[GRASS-SVN] r43960 - grass/branches/releasebranch_6_4/lib/python
Mon Oct 18 06:01:46 EDT 2010
Author: martinl
Date: 2010-10-18 03:01:46 -0700 (Mon, 18 Oct 2010)
New Revision: 43960
Added:
   grass/branches/releasebranch_6_4/lib/python/pythonlib.dox
   grass/branches/releasebranch_6_4/lib/python/Makefile
add pythonlib dox file
Modified: grass/branches/releasebranch_6_4/lib/python/Makefile
--- grass/branches/releasebranch_6_4/lib/python/Makefile	2010-10-18 09:59:37 UTC (rev 43959)
+++ grass/branches/releasebranch_6_4/lib/python/Makefile	2010-10-18 10:01:46 UTC (rev 43960)
@@ -30,4 +30,4 @@
 	$(INSTALL_DATA) $< $@
 #doxygen:
-DOXNAME=grasspython
+DOXNAME = python
Copied: grass/branches/releasebranch_6_4/lib/python/pythonlib.dox (from rev 43958, grass/trunk/lib/python/pythonlib.dox)
--- grass/branches/releasebranch_6_4/lib/python/pythonlib.dox	                        (rev 0)
+++ grass/branches/releasebranch_6_4/lib/python/pythonlib.dox	2010-10-18 10:01:46 UTC (rev 43960)
@@ -0,0 +1,246 @@
+/*! \page pythonlib GRASS Python Scripting Library
+by GRASS Development Team (http://grass.osgeo.org)
+\section pythonIntro Introduction
+The code in <tt>lib/python/</tt> provides <b>grass.script</b> in order
+to support GRASS scripts written in Python. The <tt>scripts/</tt>
+directory of GRASS contains a series of examples actually provided to
+the end users.
+See code in:
+- core.py
+- db.py
+- raster.py
+- vector.py
+<b>Table of content</b>
+- \subpage pythonScripting
+- \subpage pythonModules
+ - \subpage pythonCore
+ - \subpage pythonDb
+ - \subpage pythonRaster
+ - \subpage pythonVector
+\section pythonScripting GRASS scripting tasks for Python provided by "grass.script"
+Usage:
+\code
+import grass.script as grass
+\endcode
+or just import selected module, e.g.
+\code
+from grass.script import core as grass
+\endcode
+Sample script
+\code
+#!/usr/bin/env python
+#%module
+#% description: Checks if vector map is 3D
+#% keywords: vector
+#%end
+#%option
+#% key: map
+#% type: string
+#% gisprompt: old,vector,vector
+#% key_desc: name
+#% description: Name of vector map
+#% required: yes
+#%end
+import sys
+def main():
+    info = grass.parse_command('v.info',
+                               flags = 't',
+                               map = options['map'])
+    if info['map3d'] == '1':
+        print 'Vector map is 3D'
+    else:
+        print 'Vector map is 2D'
+    return 0
+if __name__ == "__main__":
+    options, flags = grass.parser()
+    sys.exit(main())
+\endcode
+\section pythonModules List of modules
+\subsection pythonCore Core
+<b>GRASS-oriented interface to subprocess module</b>
+ - exec_command()
+ - feed_command()
+ - make_command()
+ - parse_command()
+ - pipe_command()
+ - read_command()
+ - run_command()
+ - start_command()
+ - write_command()
+<b>Interface to g.message</b>
+These all run g.message, differing only in which flag (if any) is
+used. fatal() is error(), but also calls sys.exit(1).
+ - debug()
+ - error()
+ - fatal()
+ - info()
+ - message()
+ - verbose()
+ - warning()
+<b>Interface to g.parser</b>
+Interface to g.parser, intended to be run from the top-level, e.g.
+\code
+	if __name__ == "__main__":
+	    main()
+\endcode
+ - parser()
+<b>Interface to g.tempfile</b>
+Returns the name of a temporary file, created with g.tempfile.
+ - tempfile()
+<b>Key-value parsers</b>
+ - parse_key_val()
+<b>Interface to g.gisenv</b>
+ - gisenv()
+<b>Interface to g.region</b>
+ - del_temp_region()
+ - region()
+ - use_temp_region()
+<b>Interface to g.findfile</b>
+ - find_file()
+<b>Interface to g.list</b>
+ - list_grouped()
+ - list_pairs()
+ - list_strings()
+ - mlist_grouped()
+<b>Color parsing</b>
+ - parse_color()
+<b>Check GRASS environment variables</b>
+ - overwrite()
+ - verbosity()
+<b>Various utilities, not specific to GRASS</b>
+ - basename()
+ - find_program()
+ - try_remove()
+ - try_rmdir()
+ - float_or_dms()
+\section pythonDb Database
+Interface for <tt>db.*</tt> modules.
+\code
+from grass.script import db as grass
+\endcode
+ - db_connection()
+ - db_describe()
+ - db_select()
+\section pythonRaster Raster
+Interface for <tt>r.*</tt> modules.
+\code
+from grass.script import raster as grass
+\endcode
+ - raster_history()
+ - raster_info()
+ - mapcalc()
+\section pythonVector Vector
+Interface for <tt>v.*</tt> modules.
+\code
+from grass.script import vector as grass
+\endcode
+ - vector_columns()
+ - vector_db()
+ - vector_db_select()
+ - vector_history()
+ - vector_info_topo()
+ - vector_layer_db()
+\section pythonAuthors Authors
+ Glynn Clements
+ Martin Landa <landa.martin gmail.com>
