[GRASS-SVN] r45955 - grass/branches/releasebranch_6_4/vector/v.kernel
Wed Apr 13 15:02:30 EDT 2011
Author: martinl
Date: 2011-04-13 12:02:30 -0700 (Wed, 13 Apr 2011)
New Revision: 45955
   grass/branches/releasebranch_6_4/vector/v.kernel/description.html
   grass/branches/releasebranch_6_4/vector/v.kernel/function.c
   grass/branches/releasebranch_6_4/vector/v.kernel/global.h
   grass/branches/releasebranch_6_4/vector/v.kernel/main.c
Radim Blazek: additional kernel functions, equal split on networks (backport from trunk r45393, 45398, r45406)
      (merge r45407 from devbr6)
Modified: grass/branches/releasebranch_6_4/vector/v.kernel/description.html
--- grass/branches/releasebranch_6_4/vector/v.kernel/description.html	2011-04-13 16:28:23 UTC (rev 45954)
+++ grass/branches/releasebranch_6_4/vector/v.kernel/description.html	2011-04-13 19:02:30 UTC (rev 45955)
@@ -1,9 +1,16 @@
 <H2>DESCRIPTION</H2>
-Generates a raster density map from vector points data using
-a moving 2D isotropic Gaussian kernel or
-optionally generates a vector density map on vector network
-with a 1D kernel.
+<em>v.kernel</em> generates a raster density map from vector points data using
+a moving kernel. Available <a href="http://en.wikipedia.org/wiki/Kernel_(statistics)#Kernel_functions_in_common_use">kernel density functions</a> are <em>uniform,
+triangular, epanechnikov, quartic, triweight, gaussian, cosine</em>,
+default is <em>gaussian</em>.
+<p>
+The module can also generate a vector density map on a vector network.
+Conventional kernel functions produce biased estimates by overestimating
+the densities around network nodes, whereas the equal split method of
+Okabe et al. (2009) produces unbiased density estimates. The equal split
+method uses the kernel function selected with the <em>kernel</em> option
+and can be enabled with <em>node=split</em>.
 <H2>NOTES</H2>
@@ -18,16 +25,23 @@
 <H2>LIMITATIONS</H2>
-The modules only considers the presence of point, but not
+The module only considers the presence of points, but not
 (yet) any attribute values.
 <H2>SEE ALSO</H2>
 <A HREF="v.surf.rst.html">v.surf.rst</A>
-<H2>AUTHOR</H2>
+<H2>REFERENCES</H2>
+Okabe, A., Satoh, T., Sugihara, K. (2009). <i>A kernel density estimation
+method for networks, its computational method and a GIS-based tool</i>.
+<b>International Journal of Geographical Information Science</b>, Vol 23(1),
+pp. 7-32.<br>
+DOI: <a href="http://dx.doi.org/10.1080/13658810802475491">10.1080/13658810802475491</a>
-Stefano Menegon, <a href=http://mpa.itc.it>ITC-irst</a>, Trento, Italy
+<H2>AUTHORS</H2>
+Stefano Menegon, <a href="http://mpa.itc.it/">ITC-irst</a>, Trento, Italy
 <BR>
-Radim Blazek (network part)
+Radim Blazek (additional kernel density functions and network part)
 <p><i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/vector/v.kernel/function.c
--- grass/branches/releasebranch_6_4/vector/v.kernel/function.c	2011-04-13 16:28:23 UTC (rev 45954)
+++ grass/branches/releasebranch_6_4/vector/v.kernel/function.c	2011-04-13 19:02:30 UTC (rev 45955)
@@ -1,9 +1,10 @@
 #include <math.h>
 #include <grass/gis.h>
 #include <grass/Vect.h>
+#include <grass/glocale.h>
 #include "global.h"
+/*********************** Gaussian ****************************/
 /* probability for gaussian distribution */
 double gaussian2dBySigma(double d, double sigma)
@@ -63,10 +64,8 @@
 	res = 1. / (M_PI * (d * d + rs * rs));
     else {
-	res =
-	    segno(a) * (a / M_PI) * (pow(rs, 2. * a)) * (1 /
-							 pow(d * d + rs * rs,
-							     lambda));
+	res = segno(a) * (a / M_PI) * (pow(rs, 2. * a)) *
+	    (1 / pow(d * d + rs * rs, lambda));
     /*  res=1./(M_PI*(d*d+rs*rs)); */
@@ -79,6 +78,7 @@
     double d;
     d = sqrt(-2 * sigma * sigma * log(prob * M_PI * 2 * sigma * sigma));
     return (d);
@@ -97,3 +97,150 @@
     return sqrt(out);
+double gaussianKernel2(int dimension, double bandwidth, double x)
+    double term =
+	1. / (pow(bandwidth, dimension) * pow((2. * M_PI), dimension / 2.));
+    x /= bandwidth;
+    return (term * exp(-(x * x) / 2.));
+/* Note: these functions support currently only 1D and 2D, consider this for example
+ * before using them for 3d grid */
+double uniformKernel(int dimension, double bandwidth, double x)
+    double k;
+    if (x > bandwidth)
+	return 0;
+    if (dimension == 2)
+	k = 2. / (M_PI * pow(bandwidth, 2));
+    else
+	k = 1. / bandwidth;
+    x /= bandwidth;
+    return k * (1. / 2);
+double triangularKernel(int dimension, double bandwidth, double x)
+    double k;
+	return 0;
+	k = 3. / (M_PI * pow(bandwidth, 2));
+    else
+    x /= bandwidth;
+    return k * (1 - x);
+double epanechnikovKernel(int dimension, double bandwidth, double x)
+    double k;
+	return 0;
+	k = 8. / (M_PI * 3. * pow(bandwidth, 2));
+    else
+    x /= bandwidth;
+    return k * (3. / 4. * (1 - x * x));
+double quarticKernel(int dimension, double bandwidth, double x)
+    double k;
+	return 0;
+	k = 16. / (M_PI * 5. * pow(bandwidth, 2));
+    else
+    x /= bandwidth;
+    return k * (15. / 16. * pow(1 - x * x, 2));
+double triweightKernel(int dimension, double bandwidth, double x)
+    double k;
+	return 0;
+	k = 128. / (M_PI * 35. * pow(bandwidth, 2));
+    else
+    x /= bandwidth;
+    return k * (35. / 32 * pow(1 - x * x, 3));
+double cosineKernel(int dimension, double bandwidth, double x)
+    double k;
+	return 0;
+	k = 1. / (2 * (M_PI / 2 - 1) * pow(bandwidth, 2));
+    else
+    x /= bandwidth;
+    return k * (M_PI / 4. * cos(M_PI / 2. * x));
+double kernelFunction(int function, int dimension, double bandwidth, double x)
+    if (dimension > 2 && function != KERNEL_GAUSSIAN) {
+	G_fatal_error(_("Dimension > 2 supported only by gaussian function"));
+    switch (function) {
+    case KERNEL_UNIFORM:
+	return uniformKernel(dimension, bandwidth, x);
+	break;
+    case KERNEL_TRIANGULAR:
+	return triangularKernel(dimension, bandwidth, x);
+	break;
+    case KERNEL_EPANECHNIKOV:
+	return epanechnikovKernel(dimension, bandwidth, x);
+	break;
+    case KERNEL_QUARTIC:
+	return quarticKernel(dimension, bandwidth, x);
+	break;
+    case KERNEL_TRIWEIGHT:
+	return triweightKernel(dimension, bandwidth, x);
+	break;
+    case KERNEL_GAUSSIAN:
+	return gaussianKernel2(dimension, bandwidth, x);
+	break;
+    case KERNEL_COSINE:
+	return cosineKernel(dimension, bandwidth, x);
+	break;
+    G_fatal_error("Unknown kernel function");
Modified: grass/branches/releasebranch_6_4/vector/v.kernel/global.h
--- grass/branches/releasebranch_6_4/vector/v.kernel/global.h	2011-04-13 16:28:23 UTC (rev 45954)
+++ grass/branches/releasebranch_6_4/vector/v.kernel/global.h	2011-04-13 19:02:30 UTC (rev 45955)
@@ -1,5 +1,22 @@
+#define NODE_NONE                   0
+/* According Okabe 2009 */
+#define NODE_SIMILAR                1
+#define NODE_EQUAL_SPLIT            2
+#define NODE_CONTINUOUS_EQUAL_SPLIT 3
+#define KERNEL_UNIFORM      0
+#define KERNEL_TRIANGULAR   1
+#define KERNEL_EPANECHNIKOV 2
+#define KERNEL_QUARTIC      3
+#define KERNEL_TRIWEIGHT    4
+#define KERNEL_GAUSSIAN     5
+#define KERNEL_COSINE       6
+double kernelFunction(int function, int dimension, double bandwidth, double x);
 double euclidean_distance(double *x, double *y, int n);
 double gaussian2dBySigma(double d, double sigma);
 double gaussianFunction(double x, double sigma, double dimension);
@@ -18,7 +35,7 @@
 double compute_all_net_distances(struct Map_info *In, struct Map_info *Net,
 				 double netmax, double **dists, double dmax);
 void compute_distance(double N, double E, struct Map_info *In, double sigma,
-		      double term, double *gaussian, double dmax);
+		      double term, double *gaussian, double dmax, int kernel_function);
 void compute_net_distance(double x, double y, struct Map_info *In,
 			  struct Map_info *Net, double netmax, double sigma,
+			  double term, double *gaussian, double dmax, int node_method, int kernel_function);
Modified: grass/branches/releasebranch_6_4/vector/v.kernel/main.c
--- grass/branches/releasebranch_6_4/vector/v.kernel/main.c	2011-04-13 16:28:23 UTC (rev 45954)
+++ grass/branches/releasebranch_6_4/vector/v.kernel/main.c	2011-04-13 19:02:30 UTC (rev 45955)
@@ -4,11 +4,12 @@
 * MODULE:       v.kernel
 * AUTHOR(S):    Stefano Menegon, ITC-irst, Trento, Italy
+*               Radim Blazek (additional kernel functions, network part)
 * PURPOSE:      Generates a raster density map from vector points data using
-*               a moving 2D isotropic Gaussian kernel or
+*               a moving kernel function or
 *               optionally generates a vector density map on vector network
 *               with a 1D kernel
-* COPYRIGHT:    (C) 2004 by the GRASS Development Team
+* COPYRIGHT:    (C) 2004-2011 by the GRASS Development Team
 *               This program is free software under the GNU General Public
 *   	    	License (>=v2). Read the file COPYING that comes with GRASS
@@ -33,7 +34,7 @@
 static double dimension = 2.;
-    /* define score function L(window size) */
+/* define score function L(window size) */
 double L(double smooth)
     int ii;
@@ -54,18 +55,11 @@
     if (!net)
 	resL *= 2.;
-    resL =
-	(1. / (pow(n, 2.) * pow(smooth, dimension))) * (resL +
-							n *
-							(gaussianFunction
-							 (0., 2.,
-							  dimension) -
-							 2. *
-							 gaussianFunction(0.,
-									  1.,
-									  dimension)))
-	+ (2. / (n * pow(smooth, dimension))) * gaussianFunction(0., 1.,
-								 dimension);
+    resL = (1. / (pow(n, 2.) * pow(smooth, dimension))) *
+           (resL + n * (gaussianFunction(0., 2., dimension) -
+	   2. * gaussianFunction(0., 1., dimension))) +
+	   gaussianFunction(0., 1., dimension);
     /* resL = (1./(pow(n,2.)*pow(smooth,dimension))) * (resL + n*( gaussianFunction(0.,2.,dimension) - 2. * gaussianKernel(0.,term)) ) + (2./(n*pow(smooth,dimension)))*gaussianKernel(0.,term);   */
     G_debug(3, "smooth = %e resL = %e", smooth, resL);
@@ -80,12 +74,13 @@
     struct Option *in_opt, *net_opt, *out_opt;
     struct Option *stddev_opt, *dsize_opt, *segmax_opt, *netmax_opt,
-	*multip_opt;
-    struct Flag *flag_o, *flag_v, *flag_q;
+	*multip_opt, *node_opt, *kernel_opt;
+    struct Flag *flag_o, *flag_q, *flag_normalize, *flag_multiply;
     char *mapset;
     struct Map_info In, Net, Out;
     int fdout = 0, maskfd = 0;
+    int node_method, kernel_function;
     int row, col;
     struct Cell_head window;
     double gaussian;
@@ -101,6 +96,7 @@
     double term;
     double gausmax = 0;
+    int notreachable = 0;
     /* Initialize the GIS calls */
     G_gisinit(argv[0]);
@@ -108,8 +104,8 @@
     module = G_define_module();
     module->keywords = _("vector, kernel density");
     module->description =
-	_("Generates a raster density map from vector points data using a moving 2D isotropic Gaussian kernel or "
-	 "optionally generates a vector density map on vector network with a 1D kernel.");
+	_("Generates a raster density map from vector point data using a moving kernel or "
+	 "optionally generates a vector density map on a vector network.");
     in_opt = G_define_standard_option(G_OPT_V_INPUT);
     in_opt->description = _("Input vector with training points");
@@ -160,6 +156,26 @@
     multip_opt->description = _("Multiply the density result by this number");
     multip_opt->answer = "1.";
+    node_opt = G_define_option();
+    node_opt->key = "node";
+    node_opt->type = TYPE_STRING;
+    node_opt->required = YES;
+    node_opt->description = _("Node method");
+    node_opt->options = "none,split";
+    node_opt->answer = "none";
+    node_opt->descriptions =
+	_("none;No method applied at nodes with more than 2 arcs;"
+	  "split;Equal split (Okabe 2009) applied at nodes;");
+    kernel_opt = G_define_option();
+    kernel_opt->key = "kernel";
+    kernel_opt->type = TYPE_STRING;
+    kernel_opt->required = YES;
+    kernel_opt->description = _("Kernel function");
+    kernel_opt->options =
+	"uniform,triangular,epanechnikov,quartic,triweight,gaussian,cosine";
+    kernel_opt->answer = "gaussian";
     flag_o = G_define_flag();
     flag_o->key = 'o';
     flag_o->description =
@@ -170,11 +186,16 @@
     flag_q->description =
 	_("Only calculate optimal standard deviation and exit (no map is written)");
-    /* please, remove before GRASS 7 released */
-    flag_v = G_define_flag();
-    flag_v->key = 'v';
-    flag_v->description = _("Run verbosely");
+    flag_normalize = G_define_flag();
+    flag_normalize->key = 'n';
+    flag_normalize->description =
+	_("In network mode, normalize values by sum of density multiplied by length of each segment. Integral over the output map then gives 1.0 * mult");
+    flag_multiply = G_define_flag();
+    flag_multiply->key = 'm';
+    flag_multiply->description =
+	_("In network mode, multiply the result by number of input points.");
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
@@ -185,14 +206,43 @@
     netmax = atof(netmax_opt->answer);
     multip = atof(multip_opt->answer);
-    if (flag_v->answer) {
-	putenv("GRASS_VERBOSE=3");
-	G_warning(_("The '-v' flag is superseded and will be removed "
-		    "in future. Please use '--verbose' instead."));
+    if (strcmp(node_opt->answer, "none") == 0)
+	node_method = NODE_NONE;
+    else if (strcmp(node_opt->answer, "split") == 0)
+	node_method = NODE_EQUAL_SPLIT;
+    else
+	G_fatal_error(_("Unknown node method"));
+    kernel_function = KERNEL_GAUSSIAN;
+    if (strcmp(kernel_opt->answer, "uniform") == 0)
+	kernel_function = KERNEL_UNIFORM;
+    else if (strcmp(kernel_opt->answer, "triangular") == 0)
+	kernel_function = KERNEL_TRIANGULAR;
+    else if (strcmp(kernel_opt->answer, "epanechnikov") == 0)
+	kernel_function = KERNEL_EPANECHNIKOV;
+    else if (strcmp(kernel_opt->answer, "quartic") == 0)
+	kernel_function = KERNEL_QUARTIC;
+    else if (strcmp(kernel_opt->answer, "triweight") == 0)
+	kernel_function = KERNEL_TRIWEIGHT;
+    else if (strcmp(kernel_opt->answer, "gaussian") == 0)
+    else if (strcmp(kernel_opt->answer, "cosine") == 0)
+	kernel_function = KERNEL_COSINE;
+    else
+	G_fatal_error(_("Unknown kernel function"));
+    if (flag_o->answer) {
+	if (net_opt->answer) {
+	    if (node_method != NODE_NONE ||
+		kernel_function != KERNEL_GAUSSIAN) {
+		G_fatal_error(_("Optimal standard deviation calculation is supported only for node method 'none' and kernel function 'gaussian'."));
+	else if (kernel_function != KERNEL_GAUSSIAN) {
+	    G_fatal_error(_("Optimal standard deviation calculation is supported only for kernel function 'gaussian'."));
     if (flag_q->answer) {
 	flag_o->answer = 1;
@@ -219,7 +269,6 @@
 	int nlines, line;
-	int notreachable = 0;
 	struct line_pnts *Points;
 	Points = Vect_new_line_struct();
@@ -282,8 +331,8 @@
     /* valutazione distanza ottimale */
 	/* Note: sigmaOptimal calculates using ALL points (also those outside the region) */
-	G_message(_("Automatic choose of smoothing parameter (standard deviation), maximum possible "
-		   "value of standard deviation is was set to %f"), sigma);
+	G_message(_("Automatic choice of smoothing parameter (standard deviation), maximum possible "
+		   "value of standard deviation is set to %f"), sigma);
 	/* maximum distance 4*sigma (3.9*sigma ~ 1.0000), keep it small, otherwise it takes
 	 * too much points and calculation on network becomes slow */
@@ -334,12 +383,16 @@
     term = 1. / (pow(sigma, dimension) * pow((2. * M_PI), dimension / 2.));
-    dmax = sigma * 4.;
+    dmax = sigma;
+    if (kernel_function == KERNEL_GAUSSIAN)
+	dmax = sigma * 4.;
     if (net) {
 	int line, nlines;
 	struct line_pnts *Points, *SPoints;
 	struct line_cats *SCats;
+	double total = 0.0;
 	G_message(_("\nWriting output vector map using smooth parameter=%f."),
 		  sigma);
@@ -379,7 +432,8 @@
 			offset1, x, y);
 		compute_net_distance(x, y, &In, &Net, netmax, sigma, term,
-				     &gaussian, dmax);
+				     &gaussian, dmax, node_method,
+				     kernel_function);
 		gaussian *= multip;
 		if (gaussian > gausmax)
 		    gausmax = gaussian;
@@ -403,11 +457,44 @@
 		    Vect_cat_set(SCats, 1, (int)gaussian);
 		    Vect_write_line(&Out, GV_LINE, SPoints, SCats);
+		    total += length * gaussian;
 	    G_percent(line, nlines, 1);
+	if (flag_normalize->answer || flag_multiply->answer) {
+	    double m = multip;
+	    if (flag_normalize->answer) {
+		m /= total;
+	    if (flag_multiply->answer) {
+		m *= (Vect_get_num_primitives(&In, GV_POINT) - notreachable);
+	    Vect_build(&Out);
+	    gausmax = 0.0;
+	    nlines = Vect_get_num_lines(&Out);
+	    for (line = 1; line <= nlines; line++) {
+		int cat;
+		double gaussian;
+		Vect_read_line(&Out, SPoints, SCats, line);
+		Vect_cat_get(SCats, 1, &cat);
+		gaussian = m * cat;
+		Vect_reset_cats(SCats);
+		Vect_cat_set(SCats, 1, (int)gaussian);
+		Vect_rewrite_line(&Out, line, GV_LINE, SPoints, SCats);
+		if (gaussian > gausmax)
+		    gausmax = gaussian;
+	    Vect_build_partial(&Out, GV_BUILD_NONE);	/* to force rebuild */
 	Vect_close(&Net);
 	Vect_build(&Out);
@@ -436,7 +523,10 @@
 		N = G_row_to_northing(row + 0.5, &window);
 		E = G_col_to_easting(col + 0.5, &window);
-		compute_distance(N, E, &In, sigma, term, &gaussian, dmax);
+		/* compute_distance(N, E, &In, sigma, term, &gaussian, dmax); */
+		compute_distance(N, E, &In, sigma, term, &gaussian, dmax,
+				 kernel_function);
 		output_cell[col] = multip * gaussian;
 		    gausmax = gaussian;
@@ -447,7 +537,7 @@
 	G_close_cell(fdout);
-    G_message(_("Maximum value in output: %e."), gausmax);
+    G_message(_("Maximum value in output: %e."), multip * gausmax);
     Vect_close(&In);
@@ -597,66 +687,125 @@
     return (kk);
+/* get number of arcs for a node */
+int count_node_arcs(struct Map_info *Map, int node)
+    int i, n, line, type;
+    int count = 0;
+    n = Vect_get_node_n_lines(Map, node);
+    for (i = 0; i < n; i++) {
+	line = Vect_get_node_line(Map, node, i);
+	type = Vect_read_line(Map, NULL, NULL, abs(line));
+	if (type & GV_LINES)
+	    count++;
+    return count;
 /* Compute gausian for x, y along Net, using all points in In */
+			  int node_method, int kernel_function)
     int i;
-    double dist;
+    double dist, kernel;
     static struct line_pnts *Points = NULL;
+    static struct line_pnts *FPoints = NULL;
     BOUND_BOX box;
-    static struct ilist *List = NULL;
+    static struct ilist *PointsList = NULL;
+    static struct ilist *NodesList = NULL;
     if (!Points)
-    if (!List)
-	List = Vect_new_list();
+    if (!PointsList)
+	PointsList = Vect_new_list();
+    if (node_method == NODE_EQUAL_SPLIT) {
+	if (!NodesList)
+	    NodesList = Vect_new_list();
+	if (!FPoints)
+	    FPoints = Vect_new_line_struct();
     *gaussian = .0;
     /* The network is usually much bigger than dmax and to calculate shortest path is slow
-     * -> use spatial index to select points */
-    box.E = x + dmax;
-    box.W = x - dmax;
-    box.N = y + dmax;
-    box.S = y - dmax;
+     * -> use spatial index to select points
+     * enlarge the box by netmax (max permitted distance between a point and net) */
+    box.E = x + dmax + netmax;
+    box.W = x - dmax - netmax;
+    box.N = y + dmax + netmax;
+    box.S = y - dmax - netmax;
     box.T = PORT_DOUBLE_MAX;
     box.B = -PORT_DOUBLE_MAX;
-    Vect_select_lines_by_box(In, &box, GV_POINT, List);
-    G_debug(3, "  %d points in box", List->n_values);
+    Vect_select_lines_by_box(In, &box, GV_POINT, PointsList);
+    G_debug(3, "  %d points in box", PointsList->n_values);
-    for (i = 0; i < List->n_values; i++) {
+    for (i = 0; i < PointsList->n_values; i++) {
 	int line, ret;
-	line = List->value[i];
+	line = PointsList->value[i];
 	Vect_read_line(In, Points, NULL, line);
 	G_debug(3, "  SP: %f %f -> %f %f", x, y, Points->x[0], Points->y[0]);
-	ret =
-	    Vect_net_shortest_path_coor(Net, x, y, 0.0, Points->x[0],
-					Points->y[0], 0.0, netmax, netmax,
-					&dist, NULL, NULL, NULL, NULL, NULL,
-					NULL);
+	/*ret = Vect_net_shortest_path_coor(Net, x, y, 0.0, Points->x[0], */
+	/*Points->y[0], 0.0, netmax, netmax, */
+	/*&dist, NULL, NULL, NULL, NULL, NULL, */
+	/*NULL); */
+	ret = Vect_net_shortest_path_coor2(Net,
+					   Points->x[0], Points->y[0], 0.0,
+					   x, y, 0.0, netmax, 1.0,
+					   &dist, NULL,
+					   NULL, NodesList, FPoints, NULL,
+					   NULL, NULL);
 	if (ret == 0) {
 	    G_debug(3, "not reachable");
 	    continue;		/* Not reachable */
-	if (dist <= dmax)
-	    *gaussian += gaussianKernel(dist / sigma, term);
+	/* if (dist <= dmax)
+	 *gaussian += gaussianKernel(dist / sigma, term); */
+	if (dist > dmax)
+	    continue;
+	/* kernel = gaussianKernel(dist / sigma, term); */
+	kernel = kernelFunction(kernel_function, 1, sigma, dist);
+	    int j, node;
+	    double ndiv = 1.;
+	    int start = 0;
+	    /* Count the nodes and arcs on path (n1-1)*(n2-1)* ... (ns-1) */
+	    for (j = start; j < NodesList->n_values; j++) {
+		node = NodesList->value[j];
+		/* Divide into 2/n if point falls on a node */
+		if (j == 0 && FPoints->n_points < 3) {
+		    ndiv *= count_node_arcs(Net, node) / 2.;
+		else {
+		    ndiv *= count_node_arcs(Net, node) - 1;
+	    kernel /= ndiv;
+	*gaussian += kernel;
 	G_debug(3, "  dist = %f gaussian = %f", dist, *gaussian);
 		      double sigma, double term, double *gaussian,
-		      double dmax)
+		      double dmax, int kernel_function)
     int line, nlines;
     double a[2], b[2];
@@ -698,7 +847,9 @@
 	dist = euclidean_distance(a, b, 2);
 	if (dist <= dmax)
+	    /* *gaussian += gaussianKernel(dist / sigma, term); */
+	    *gaussian += kernelFunction(kernel_function, 2, sigma, dist);
