[GRASS-SVN] r43027 - in grass/branches/develbranch_6: gui/wxpython gui/wxpython/gui_modules gui/wxpython/icons gui/wxpython/scripts include/Make
Mon Aug 9 14:50:29 EDT 2010
Author: martinl
Date: 2010-08-09 18:50:29 +0000 (Mon, 09 Aug 2010)
New Revision: 43027
Added:
   grass/branches/develbranch_6/gui/wxpython/scripts/Makefile
   grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d.py
   grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd.py
   grass/branches/develbranch_6/gui/wxpython/scripts/p.db.py
   grass/branches/develbranch_6/gui/wxpython/scripts/p.mon.py
   grass/branches/develbranch_6/gui/wxpython/scripts/p.rast.py
   grass/branches/develbranch_6/gui/wxpython/scripts/p.vect.py
Removed:
   grass/branches/develbranch_6/gui/wxpython/Makefile
   grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
   grass/branches/develbranch_6/gui/wxpython/gui_modules/wxnviz.py
   grass/branches/develbranch_6/gui/wxpython/icons/icon.py
   grass/branches/develbranch_6/gui/wxpython/wxgui.py
   grass/branches/develbranch_6/include/Make/Platform.make.in
   grass/branches/develbranch_6/include/Make/Python.make
wxGUI/nviz: fix volumes + convert support scripts to Python
Modified: grass/branches/develbranch_6/gui/wxpython/Makefile
--- grass/branches/develbranch_6/gui/wxpython/Makefile	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/Makefile	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1,8 +1,8 @@
 MODULE_TOPDIR = ../..
-SUBDIRS = docs vdigit
+SUBDIRS = docs vdigit scripts
 EXTRA_CLEAN_FILES = menustrings.py
-CLEAN_SUBDIRS = vdigit
+CLEAN_SUBDIRS = vdigit scripts
 include $(MODULE_TOPDIR)/include/Make/Dir.make
 include $(MODULE_TOPDIR)/include/Make/Doxygen.make
@@ -10,25 +10,19 @@
 ETCDIR = $(ETC)/wxpython
-SRCFILES := $(wildcard scripts/* compat/* gui_modules/* icons/*.* icons/silk/* images/* xml/*) gis_set.py wxgui.py README scripts/wxgui
+SRCFILES := $(wildcard compat/* gui_modules/* icons/*.* icons/silk/* images/* xml/*) gis_set.py wxgui.py README
 DSTFILES := $(patsubst %,$(ETCDIR)/%,$(SRCFILES)) $(patsubst %.py,$(ETCDIR)/%.pyc,$(filter %.py,$(SRCFILES)))
 default: install_scripts
 	$(MAKE) parsubdirs
 install_scripts:
-	-for dir in '' compat gui_modules icons icons/silk images scripts vdigit xml; do \
+	-for dir in '' compat gui_modules icons icons/silk images vdigit xml; do \
 	if [ ! -d $(ETCDIR)/$$dir ] ; then $(MKDIR) $(ETCDIR)/$$dir ; fi ; \
 	done
 	$(MAKE) $(DSTFILES)
 	$(MAKE) menustrings.py
-$(ETCDIR)/scripts/wxgui: wxgui
-	$(INSTALL) $< $@
-$(ETCDIR)/scripts/%: scripts/%
-	$(INSTALL) $< $@
 $(ETCDIR)/%: %
 	$(INSTALL_DATA) $< $@
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/globalvar.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -154,6 +154,7 @@
         cmd = cmd + os.listdir(os.path.join(gisbase, 'scripts'))
     if gui_scripts is True:
         os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'gui', 'scripts')
+        os.environ["PATH"] = os.getenv("PATH") + os.pathsep + os.path.join(gisbase, 'etc', 'wxpython', 'scripts')
         cmd = cmd + os.listdir(os.path.join(gisbase, 'etc', 'gui', 'scripts'))
     if subprocess.mswindows:
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/goutput.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -459,6 +459,7 @@
                 try:
                     layertype = {'d.rast'         : 'raster',
+                                 'd.rast3d'       : '3d-raster',
                                  'd.rgb'          : 'rgb',
                                  'd.his'          : 'his',
                                  'd.shaded'       : 'shaded',
@@ -473,11 +474,11 @@
                                  'd.rhumbline'    : 'rhumb',
                                  'd.labels'       : 'labels'}[cmdlist[0]]
                 except KeyError:
-                    wx.MessageBox(caption = _("Message"),
-                                  message=_("Command '%s' not yet implemented in the GUI. "
-                                            "Try adding it as a command layer instead.") % cmdlist[0])
+                    gcmd.GMessage(parent = self.parent,
+                                  message = _("Command '%s' not yet implemented in the WxGUI. "
+                                              "Try adding it as a command layer instead.") % cmdlist[0])
                     return None
                 # add layer into layer tree
                 if cmdlist[0] == 'd.rast':
                     lname = utils.GetLayerNameFromCmd(cmdlist, fullyQualified = True,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/layertree.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -279,7 +279,7 @@
             self.popupMenu.Append(self.popupID3, text=_("Properties"))
             self.Bind(wx.EVT_MENU, self.OnPopupProperties, id=self.popupID3)
-            if ltype in ('raster', 'vector', 'raster3d') and self.mapdisplay.toolbars['nviz']:
+            if ltype in ('raster', 'vector', '3d-raster') and self.mapdisplay.toolbars['nviz']:
                 self.popupMenu.Append(self.popupID11, _("3D view properties"))
                 self.Bind (wx.EVT_MENU, self.OnNvizProperties, id=self.popupID11)
@@ -619,7 +619,7 @@
             self.lmgr.nviz.SetPage('surface')
         elif ltype == 'vector':
             self.lmgr.nviz.SetPage('vector')
-        elif ltype == 'raster3d':
+        elif ltype == '3d-raster':
             self.lmgr.nviz.SetPage('volume')
     def RenameLayer (self, event):
@@ -813,11 +813,7 @@
             # run properties dialog if no properties given
             if len(cmd) == 0:
                 self.PropertiesDialog(layer, show=True)
-            if ltype == '3d-raster' and \
-                    not self.mapdisplay.toolbars['nviz']:
-                self.EnableItem(layer, False)
         else: # group
             self.SetPyData(layer, ({'cmd': None,
                                     'type' : ltype,
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -393,10 +393,6 @@
             self.toolbars['nviz'] = toolbars.NvizToolbar(self, self.Map)
             self.toolbars['map'].Enable2D(False)
-            # update layer tree (-> enable 3d-rasters)
-            if self.tree:
-                self.tree.EnableItemType(type='3d-raster', enable=True)
             # update status bar
             self.statusbarWin['toggle'].Enable(False)
@@ -477,11 +473,6 @@
             # remove nviz notebook page
             self._layerManager.RemoveNviz()
-            # update layer tree (-> disable 3d-rasters)
-            if self.tree:
-                self.tree.EnableItemType(type='3d-raster', enable=False)
             self.MapWindow.UpdateMap()
         self.toolbars['map'].combo.SetValue (_("2D view"))
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/mapdisp_window.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -762,18 +762,22 @@
         if self.tree:
             self.tree.rerender = False
-        if render:
-            # update display size
-            self.Map.ChangeMapSize(self.GetClientSize())
-            if self.parent.statusbarWin['resolution'].IsChecked():
-                # use computation region resolution for rendering
-                windres = True
+        try:
+            if render:
+                # update display size
+                self.Map.ChangeMapSize(self.GetClientSize())
+                if self.parent.statusbarWin['resolution'].IsChecked():
+                    # use computation region resolution for rendering
+                    windres = True
+                else:
+                    windres = False
+                self.mapfile = self.Map.Render(force = True, mapWindow = self.parent,
+                                               windres = windres)
             else:
-                windres = False
-            self.mapfile = self.Map.Render(force=True, mapWindow=self.parent,
-                                           windres=windres)
-        else:
-            self.mapfile = self.Map.Render(force=False, mapWindow=self.parent)
+                self.mapfile = self.Map.Render(force = False, mapWindow = self.parent)
+        except gcmd.GException, e:
+            gcmd.GError(message = e)
+            self.mapfile = None
         self.img = self.GetImage() # id=99
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/nviz_tools.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -887,9 +887,9 @@
         # selection
         box = wx.StaticBox (parent = panel, id = wx.ID_ANY,
-                            label = " %s " % (_("3D Raster map")))
+                            label = " %s " % (_("3D raster map")))
         boxSizer = wx.StaticBoxSizer(box, wx.VERTICAL)
-        rmaps = gselect.Select(parent = panel, type = 'raster3d',
+        rmaps = gselect.Select(parent = panel, type = 'raster3D',
                                onPopup = self.GselectOnPopup)
         rmaps.GetChildren()[0].Bind(wx.EVT_TEXT, self.OnSetRaster3D)
         self.win['volume']['map'] = rmaps.GetId()
@@ -1327,7 +1327,7 @@
         elif nvizType == 'vector':
             return self.mapWindow.GetLayerByName(name, mapType = 'vector', dataType = 'nviz')
         elif nvizType == 'volume':
-            return self.mapWindow.GetLayerByName(name, mapType = 'raster3d', dataType = 'nviz')
+            return self.mapWindow.GetLayerByName(name, mapType = '3d-raster', dataType = 'nviz')
         return None
@@ -1522,12 +1522,12 @@
         """!3D Raster map selected, update surface page"""
         name = event.GetString()
         try:
-            data = self.mapWindow.GetLayerByName(name, mapType = 'raster3d', dataType = 'nviz')['surface']
+            data = self.mapWindow.GetLayerByName(name, mapType = '3d-raster', dataType = 'nviz')['volume']
         except:
             self.EnablePage('volume', False)
             return
-        layer = self.mapWindow.GetLayerByName(name, mapType = 'raster3d')
+        layer = self.mapWindow.GetLayerByName(name, mapType = '3d-raster')
         self.EnablePage('volume', True)
         self.UpdateVolumePage(layer, data, updateName = False)
@@ -1666,7 +1666,7 @@
                                                    'value' : str(value),
                                                    'update' : None }
         else: # volume / isosurface
             list = self.FindWindowById(self.win['volume']['isosurfs'])
             id = list.GetSelection()
             data[nvizType]['isosurface'][id][attrb] = { 'map' : useMap,
@@ -1761,12 +1761,13 @@
                                                        'update' : None }
             else:
-                data[nvizType]['isosurface'][id][attrb] = { 'map' : useMap,
-                                                            'value' : str(value),
-                                                            'update' : None }
+                if id > -1:
+                    data[nvizType]['isosurface'][id][attrb] = { 'map' : useMap,
+        'value' : str(value),
+        'update' : None }
             # update properties
             event = wxUpdateProperties(data = data)
@@ -2273,7 +2274,7 @@
         # update dialog
         name = self.FindWindowById(self.win['volume']['map']).GetValue()
         data = self.GetLayerData('volume')['volume']['isosurface'][selection]
         self.UpdateVolumeIsosurfPage(layer, data)
@@ -2295,7 +2296,7 @@
         list.SetSelection(item)
         id = data['object']['id']
@@ -2356,7 +2357,7 @@
             list.SetSelection(list.GetCount()-1)
@@ -2383,7 +2384,7 @@
             return # this should not happen
@@ -2415,7 +2416,7 @@
@@ -2471,7 +2472,7 @@
                     layer = self.mapWindow.GetLayerByName(name, mapType = 'vector')
                     self.UpdateVectorPage(layer, data['vector'])
                 elif pageId == 'volume':
         elif pageId == 'light':
             zval = self.mapWindow.light['position']['z']
@@ -2713,14 +2714,10 @@
         """!Update volume page"""
         if updateName:
             self.FindWindowById(self.win['volume']['map']).SetValue(layer.name)
-        # self.FindWindowById(self.win['volume']['desc']).SetLabel(desc)
         # draw
-        for control, data in data['draw'].iteritems():
+        for control, idata in data['draw'].iteritems():
             if control == 'all': # skip 'all' property
                 continue
@@ -2732,7 +2729,7 @@
                 else:
                     value = 1
             else:
-                value = data['value']
+                value = idata['value']
             if win.GetName() == "selection":
                 win.SetSelection(value)
@@ -2741,7 +2738,7 @@
         self.SetIsosurfaceMode(data['draw']['shading']['value'])
         self.SetIsosurfaceResolution(data['draw']['resolution']['value'])
         self.UpdateVolumeIsosurfPage(layer, data['attribute'])
     def UpdateVolumeIsosurfPage(self, layer, data):
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/render.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -131,7 +131,7 @@
                       'overlay')
         if self.type not in layertypes:
-            raise gcmd.GException(_("<%(name)s>: layer type <%(type)s> is not supported yet.") % \
+            raise gcmd.GException(_("<%(name)s>: layer type <%(type)s> is not supported") % \
                                       {'type' : self.type, 'name' : self.name})
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/toolbars.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1557,6 +1557,7 @@
         self.workspaceOpen = wx.NewId()
         self.workspaceSave = wx.NewId()
         self.addrast = wx.NewId()
+        self.addrast3d = wx.NewId()
         self.addshaded = wx.NewId()
         self.addvect = wx.NewId()
         self.addthematic = wx.NewId()
@@ -1586,6 +1587,9 @@
             (self.addrast, 'addrast', Icons["addrast"].GetBitmap(),
              wx.ITEM_NORMAL, Icons["addrast"].GetLabel(), Icons["addrast"].GetDesc(),
              self.parent.OnAddRaster),
+            (self.addrast3d, 'addrast3d', Icons["addrast3d"].GetBitmap(),
+             wx.ITEM_NORMAL, Icons["addrast3d"].GetLabel(), Icons["addrast3d"].GetDesc(),
+             self.parent.OnAddRaster3D),
             (self.addshaded, 'addshaded', Icons["addshaded"].GetBitmap(),
              wx.ITEM_NORMAL, _("Add various raster-based map layers"), "",
              self.parent.OnAddRasterMisc),
Modified: grass/branches/develbranch_6/gui/wxpython/gui_modules/wxnviz.py
--- grass/branches/develbranch_6/gui/wxpython/gui_modules/wxnviz.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/gui_modules/wxnviz.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -24,6 +24,7 @@
 from ctypes import *
 try:
     from grass.lib.grass import *
+    from grass.lib.g3d   import *
     from grass.lib.ogsf  import *
     from grass.lib.nviz  import *
     errorMsg = ''
Modified: grass/branches/develbranch_6/gui/wxpython/icons/icon.py
--- grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/icons/icon.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -192,9 +192,9 @@
     "addvect"    : MetaIcon (img=Icons["addvect"],
                              label=_("Add vector map layer (Ctrl+V)")),
     "addcmd"     : MetaIcon (img=Icons["addcmd"],
-                             label=_("Add command map layer")),
+                             label=_("Add command layer")),
     "addgrp"     : MetaIcon (img=Icons["addgrp"],
-                             label=_("Add map layer group")),
+                             label=_("Add group")),
     "addovl"     : MetaIcon (img=Icons["addovl"],
                              label=_("Add grid or vector labels overlay")),
     "delcmd"     : MetaIcon (img=Icons["delcmd"],
@@ -228,7 +228,8 @@
     "addtext"    : MetaIcon (img=Icons["addtext"],
                              label=_("Add text layer")),
     "addrast3d"  : MetaIcon (img=Icons["addrast3d"],
-                             label=_("Add 3D raster map")),
+                             label=_("Add 3D raster map layer"),
+                             desc = _("Note that 3D raster data are rendered only in 3D view mode")),
     "settings"   : MetaIcon (img=Icons["settings"],
                              label=_("Show GUI settings")),
     # digit
Added: grass/branches/develbranch_6/gui/wxpython/scripts/Makefile
--- grass/branches/develbranch_6/gui/wxpython/scripts/Makefile	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/Makefile	2010-08-09 18:50:29 UTC (rev 43027)
@@ -0,0 +1,26 @@
+MODULE_TOPDIR = ../../..
+include $(MODULE_TOPDIR)/include/Make/Dir.make
+include $(MODULE_TOPDIR)/include/Make/Python.make
+SCRIPTDIR = $(ETC)/wxpython/scripts
+ifdef MINGW
+PYFILES := $(patsubst %.py, $(SCRIPTDIR)/%.py, $(filter %.py, $(PY_SOURCES)))
+else
+PYFILES := $(patsubst %.py, $(SCRIPTDIR)/%, $(filter %.py, $(PY_SOURCES)))
+endif
+default: install_scripts
+install_scripts:
+	$(MAKE) $(PYFILES)
+$(SCRIPTDIR)/%: %.py | $(SCRIPTDIR)
+	$(INSTALL) $< $@
+$(SCRIPTDIR)/%.py: %.py | $(SCRIPTDIR)
+	$(INSTALL) $< $@
+$(SCRIPTDIR):
+	-test -d $@ | $(MKDIR) $@
Property changes on: grass/branches/develbranch_6/gui/wxpython/scripts/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-sh
Added: svn:keywords
   + Author Date Id
Added: svn:eol-style
   + native
Deleted: grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d
--- grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1,36 +0,0 @@
-#!/usr/bin/env python
-# MODULE:       d.rast3d
-# AUTHOR(S):    Martin Landa <landa.martin gmail.com>
-# PURPOSE:	Wrapper for wxGUI -- add 3d raster map layer into layer tree
-# COPYRIGHT:	(C) 2008 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#%module
-#%  description: Displays 3d raster data in the active frame on the graphics monitor.
-#%  keywords: display, raster3d
-#%end
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,grid3,3d-raster
-#% description: 3D raster map to be displayed
-#% required : yes
-#%end
-from grass.script import core as grass
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    main()
Added: grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d.py
--- grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -0,0 +1,36 @@
+#!/usr/bin/env python
+# MODULE:       d.rast3d
+# AUTHOR(S):    Martin Landa <landa.martin gmail.com>
+# PURPOSE:	Wrapper for wxGUI to add 3D raster map into layer tree
+# COPYRIGHT:	(C) 2008, 2010 by the GRASS Development Team
+#		This program is free software under the GNU General
+#		Public License (>=v2). Read the file COPYING that
+#		comes with GRASS for details.
+#%module
+#% description: Displays 3D raster map layer.
+#% keywords: display, raster3d
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,grid3,3d-raster
+#% description: 3D raster map to be displayed
+#% required : yes
+#%end
+from grass.script import core as grass
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    main()
Property changes on: grass/branches/develbranch_6/gui/wxpython/scripts/d.rast3d.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Deleted: grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1,49 +0,0 @@
-#!/bin/sh
-#%module
-#% description: Wrapper for display commands and pX monitors
-#%end
-#%option
-#% key: cmd
-#% type: string
-#% required: yes
-#% multiple: no
-#% label: Command to be performed
-#% description: Example: "d.rast map=elevation.dem at PERMANENT catlist=1300-1400 -i"
-#%end
-#%option
-#% key: opacity
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: val
-#% description: Opacity level in percentage
-#% answer: 100
-#%end
-if [ -z "$GISBASE" ] ; then
-    echo "You must be in GRASS GIS to run this program." 1>&2
-    exit 1
-fi
-if [ "$1" != "@ARGS_PARSED@" ] ; then
-    exec g.parser "$0" "$@"
-fi
-cmdfile="`g.gisenv get=GRASS_PYCMDFILE`"
-if [ -e ${cmdfile} ] && [ -n "${cmdfile}" ]; then
-else
-    g.message -e "GRASS_PYCMDFILE - File not found. Run p.mon"
-    exit 1
-fi
-cmd="${GIS_OPT_CMD}"
-g.message -d message="$0: ${cmd}"
-echo "${cmd}" >> "${cmdfile}"
-exit 0
Added: grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd.py
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -0,0 +1,65 @@
+# MODULE:       p.cmd
+# AUTHOR(S):    Martin Landa, Hamish Bowman
+#               Converted to Python by Huidae Cho
+# PURPOSE:      Wrapper for display commands and pX monitors
+# COPYRIGHT:    (C) 2009 by The GRASS Development Team
+#  This program is free software; you can redistribute it and/or modify
+#  it under the terms of the GNU General Public License as published by
+#  the Free Software Foundation; either version 2 of the License, or
+#  (at your option) any later version.
+#  This program is distributed in the hope that it will be useful,
+#  but WITHOUT ANY WARRANTY; without even the implied warranty of
+#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+#  GNU General Public License for more details.
+#%Module
+#% description: Wrapper for display commands and pX monitors
+#%End
+#%Option
+#% key: cmd
+#% type: string
+#% required: yes
+#% multiple: no
+#% label: Command to be performed
+#% description: Example: "d.rast map=elevation.dem at PERMANENT catlist=1300-1400 -i"
+#%End
+#%Option
+#% key: opacity
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: val
+#% description: Opacity level in percentage
+#% answer: 100
+#%End
+import os
+import grass.script as grass
+def main():
+    cmd_file = grass.gisenv()["GRASS_PYCMDFILE"]
+    if cmd_file == "" or os.path.exists(cmd_file) == False:
+        grass.message(_("GRASS_PYCMDFILE - File not found. Run p.mon."), "e")
+        return
+    cmd = options["cmd"]
+    opacity = options["opacity"]
+    fp = open(cmd_file, "a")
+    fp.write("%s opacity=%s\n" % (cmd, opacity))
+    fp.close()
+    main()
Property changes on: grass/branches/develbranch_6/gui/wxpython/scripts/p.cmd.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Deleted: grass/branches/develbranch_6/gui/wxpython/scripts/p.db
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.db	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.db	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1,35 +0,0 @@
-#!/bin/sh
-#%Module
-#% description: Start stand-alone attribute table manager
-#% keywords: database
-#%End
-#%Option
-#% key: table
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Table name
-#%End
-    exit 1
-fi
-fi
-# CODE GOES HERE
-if [ -z "$PYTHONPATH" ] ; then
-   PYTHONPATH="$GISBASE/etc/wxpython"
-else
-   PYTHONPATH="$GISBASE/etc/wxpython:$PYTHONPATH"
-fi
-export PYTHONPATH
-"$GRASS_PYTHON" "$PYTHONPATH/gui_modules/dbm.py" "$GIS_OPT_TABLE"
-exit 0
Added: grass/branches/develbranch_6/gui/wxpython/scripts/p.db.py
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.db.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.db.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -0,0 +1,44 @@
+# MODULE:       p.db
+# AUTHOR(S):    Jachym Cepicky, Markus Neteler, Hamish Bowman
+# PURPOSE:      Start stand-alone attribute table manager
+#%Module
+#% description: Start stand-alone attribute table manager
+#% keywords: database
+#%End
+#%Option
+#% key: table
+#% type: string
+#% required: yes
+#% multiple: no
+#% description: Table name
+#%End
+import os
+def main():
+    table = options["table"]
+    os.spawnlp(os.P_NOWAIT, os.environ["GRASS_PYTHON"], os.environ["GRASS_PYTHON"], "%s/etc/wxpython/gui_modules/dbm.py" % os.environ["GISBASE"], table)
+    main()
Property changes on: grass/branches/develbranch_6/gui/wxpython/scripts/p.db.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Deleted: grass/branches/develbranch_6/gui/wxpython/scripts/p.mon
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.mon	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.mon	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1,91 +0,0 @@
-#!/bin/sh
-#%Module
-#% description: To establish and control use of a graphics display monitor.
-#%End
-#%Flag
-#% key: l
-#% description: List all monitors
-#%End
-#%Flag
-#% key: L
-#% description: List all monitors (with current status)
-#%End
-#%Flag
-#% key: p
-#% description: Print name of currently selected monitor
-#%End
-#%Flag
-#% key: r
-#% description: Release currently selected monitor
-#%End
-#%Flag
-#% key: s
-#% description: Do not automatically select when starting
-#%End
-#%Option
-#% key: start
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of graphics monitor to start (p0-p9)
-#%End
-#%Option
-#% key: stop
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of graphics monitor to stop
-#%End
-#%Option
-#% key: select
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of graphics monitor to select
-#%End
-#%Option
-#% key: unlock
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of graphics monitor to unlock
-#%End
-    exit 1
-fi
-fi
-# CODE GOES HERE
-else
-fi
-export PYTHONPATH
-start="$GIS_OPT_START"
-select="$GIS_OPT_SELECT"
-stop="$GIS_OPT_STOP"
-unlock="$GIS_OPT_UNLOCK"
-# create the command file
-command_file="`g.tempfile pid=$$`"
-g.gisenv set="GRASS_PYCMDFILE=${command_file}"
-if [ -n "$start" ] ; then
-    "$GRASS_PYTHON" "$PYTHONPATH/gui_modules/mapdisp.py" "$start" "${command_file}" &
-fi
-if [[ -n "$stop" || -n "$select" || -n "$unlock" ]] ; then
-    g.message -w "Not implemented yet"
-fi
-exit 0
Added: grass/branches/develbranch_6/gui/wxpython/scripts/p.mon.py
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.mon.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.mon.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -0,0 +1,107 @@
+# MODULE:       p.mon
+# AUTHOR(S):    Jachym Cepicky, Michael Barton, Martin Landa, Markus Neteler,
+#               Hamish Bowman
+# PURPOSE:      To establish and control use of a graphics display monitor.
+#%Module
+#% description: To establish and control use of a graphics display monitor.
+#%End
+##%Flag
+##% key: l
+##% description: List all monitors
+##%End
+##%Flag
+##% key: L
+##% description: List all monitors (with current status)
+##%End
+##%Flag
+##% key: p
+##% description: Print name of currently selected monitor
+##%End
+##%Flag
+##% key: r
+##% description: Release currently selected monitor
+##%End
+##%Flag
+##% key: s
+##% description: Do not automatically select when starting
+##%End
+#%Option
+#% key: start
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Name of graphics monitor to start (p0-p9)
+#%End
+##%Option
+##% key: stop
+##% type: string
+##% required: no
+##% multiple: no
+##% description: Name of graphics monitor to stop
+##%End
+##%Option
+##% key: select
+##% type: string
+##% required: no
+##% multiple: no
+##% description: Name of graphics monitor to select
+##%End
+##%Option
+##% key: unlock
+##% type: string
+##% required: no
+##% multiple: no
+##% description: Name of graphics monitor to unlock
+##%End
+import os
+def main():
+    start = options["start"]
+#    select = options["select"]
+#    stop = options["stop"]
+#    unlock = options["unlock"]
+    # create the command file
+    command_file = grass.tempfile()
+    os.system("g.gisenv set=GRASS_PYCMDFILE=%s" % command_file)
+    if start != "":
+        os.spawnlp(os.P_NOWAIT, os.environ["GRASS_PYTHON"], os.environ["GRASS_PYTHON"], "%s/etc/wxpython/gui_modules/mapdisp.py" % os.environ["GISBASE"], start, command_file)
+        return
+#    if stop != "" or select != "" or unlock != "":
+#        grass.message(_("Not implemented yet"), "w")
+    main()
Property changes on: grass/branches/develbranch_6/gui/wxpython/scripts/p.mon.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Deleted: grass/branches/develbranch_6/gui/wxpython/scripts/p.rast
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.rast	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.rast	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1,113 +0,0 @@
-#!/bin/sh
-#%Module
-#% description: Displays and overlays raster map layers in the active display frame on the graphics monitor
-#%End
-#%flag
-#% key: i
-#% description: Invert catlist
-#%End
-#%Option
-#% key: map
-#% type: string
-#% required: yes
-#% multiple: no
-#% description: Raster map to be displayed
-#% gisprompt: old,cell,raster
-#%End
-#%Option
-#% key: catlist
-#% type: string
-#% required: no
-#% multiple: yes
-#% key_desc: cat[-cat]
-#% description: List of categories to be displayed (INT maps)
-#%End
-#%Option
-#% key: vallist
-#% type: string
-#% required: no
-#% multiple: yes
-#% key_desc: val[-val]
-#% description: List of values to be displayed (FP maps)
-#%End
-#%Option
-#% key: opacity
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Set opacity between 0-100%
-#%End
-    exit 1
-fi
-fi
-# CODE GOES HERE
-    echo -n
-else
-    exit 1
-fi
-eval "`echo ${GIS_OPT_MAP} | sed -e 's/^/NAME=/' -e 's/@/; MAPSET=/'`;"
-#echo $NAME
-if [ -z "${MAPSET}" ]; then
-    mapset=""
-else
-    mapset="mapset=${MAPSET}"
-fi
-#echo $MAPSET
-eval "`g.findfile element=cell file=${NAME} ${mapset}`"
-#echo $NAME
-#echo $MAPSET
-if [ -z "${GIS_OPT_CATLIST}" ]; then
-    CATLIST="None"
-else
-    CATLIST="${GIS_OPT_CATLIST}"
-fi
-if [ -z "${GIS_OPT_VALLIST}" ]; then
-    VALLIST="None"
-else
-    VALLIST="${GIS_OPT_VALLIST}"
-fi
-if [ -z "${GIS_OPT_OPACITY}" ]; then
-    OPACITY="100"
-else
-    OPACITY="${GIS_OPT_OPACITY}"
-fi
-if [ "${GIS_FLAG_I}" -eq "1" ]; then
-    INVERT="True"
-else
-    INVERT="False"
-fi
-#cmd="self.map.AddRasterLayer(self, $NAME $MAPSET $CATLIST $VALLIST $INVERCATS $INVERT $OPACITY)"
-cmd="addraster ${name} ${mapset} ${CATLIST} ${VALLIST} ${INVERT} ${OPACITY}"
-#echo "${cmd}"
Added: grass/branches/develbranch_6/gui/wxpython/scripts/p.rast.py
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.rast.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.rast.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -0,0 +1,110 @@
+# MODULE:       p.rast
+# AUTHOR(S):    Jachym Cepicky, Martin Landa, Hamish Bowman
+# PURPOSE:      Displays raster map layer in the active map display window.
+#%module
+#% description: Displays raster map layer in the active map display window.
+#%end
+#%flag
+#% key: n
+#% description: Make null cells opaque
+#%end
+#%flag
+#% key: i
+#% description: Invert catlist
+#% guisection: Selection
+#%end
+#%option
+#% key: map
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Raster map to be displayed
+#% gisprompt: old,cell,raster
+#%end
+#%option
+#% key: catlist
+#% type: string
+#% required: no
+#% multiple: yes
+#% key_desc: cat[-cat]
+#% description: List of categories to be displayed (INT maps)
+#%end
+#%option
+#% key: vallist
+#% type: string
+#% required: no
+#% multiple: yes
+#% key_desc: val[-val]
+#% description: List of values to be displayed (FP maps)
+#%end
+#%option
+#% key: bg
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: color
+#% description: Background color (for null)
+#% gisprompt: old_color,color,color
+#%end
+#%option
+#% key: opacity
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: val
+#% answer: 100
+#% description: Set opacity between 0-100%
+#%end
+import sys
+import os
+def construct_command(cmd):
+    line = cmd
+    for key, val in options.iteritems():
+        if val != "":
+            line += " %s=%s" % (key, val)
+    for key, val in flags.iteritems():
+        if val == True:
+            line += " -%s" % key
+    return line
+def main():
+        return
+    cmd = construct_command("d"+os.path.basename(sys.argv[0])[1:-3])
+    fp.write("%s\n" % cmd)
+    fp.close()
+    main()
Property changes on: grass/branches/develbranch_6/gui/wxpython/scripts/p.rast.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Deleted: grass/branches/develbranch_6/gui/wxpython/scripts/p.vect
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.vect	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.vect	2010-08-09 18:50:29 UTC (rev 43027)
@@ -1,335 +0,0 @@
-#!/bin/sh
-#%Module
-#% description: Displays GRASS vector data in the active frame on the graphics monitor.
-#%End
-#%Flag
-#% key: v
-#% description: Run verbosely
-#%End
-#%Flag
-#% key: a
-#% description: Get colors from map table column (of form RRR:GGG:BBB)
-#% guisection: Colors
-#%End
-#%Flag
-#% key: c
-#% description: Random colors according to category number (or layer number if 'layer=-1' is given)
-#%End
-#%Flag
-#% key: i
-#% description: Use values from 'cats' option as line ID
-#% guisection: Query
-#%End
-#%Flag
-#% key: x
-#% description: Don't add to list of vectors and commands in monitor (it won't be drawn if the monitor is refreshed)
-#%End
-#%Option
-#% key: map
-#% type: string
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name of input vector map
-#% gisprompt: old,vector,vector
-#%End
-#%Option
-#% key: type
-#% type: string
-#% required: no
-#% multiple: yes
-#% options: point,line,boundary,centroid,area,face
-#% label: Type
-#% description: Feature type(s)
-#% answer: point,line,boundary,centroid,area,face
-#%End
-#%Option
-#% key: display
-#% type: string
-#% required: no
-#% multiple: yes
-#% options: shape,cat,topo,dir,attr,zcoor
-#% answer: shape
-#%End
-#%Option
-#% key: attrcol
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of column to be displayed
-#% guisection: Labels
-#%End
-#%Option
-#% key: icon
-#% type: string
-#% required: no
-#% multiple: no
-#% options: demo/muchomurka,demo/smrk,basic/arrow1,basic/arrow2,basic/box,basic/circle,basic/cross1,basic/cross2,basic/diamond,basic/marker,basic/octagon,basic/point,basic/pushpin,basic/star,basic/triangle,basic/x,extra/4pt_star,extra/adcp,extra/airport,extra/alpha_flag,extra/bridge,extra/compass,extra/dive_flag,extra/fancy_compass,extra/half-circle,extra/offbox_ne,extra/offbox_nw,extra/offbox_se,extra/offbox_sw,extra/pentagon,extra/target
-#% description: Point and centroid symbol
-#% answer: basic/x
-#% guisection: Symbols
-#%End
-#%Option
-#% key: size
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Symbol size
-#% answer: 8
-#%End
-#%Option
-#% key: layer
-#% type: integer
-#% required: no
-#% multiple: no
-#% label: Layer number
-#% description: Layer number. If -1, all layers are displayed.
-#% answer: 1
-#%End
-#%Option
-#% key: cats
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: range
-#% label: Category values
-#% description: Example: 1,3,7-9,13
-#%End
-#%Option
-#% key: where
-#% type: string
-#% required: no
-#% multiple: no
-#% key_desc: sql_query
-#% label: WHERE conditions of SQL statement without 'where' keyword.
-#% description: Example: income < 1000 and inhab >= 10000
-#%End
-#%Option
-#% key: width
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Line width
-#% answer: 0
-#% guisection: Lines
-#%End
-#%Option
-#% key: wcolumn
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of column for line widths (these values will be scaled by wscale)
-#%End
-#%Option
-#% key: wscale
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Scale factor for wcolumn
-#% answer: 1
-#%End
-#%Option
-#% key: color
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Line color
-#% answer: black
-#% gisprompt: color,grass,color
-#%End
-#%Option
-#% key: fcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Area fill color
-#% answer: 200:200:200
-#%End
-#%Option
-#% key: rgb_column
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Name of color definition column (for use with -a flag)
-#% answer: GRASSRGB
-#%End
-#%Option
-#% key: llayer
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Layer for labels (default: the given layer number)
-#%End
-#%Option
-#% key: lcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Label color
-#% answer: red
-#%End
-#%Option
-#% key: bgcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Label background color
-#% answer: none
-#%End
-#%Option
-#% key: bcolor
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Label border color
-#% answer: none
-#%End
-#%Option
-#% key: lsize
-#% type: integer
-#% required: no
-#% multiple: no
-#% description: Label size (pixels)
-#% answer: 8
-#%End
-#%Option
-#% key: font
-#% type: string
-#% required: no
-#% multiple: no
-#% description: Font name
-#%End
-#%Option
-#% key: xref
-#% type: string
-#% required: no
-#% multiple: no
-#% options: left,center,right
-#% description: Label horizontal justification
-#% answer: left
-#%End
-#%Option
-#% key: yref
-#% type: string
-#% required: no
-#% multiple: no
-#% options: top,center,bottom
-#% description: Label vertical justification
-#% answer: center
-#%End
-#%Option
-#% key: minreg
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Minimum region size (average from height and width) when map is displayed
-#%End
-#%Option
-#% key: maxreg
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Maximum region size (average from height and width) when map is displayed
-#%End
-#%Option
-#% key: render
-#% type: string
-#% required: no
-#% multiple: no
-#% options: g,r,d,c
-#% description: Rendering method for filled polygons
-#% answer: g
-#%End
-    exit 1
-fi
-fi
-# CODE GOES HERE
-    echo -n
-else
-    echo "WARNING: GRASS_PYCMDFILE - File not found. Run p.mon" >&2
-    exit 1
-fi
-#echo $NAME
-    mapset=""
-else
-fi
-#echo $MAPSET
-eval "`g.findfile element=vector file=${NAME} ${mapset}`"
-#echo $NAME
-#echo $MAPSET
-    CATLIST="None"
-else
-fi
-    VALLIST="None"
-else
-fi
-    OPACITY="100"
-else
-fi
-if [ "${GIS_FLAG_c}" -eq "1" ]; then
-    CATSCOLORS="True"
-else
-    CATSCOLORS="False"
-fi
-cmd="addvector ${name} ${mapset}"
Added: grass/branches/develbranch_6/gui/wxpython/scripts/p.vect.py
--- grass/branches/develbranch_6/gui/wxpython/scripts/p.vect.py	                        (rev 0)
+++ grass/branches/develbranch_6/gui/wxpython/scripts/p.vect.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -0,0 +1,367 @@
+# MODULE:       p.vect
+# AUTHOR(S):    Jachym Cepicky, Hamish Bowman
+# PURPOSE:      Displays vector map layer in the active map display window.
+#%module
+#% description: Displays vector map layer in the active map display window.
+#% keywords: display, vector
+#%end
+#%flag
+#% key: a
+#% description: Get colors from map table column (of form RRR:GGG:BBB)
+#% guisection: Colors
+#%end
+#%flag
+#% key: c
+#% description: Random colors according to category number (or layer number if 'layer=-1' is given)
+#%end
+#%flag
+#% key: i
+#% description: Use values from 'cats' option as feature id
+#%end
+#%flag
+#% key: z
+#% description: Colorize polygons according to z height
+#%end
+#%option
+#% key: map
+#% type: string
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name of input vector map
+#% gisprompt: old,vector,vector
+#%end
+#%option
+#% key: display
+#% type: string
+#% required: no
+#% multiple: yes
+#% options: shape,cat,topo,dir,attr,zcoor
+#% answer: shape
+#%end
+#%option
+#% key: type
+#% type: string
+#% required: no
+#% multiple: yes
+#% options: point,line,boundary,centroid,area,face
+#% description: Feature type
+#% answer: point,line,boundary,centroid,area,face
+#%end
+#%option
+#% key: layer
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Layer number (if -1, all layers are displayed)
+#% description: A single vector map can be connected to multiple database tables. This number determines which table to use.
+#% answer: 1
+#% gisprompt: old_layer,layer,layer_all
+#%end
+#%option
+#% key: cats
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: range
+#% label: Category values
+#% description: Example: 1,3,7-9,13
+#%end
+#%option
+#% key: where
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: sql_query
+#% label: WHERE conditions of SQL statement without 'where' keyword
+#% description: Example: income < 1000 and inhab >= 10000
+#%end
+#%option
+#% key: color
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Line color
+#% description: Either a standard GRASS color, R:G:B triplet, or "none"
+#% answer: black
+#% gisprompt: old_color,color,color_none
+#%end
+#%option
+#% key: fcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Area fill color
+#% answer: 200:200:200
+#%end
+#%option
+#% key: rgb_column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of color definition column (for use with -a flag)
+#% answer: GRASSRGB
+#% gisprompt: old_dbcolumn,dbcolumn,dbcolumn
+#%end
+#%option
+#% key: zcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: style
+#% description: Type of color table (for use with -z flag)
+#% answer: terrain
+#%end
+#%option
+#% key: width
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Line width
+#% answer: 0
+#% guisection: Lines
+#%end
+#%option
+#% key: wcolumn
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of column for line widths (these values will be scaled by wscale)
+#%end
+#%option
+#% key: wscale
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Scale factor for wcolumn
+#% answer: 1
+#%end
+#%option
+#% key: icon
+#% type: string
+#% required: no
+#% multiple: no
+#% options: basic/marker,basic/circle,basic/arrow1,basic/star,basic/point,basic/triangle,basic/box,basic/arrow2,basic/octagon,basic/cross2,basic/pushpin,basic/diamond,basic/cross1,basic/x,demo/smrk,demo/muchomurka,extra/dive_flag,extra/half-box,extra/bridge,extra/fiducial,extra/ping,extra/offbox_ne,extra/adcp,extra/alpha_flag,extra/4pt_star,extra/half-circle,extra/offbox_nw,extra/fancy_compass,extra/airport,extra/compass,extra/offbox_se,extra/fish,extra/target,extra/offbox_sw,extra/n_arrow1,extra/pentagon,extra/n_arrow2,geology/strike_circle,geology/strike_box,geology/strike_line,geology/strike_triangle
+#% description: Point and centroid symbol
+#% answer: basic/x
+#% guisection: Symbols
+#%end
+#%option
+#% key: size
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Symbol size
+#% answer: 5
+#%end
+#%option
+#% key: size_column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of numeric column containing symbol size
+#%end
+#%option
+#% key: rot_column
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% label: Name of numeric column containing symbol rotation angle
+#% description: Measured in degrees CCW from east
+#%end
+#%option
+#% key: llayer
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Layer number or name
+#% description: Layer number for labels (default: the given layer number)
+#% answer: 1
+#% guisection: Labels
+#%end
+#%option
+#% key: attrcol
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: name
+#% description: Name of column to be displayed
+#%end
+#%option
+#% key: lcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Label color
+#% description: Either a standard color name or R:G:B triplet
+#% answer: red
+#%end
+#%option
+#% key: bgcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Label background color
+#% answer: none
+#%end
+#%option
+#% key: bcolor
+#% type: string
+#% required: no
+#% multiple: no
+#% label: Label border color
+#% answer: none
+#%end
+#%option
+#% key: lsize
+#% type: integer
+#% required: no
+#% multiple: no
+#% description: Label size (pixels)
+#% answer: 8
+#%end
+#%option
+#% key: font
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Font name
+#%end
+#%option
+#% key: encoding
+#% type: string
+#% required: no
+#% multiple: no
+#% description: Text encoding
+#%end
+#%option
+#% key: xref
+#% type: string
+#% required: no
+#% multiple: no
+#% options: left,center,right
+#% description: Label horizontal justification
+#% answer: left
+#%end
+#%option
+#% key: yref
+#% type: string
+#% required: no
+#% multiple: no
+#% options: top,center,bottom
+#% description: Label vertical justification
+#% answer: center
+#%end
+#%option
+#% key: minreg
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Minimum region size (average from height and width) when map is displayed
+#%end
+#%option
+#% key: maxreg
+#% type: double
+#% required: no
+#% multiple: no
+#% description: Maximum region size (average from height and width) when map is displayed
+#%end
+#%option
+#% key: opacity
+#% type: string
+#% required: no
+#% multiple: no
+#% key_desc: val
+#% answer: 100
+#%end
+import sys
+import os
+    line = cmd
+        if val != "":
+        if val == True:
+    return line
+def main():
+        return
+    fp.close()
+    main()
Property changes on: grass/branches/develbranch_6/gui/wxpython/scripts/p.vect.py
   + text/x-python
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass/branches/develbranch_6/gui/wxpython/wxgui.py
--- grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/gui/wxpython/wxgui.py	2010-08-09 18:50:29 UTC (rev 43027)
@@ -96,14 +96,15 @@
     GIS. Includes command console page for typing GRASS (and other)
     commands, tree widget page for managing map layers.
-    def __init__(self, parent, id=wx.ID_ANY, title=_("GRASS GIS Layer Manager"),
-                 workspace=None):
+    def __init__(self, parent, id = wx.ID_ANY, title = _("GRASS GIS Layer Manager"),
+                 workspace = None,
+                 size = (575, 450), style = wx.DEFAULT_FRAME_STYLE, **kwargs):
         self.parent    = parent
         self.baseTitle = title
         self.iconsize  = (16, 16)
-        wx.Frame.__init__(self, parent=parent, id=id, size=(550, 450),
-                          style=wx.DEFAULT_FRAME_STYLE)
+        wx.Frame.__init__(self, parent = parent, id = id, size = size,
+                          style = style, **kwargs)
         self.SetTitle(self.baseTitle)
         self.SetName("LayerManager")
@@ -1182,7 +1183,6 @@
         return self.curr_page.maptree.mapdisplay
-    # toolBar button handlers
     def OnAddRaster(self, event):
         """!Add raster map layer"""
         # start new map display if no display is available
@@ -1190,48 +1190,49 @@
             self.NewDisplay(show=False)
         self.AddRaster(event)
+    def OnAddRaster3D(self, event):
+        """!Add 3D raster map layer"""
+        # start new map display if no display is available
+        if not self.curr_page:
+            self.NewDisplay(show=False)
+        self.AddRaster3D(event)
     def OnAddRasterMisc(self, event):
         """!Add raster menu"""
         point = wx.GetMousePosition()
         rastmenu = wx.Menu()
-        # add items to the menu
-        if self.curr_page.maptree.mapdisplay.toolbars['nviz']:
-            addrast3d = wx.MenuItem(rastmenu, -1, Icons ["addrast3d"].GetLabel())
-            addrast3d.SetBitmap(Icons["addrast3d"].GetBitmap (self.iconsize))
-            rastmenu.AppendItem(addrast3d)
-            self.Bind(wx.EVT_MENU, self.AddRaster3d, addrast3d)
         addshaded = wx.MenuItem(rastmenu, -1, Icons ["addshaded"].GetLabel())
         addshaded.SetBitmap(Icons["addshaded"].GetBitmap (self.iconsize))
         rastmenu.AppendItem(addshaded)
         self.Bind(wx.EVT_MENU, self.AddShaded, addshaded)
         addrgb = wx.MenuItem(rastmenu, -1, Icons["addrgb"].GetLabel())
         addrgb.SetBitmap(Icons["addrgb"].GetBitmap(self.iconsize))
         rastmenu.AppendItem(addrgb)
         self.Bind(wx.EVT_MENU, self.AddRGB, addrgb)
         addhis = wx.MenuItem(rastmenu, -1, Icons ["addhis"].GetLabel())
         addhis.SetBitmap(Icons["addhis"].GetBitmap (self.iconsize))
         rastmenu.AppendItem(addhis)
         self.Bind(wx.EVT_MENU, self.AddHIS, addhis)
         addrastarrow = wx.MenuItem(rastmenu, -1, Icons ["addrarrow"].GetLabel())
         addrastarrow.SetBitmap(Icons["addrarrow"].GetBitmap (self.iconsize))
         rastmenu.AppendItem(addrastarrow)
         self.Bind(wx.EVT_MENU, self.AddRastarrow, addrastarrow)
         addrastnums = wx.MenuItem(rastmenu, -1, Icons ["addrnum"].GetLabel())
         addrastnums.SetBitmap(Icons["addrnum"].GetBitmap (self.iconsize))
         rastmenu.AppendItem(addrastnums)
         self.Bind(wx.EVT_MENU, self.AddRastnum, addrastnums)
         # Popup the menu.  If an item is selected then its handler
         # will be called before PopupMenu returns.
         self.PopupMenu(rastmenu)
@@ -1316,7 +1317,7 @@
         self.notebook.SetSelection(0)
         self.curr_page.maptree.AddLayer('raster')
-    def AddRaster3d(self, event):
+    def AddRaster3D(self, event):
         self.curr_page.maptree.AddLayer('3d-raster')
Modified: grass/branches/develbranch_6/include/Make/Platform.make.in
--- grass/branches/develbranch_6/include/Make/Platform.make.in	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/include/Make/Platform.make.in	2010-08-09 18:50:29 UTC (rev 43027)
@@ -249,8 +249,8 @@
 MINGW		    = @MINGW32@
 MACOSX_APP	    = @MACOSX_APP@
-MACOSX_ARCHS    = @MACOSX_ARCHS@
-MACOSX_SDK      = @MACOSX_SDK@
+MACOSX_ARCHS        = @MACOSX_ARCHS@
+MACOSX_SDK          = @MACOSX_SDK@
 # Cross compilation
 CROSS_COMPILING = @CROSS_COMPILING@
Modified: grass/branches/develbranch_6/include/Make/Python.make
--- grass/branches/develbranch_6/include/Make/Python.make	2010-08-09 18:16:56 UTC (rev 43026)
+++ grass/branches/develbranch_6/include/Make/Python.make	2010-08-09 18:50:29 UTC (rev 43027)
@@ -8,6 +8,8 @@
 endif
 PYMOD_CFLAGS = $(SHLIB_CFLAGS) $(PYTHONINC) $(PYTHON_CFLAGS)
+PY_SOURCES := $(wildcard *.py)
 %.pyc: %.py
 	$(PYTHON) -m py_compile $<
