                                                            'value' : str(value),
-                                                            'update' : None }
+                if id > -1:
+                    data[nvizType]['isosurface'][id][attrb] = { 'map' : useMap,
+        'value' : str(value),
+        'update' : None }
             # update properties
             event = wxUpdateProperties(data = data)
@@ -2272,7 +2273,7 @@
         # update dialog
         name = self.FindWindowById(self.win['volume']['map']).GetValue()
         data = self.GetLayerData('volume')['volume']['isosurface'][selection]
         self.UpdateVolumeIsosurfPage(layer, data)
@@ -2294,7 +2295,7 @@
         list.SetSelection(item)
         id = data['object']['id']
@@ -2355,7 +2356,7 @@
             list.SetSelection(list.GetCount()-1)
@@ -2382,7 +2383,7 @@
             return # this should not happen
@@ -2414,7 +2415,7 @@
@@ -2470,7 +2471,7 @@
                     layer = self.mapWindow.GetLayerByName(name, mapType = 'vector')
                     self.UpdateVectorPage(layer, data['vector'])
                 elif pageId == 'volume':
         elif pageId == 'light':
             zval = self.mapWindow.light['position']['z']
@@ -2712,14 +2713,10 @@
         """!Update volume page"""
         if updateName:
             self.FindWindowById(self.win['volume']['map']).SetValue(layer.name)
-        # self.FindWindowById(self.win['volume']['desc']).SetLabel(desc)
         # draw
-        for control, data in data['draw'].iteritems():
+        for control, idata in data['draw'].iteritems():
             if control == 'all': # skip 'all' property
                 continue
@@ -2731,7 +2728,7 @@
                 else:
                     value = 1
             else:
-                value = data['value']
+                value = idata['value']
             if win.GetName() == "selection":
                 win.SetSelection(value)
@@ -2740,7 +2737,7 @@
         self.SetIsosurfaceMode(data['draw']['shading']['value'])
         self.SetIsosurfaceResolution(data['draw']['resolution']['value'])
         self.UpdateVolumeIsosurfPage(layer, data['attribute'])
     def UpdateVolumeIsosurfPage(self, layer, data):
Modified: grass/trunk/gui/wxpython/gui_modules/render.py
--- grass/trunk/gui/wxpython/gui_modules/render.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/gui_modules/render.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -131,7 +131,7 @@
                       'overlay')
         if self.type not in layertypes:
-            raise gcmd.GException(_("<%(name)s>: layer type <%(type)s> is not supported yet.") % \
+            raise gcmd.GException(_("<%(name)s>: layer type <%(type)s> is not supported") % \
                                       {'type' : self.type, 'name' : self.name})
Modified: grass/trunk/gui/wxpython/gui_modules/toolbars.py
--- grass/trunk/gui/wxpython/gui_modules/toolbars.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/gui_modules/toolbars.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -1706,6 +1706,7 @@
         self.workspaceOpen = wx.NewId()
         self.workspaceSave = wx.NewId()
         self.addrast = wx.NewId()
+        self.addrast3d = wx.NewId()
         self.addshaded = wx.NewId()
         self.addvect = wx.NewId()
         self.addthematic = wx.NewId()
@@ -1735,6 +1736,9 @@
             (self.addrast, 'addrast', Icons["addrast"].GetBitmap(),
              wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
              self.parent.OnAddRaster),
+            (self.addrast3d, 'addrast3d', Icons["addrast3d"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["addrast3d"].GetLabel(), Icons["addrast3d"].GetDesc(),
+             self.parent.OnAddRaster3D),
             (self.addshaded, 'addshaded', Icons["addshaded"].GetBitmap(),
              wx.ITEM_NORMAL, _("Add various raster-based map layers"), "",
              self.parent.OnAddRasterMisc),
Modified: grass/trunk/gui/wxpython/icons/icon.py
--- grass/trunk/gui/wxpython/icons/icon.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/icons/icon.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -192,9 +192,9 @@
     "addvect"    : MetaIcon (img=Icons["addvect"],
                              label=_("Add vector map layer (Ctrl+V)")),
     "addcmd"     : MetaIcon (img=Icons["addcmd"],
-                             label=_("Add command map layer")),
+                             label=_("Add command layer")),
     "addgrp"     : MetaIcon (img=Icons["addgrp"],
-                             label=_("Add map layer group")),
+                             label=_("Add group")),
     "addovl"     : MetaIcon (img=Icons["addovl"],
                              label=_("Add grid or vector labels overlay")),
     "delcmd"     : MetaIcon (img=Icons["delcmd"],
@@ -228,7 +228,8 @@
     "addtext"    : MetaIcon (img=Icons["addtext"],
                              label=_("Add text layer")),
     "addrast3d"  : MetaIcon (img=Icons["addrast3d"],
-                             label=_("Add 3D raster map layer")),
+                             label=_("Add 3D raster map layer"),
+                             desc = _("Note that 3D raster data are rendered only in 3D view mode")),
     "settings"   : MetaIcon (img=Icons["settings"],
                              label=_("Show GUI settings")),
     # digit
Modified: grass/trunk/gui/wxpython/wxgui.py
--- grass/trunk/gui/wxpython/wxgui.py	2010-08-09 16:45:03 UTC (rev 43025)
+++ grass/trunk/gui/wxpython/wxgui.py	2010-08-09 18:16:56 UTC (rev 43026)
@@ -98,14 +98,15 @@
     GIS. Includes command console page for typing GRASS (and other)
     commands, tree widget page for managing map layers.
-    def __init__(self, parent, id=wx.ID_ANY, title=_("GRASS GIS Layer Manager"),
-                 workspace=None):
+    def __init__(self, parent, id = wx.ID_ANY, title = _("GRASS GIS Layer Manager"),
+                 workspace = None,
+                 size = (575, 450), style = wx.DEFAULT_FRAME_STYLE, **kwargs):
         self.parent    = parent
         self.baseTitle = title
         self.iconsize  = (16, 16)
-        wx.Frame.__init__(self, parent=parent, id=id, size=(550, 450),
-                          style=wx.DEFAULT_FRAME_STYLE)
+        wx.Frame.__init__(self, parent = parent, id = id, size = size,
+                          style = style, **kwargs)
         self.SetTitle(self.baseTitle)
         self.SetName("LayerManager")
@@ -1138,7 +1139,6 @@
         return self.curr_page.maptree.mapdisplay
-    # toolBar button handlers
     def OnAddRaster(self, event):
         """!Add raster map layer"""
         # start new map display if no display is available
@@ -1146,7 +1146,15 @@
             self.NewDisplay(show=False)
         self.AddRaster(event)
+    def OnAddRaster3D(self, event):
+        """!Add 3D raster map layer"""
+        # start new map display if no display is available
+        if not self.curr_page:
+            self.NewDisplay(show=False)
+        self.AddRaster3D(event)
     def OnAddRasterMisc(self, event):
         """!Add raster menu"""
@@ -1156,12 +1164,6 @@
         point = wx.GetMousePosition()
         rastmenu = wx.Menu()
-        # add items to the menu
-        addrast3d = wx.MenuItem(rastmenu, -1, Icons ["addrast3d"].GetLabel())
-        addrast3d.SetBitmap(Icons["addrast3d"].GetBitmap (self.iconsize))
-        rastmenu.AppendItem(addrast3d)
-        self.Bind(wx.EVT_MENU, self.AddRaster3d, addrast3d)
         addshaded = wx.MenuItem(rastmenu, -1, Icons ["addshaded"].GetLabel())
         addshaded.SetBitmap(Icons["addshaded"].GetBitmap (self.iconsize))
         rastmenu.AppendItem(addshaded)
@@ -1271,7 +1273,7 @@
         self.notebook.SetSelection(0)
         self.curr_page.maptree.AddLayer('raster')
-    def AddRaster3d(self, event):
+    def AddRaster3D(self, event):
         self.curr_page.maptree.AddLayer('3d-raster')
