[GRASS-SVN] r43959 - grass/branches/develbranch_6/lib/python
Mon Oct 18 05:59:37 EDT 2010
Author: martinl
Date: 2010-10-18 02:59:37 -0700 (Mon, 18 Oct 2010)
New Revision: 43959
Added:
   grass/branches/develbranch_6/lib/python/pythonlib.dox
Removed:
   grass/branches/develbranch_6/lib/python/grasspythonlib.dox
   grass/branches/develbranch_6/lib/python/Makefile
dox file renamed
(merge r43958 from trunk)
Modified: grass/branches/develbranch_6/lib/python/Makefile
--- grass/branches/develbranch_6/lib/python/Makefile	2010-10-18 09:54:42 UTC (rev 43958)
+++ grass/branches/develbranch_6/lib/python/Makefile	2010-10-18 09:59:37 UTC (rev 43959)
@@ -36,4 +36,4 @@
 	$(INSTALL_DATA) $< $@
 #doxygen:
-DOXNAME=grasspython
+DOXNAME = python
Deleted: grass/branches/develbranch_6/lib/python/grasspythonlib.dox
--- grass/branches/develbranch_6/lib/python/grasspythonlib.dox	2010-10-18 09:54:42 UTC (rev 43958)
+++ grass/branches/develbranch_6/lib/python/grasspythonlib.dox	2010-10-18 09:59:37 UTC (rev 43959)
@@ -1,246 +0,0 @@
-/*! \page pythonlib GRASS Python Scripting Library
-by GRASS Development Team (http://grass.osgeo.org)
-\section pythonIntro Introduction
-The code in <tt>lib/python/</tt> provides <b>grass.script</b> in order
-to support GRASS scripts written in Python. The <tt>scripts/</tt>
-directory of GRASS contains a series of examples actually provided to
-the end users.
-See code in:
-- core.py
-- db.py
-- raster.py
-- vector.py
-<b>Table of content</b>
-- \subpage pythonScripting
-- \subpage pythonModules
- - \subpage pythonCore
- - \subpage pythonDb
- - \subpage pythonRaster
- - \subpage pythonVector
-\section pythonScripting GRASS scripting tasks for Python provided by "grass.script"
-Usage:
-\code
-import grass.script as grass
-\endcode
-or just import selected module, e.g.
-\code
-from grass.script import core as grass
-\endcode
-Sample script
-\code
-#!/usr/bin/env python
-#%module
-#% description: Checks if vector map is 3D
-#% keywords: vector
-#%end
-#%option
-#% key: map
-#% type: string
-#% gisprompt: old,vector,vector
-#% key_desc: name
-#% description: Name of vector map
-#% required: yes
-#%end
-import sys
-def main():
-    info = grass.parse_command('v.info',
-                               flags = 't',
-                               map = options['map'])
-    if info['map3d'] == '1':
-        print 'Vector map is 3D'
-    else:
-        print 'Vector map is 2D'
-    return 0
-if __name__ == "__main__":
-    options, flags = grass.parser()
-    sys.exit(main())
-\endcode
-\section pythonModules List of modules
-\subsection pythonCore Core
-<b>GRASS-oriented interface to subprocess module</b>
- - exec_command()
- - feed_command()
- - make_command()
- - parse_command()
- - pipe_command()
- - read_command()
- - run_command()
- - start_command()
- - write_command()
-<b>Interface to g.message</b>
-These all run g.message, differing only in which flag (if any) is
-used. fatal() is error(), but also calls sys.exit(1).
- - debug()
- - error()
- - fatal()
- - info()
- - message()
- - verbose()
- - warning()
-<b>Interface to g.parser</b>
-Interface to g.parser, intended to be run from the top-level, e.g.
-\code
-	if __name__ == "__main__":
-	    main()
-\endcode
- - parser()
-<b>Interface to g.tempfile</b>
-Returns the name of a temporary file, created with g.tempfile.
- - tempfile()
-<b>Key-value parsers</b>
- - parse_key_val()
-<b>Interface to g.gisenv</b>
- - gisenv()
-<b>Interface to g.region</b>
- - del_temp_region()
- - region()
- - use_temp_region()
-<b>Interface to g.findfile</b>
- - find_file()
-<b>Interface to g.list</b>
- - list_grouped()
- - list_pairs()
- - list_strings()
- - mlist_grouped()
-<b>Color parsing</b>
- - parse_color()
-<b>Check GRASS environment variables</b>
- - overwrite()
- - verbosity()
-<b>Various utilities, not specific to GRASS</b>
- - basename()
- - find_program()
- - try_remove()
- - try_rmdir()
- - float_or_dms()
-\section pythonDb Database
-Interface for <tt>db.*</tt> modules.
-\code
-from grass.script import db as grass
-\endcode
- - db_connection()
- - db_describe()
- - db_select()
-\section pythonRaster Raster
-Interface for <tt>r.*</tt> modules.
-\code
-from grass.script import raster as grass
-\endcode
- - raster_history()
- - raster_info()
- - mapcalc()
-\section pythonVector Vector
-Interface for <tt>v.*</tt> modules.
-\code
-from grass.script import vector as grass
-\endcode
- - vector_columns()
- - vector_db()
- - vector_db_select()
- - vector_history()
- - vector_info_topo()
- - vector_layer_db()
-\section pythonAuthors Authors
- Glynn Clements
- Martin Landa <landa.martin gmail.com>
Copied: grass/branches/develbranch_6/lib/python/pythonlib.dox (from rev 43958, grass/trunk/lib/python/pythonlib.dox)
--- grass/branches/develbranch_6/lib/python/pythonlib.dox	                        (rev 0)
+++ grass/branches/develbranch_6/lib/python/pythonlib.dox	2010-10-18 09:59:37 UTC (rev 43959)
@@ -0,0 +1,246 @@
+/*! \page pythonlib GRASS Python Scripting Library
+by GRASS Development Team (http://grass.osgeo.org)
+\section pythonIntro Introduction
+The code in <tt>lib/python/</tt> provides <b>grass.script</b> in order
+to support GRASS scripts written in Python. The <tt>scripts/</tt>
+directory of GRASS contains a series of examples actually provided to
+the end users.
+See code in:
+- core.py
+- db.py
+- raster.py
+- vector.py
+<b>Table of content</b>
+- \subpage pythonScripting
+- \subpage pythonModules
+ - \subpage pythonCore
+ - \subpage pythonDb
+ - \subpage pythonRaster
+ - \subpage pythonVector
+\section pythonScripting GRASS scripting tasks for Python provided by "grass.script"
+Usage:
+\code
+import grass.script as grass
+\endcode
+or just import selected module, e.g.
+\code
+from grass.script import core as grass
+\endcode
+Sample script
+\code
+#!/usr/bin/env python
+#%module
+#% description: Checks if vector map is 3D
+#% keywords: vector
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
+#% description: Name of vector map
+#% required: yes
+#%end
+import sys
+def main():
+    info = grass.parse_command('v.info',
+                               flags = 't',
+                               map = options['map'])
+    if info['map3d'] == '1':
+        print 'Vector map is 3D'
+    else:
+        print 'Vector map is 2D'
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
+\endcode
+\section pythonModules List of modules
+\subsection pythonCore Core
+<b>GRASS-oriented interface to subprocess module</b>
+ - exec_command()
+ - feed_command()
+ - make_command()
+ - parse_command()
+ - pipe_command()
+ - read_command()
+ - run_command()
+ - start_command()
+ - write_command()
+<b>Interface to g.message</b>
+These all run g.message, differing only in which flag (if any) is
+used. fatal() is error(), but also calls sys.exit(1).
+ - debug()
+ - error()
+ - fatal()
+ - info()
+ - message()
+ - verbose()
+ - warning()
+<b>Interface to g.parser</b>
+Interface to g.parser, intended to be run from the top-level, e.g.
+\code
+	if __name__ == "__main__":
+	    main()
+\endcode
+ - parser()
+<b>Interface to g.tempfile</b>
+Returns the name of a temporary file, created with g.tempfile.
+ - tempfile()
+<b>Key-value parsers</b>
+ - parse_key_val()
+<b>Interface to g.gisenv</b>
+ - gisenv()
+<b>Interface to g.region</b>
+ - del_temp_region()
+ - region()
+ - use_temp_region()
+<b>Interface to g.findfile</b>
+ - find_file()
+<b>Interface to g.list</b>
+ - list_grouped()
+ - list_pairs()
+ - list_strings()
+ - mlist_grouped()
+<b>Color parsing</b>
+ - parse_color()
+<b>Check GRASS environment variables</b>
+ - overwrite()
+ - verbosity()
+<b>Various utilities, not specific to GRASS</b>
+ - basename()
+ - find_program()
+ - try_remove()
+ - try_rmdir()
+ - float_or_dms()
+\section pythonDb Database
+Interface for <tt>db.*</tt> modules.
+\code
+from grass.script import db as grass
+\endcode
+ - db_connection()
+ - db_describe()
+ - db_select()
+\section pythonRaster Raster
+Interface for <tt>r.*</tt> modules.
+\code
+from grass.script import raster as grass
+\endcode
+ - raster_history()
+ - raster_info()
+ - mapcalc()
+\section pythonVector Vector
+Interface for <tt>v.*</tt> modules.
+\code
+from grass.script import vector as grass
+\endcode
+ - vector_columns()
+ - vector_db()
+ - vector_db_select()
+ - vector_history()
+ - vector_info_topo()
+ - vector_layer_db()
+\section pythonAuthors Authors
+ Glynn Clements
+ Martin Landa <landa.martin gmail.com>
