[GRASS-SVN] r47889 - grass-addons/grass7/gui/wxpython/wx.wms
Fri Aug 26 06:47:13 EDT 2011
Author: sudeepsingh
Date: 2011-08-26 03:47:13 -0700 (Fri, 26 Aug 2011)
New Revision: 47889
   grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py
   grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
   grass-addons/grass7/gui/wxpython/wx.wms/WMSMapDisplay.py
   grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
   grass-addons/grass7/gui/wxpython/wx.wms/parse.py
   grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
Debug messages removed
Modified: grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py
--- grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py	2011-08-25 16:58:39 UTC (rev 47888)
+++ grass-addons/grass7/gui/wxpython/wx.wms/LoadConfig.py	2011-08-26 10:47:13 UTC (rev 47889)
@@ -17,6 +17,7 @@
 import os
+import grass
 def loadConfigFile(self):
     try:
         f=open('config','r')
@@ -26,24 +27,17 @@
         #patch4s
         try:
             if(len(lines)!=3):
-                print 'Insufficient number of arguments,3 paramters required name_url_delimiter, timeoutValueSeconds, urlLength'
+                message = 'Insufficient number of arguments,3 paramters required name_url_delimiter, timeoutValueSeconds, urlLength'
+                grass.fatal_error(message)
                 raise Exception
             self.name_url_delimiter = lines[0].split(':')[1]
             self.timeoutValueSeconds = int(lines[1].split(':')[1])
             self.urlLength = int(lines[2].split(':')[1])
-            #self.name_url_delimiter = '\n'
-            print self.timeoutValueSeconds
         except Exception, e:
-            print e
-            print 'Internal exception, config file format error, using default values'
             self.name_url_delimiter = '#'
             self.timeoutValueSeconds = 5
             self.urlLength = 50
-        #patch4e
-        print "config file loaded successfully"
-        print self.name_url_delimiter
         return True
     except:
-    	os.system("find ./ -name config")
-    	print "Unable to load config file"
         return False
Modified: grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py
--- grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-08-25 16:58:39 UTC (rev 47888)
+++ grass-addons/grass7/gui/wxpython/wx.wms/ServerInfoAPIs.py	2011-08-26 10:47:13 UTC (rev 47889)
@@ -32,20 +32,13 @@
     if(os.path.exists(fileName)):
         try:
             f = open(fileName,'r')
-            print 'ServersList.xml found, loading ... '
         except:
-            print 'Unable to open File '+fileName
-            print 'exiting application...'
             return None, False
         xml = f.read()
         f.close()
         soup = BeautifulStoneSoup(xml)
         serverinfolist = soup.findAll('serverinfo')
-        #print 'serverinfolisthere'
-        #print serverinfolist
-        #print len(serverinfolist)
     else:
-    	print 'ServersList.xml not found, creating a new file'
         serverinfolist = []
         soup = BeautifulSoup()
         xml = "null"
@@ -74,23 +67,18 @@
     else:
         server = Tag(soup, "server")
         serverinfo.insert(0,server)
         #Creating server info tags
         servername = Tag(soup, "servername")
         serverurl = Tag(soup, "serverurl")
         username = Tag(soup, "username")
         password = Tag(soup, "password")
         #Inserting server info fields
         server.insert(0, servername)
         server.insert(1, serverurl)
         server.insert(2, username)
         server.insert(3, password)
         #Adding attribute to server tag
         server['id'] = uid
         #Adding text values to the server info fields
         servername.insert(0,snamevalue)
         serverurl.insert(0, urlvalue)
Modified: grass-addons/grass7/gui/wxpython/wx.wms/WMSMapDisplay.py
--- grass-addons/grass7/gui/wxpython/wx.wms/WMSMapDisplay.py	2011-08-25 16:58:39 UTC (rev 47888)
+++ grass-addons/grass7/gui/wxpython/wx.wms/WMSMapDisplay.py	2011-08-26 10:47:13 UTC (rev 47889)
@@ -33,7 +33,8 @@
         png = wx.Image(imageFile, wx.BITMAP_TYPE_ANY).ConvertToBitmap()
         wx.StaticBitmap(self, -1, png, (10 + png.GetWidth(), 5), (png.GetWidth(), png.GetHeight()))
     except IOError:
-        print "Image file %s not found" % imageFile
+        message = "Image file %s not found" % imageFile
+        grass.warning(message)
         raise SystemExit
 def NewImageFrame(tempFile):
Modified: grass-addons/grass7/gui/wxpython/wx.wms/addserver.py
--- grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-08-25 16:58:39 UTC (rev 47888)
+++ grass-addons/grass7/gui/wxpython/wx.wms/addserver.py	2011-08-26 10:47:13 UTC (rev 47889)
@@ -35,8 +35,6 @@
-# begin wxGlade: extracode
-# end wxGlade
 class ServerData():
     pass
@@ -85,7 +83,6 @@
         #sudeep code starts
         if( not loadConfigFile(self)):
-            print 'Config File Error, Unable to start application...'
             grass.fatal_error('Config File Error, Unable to start application...')
             self.Close()
@@ -158,22 +155,15 @@
         self.Layout()
         # end wxGlade
     def valueExists(self,dict, newServerName):
-        print 'Enter here'
-        print newServerName
         try:
             for key, value in dict.items():
-                #print key, value.servername
                 if(value.servername == newServerName):
-                    print 'returning true'
                     return True
-            print 'returning False'
             return False
         except:
-            print 'Exception while iterating dictionary elements'
             return False
     def OnSave(self, event): # wxGlade: ServerAdd.<event_handler>
-        #print "Event handler `OnSave' not implemented"
-        print '-------------------------------------------------------------------> OnSave'
         newServerName = unicode(self.ServerNameText.GetValue())
         newUrl = self.URLText.GetValue()
         newUserName = self.UsernameText.GetValue()
@@ -181,43 +171,14 @@
         if(not self.allFieldsValid(newServerName, newUrl, newUserName, newPassword)):
             return
-        print 'check12'
         if(self.selectedUid == None):
             update = False
         else:
             update = True
-        '''print newServerName
-        print self.map_servernameTouid
-        if(self.map_servernameTouid.has_key(newServerName)):
-            CurrentUid = self.map_servernameTouid[newServerName]
-            update = True
-            print 'key present'
-        else:
-            print 'key not present'
-            CurrentUid = None
-            update = False
-        if(self.servers.has_key(Uid)):StatusBar_fields = [character+' is not allowed in a Field']
-            self.StatusBar.SetStatusText(StatusBar_fields[0], 0)
-            update = True
-            #print 'Server Name already exists'
-            #return
-        else:
-            update = False'''
         serverData = ServerData()
-        #self.ServerList.Append(newServerName+" "+newUrl)
-        #url = newUrl.split()
-        #if(len(newUrl) != 0 and len(newServerName) != 0 and len(newUserName) !=0 and len(newPassword) != 0 ):
         if(len(newUrl) != 0 and len(newServerName) != 0):
             if(self.selectedServer is not None):
                 if(not self.selectedServer.servername == newServerName):
@@ -227,9 +188,8 @@
                         StatusBar_fields = [message]
-                        print message
                         return
-            #del self.servers[self.selectedUid]
             if(not newUrl.startswith('http://')):
                 newUrl = 'http://'+newUrl
@@ -244,140 +204,89 @@
-            print message
+            self.StatusBar.SetStatusText(StatusBar_fields[0], 0)
             serverData.servername = newServerName
             serverData.url = newUrl
             serverData.username = newUserName
             serverData.password = newPassword
             if(update):
                 if(updateServerInfo(self.soup, self.soup.serverinfo, self.selectedUid, newServerName, newUrl, newUserName, newPassword)):
-                    #patch7s
                     if(not self.saveXMLData()):
                         oldInfo = self.servers[self.selectedUid]
                         if(updateServerInfo(self.soup, self.soup.serverinfo, self.selectedUid, oldInfo.servername, oldInfo.url, oldInfo.username, oldInfo.password)):
                             message = 'Unable to SaveXML, changes reverted back'
-                            print message
                             return
                         else:
                             message = 'Unable to SaveXML, changes will be reverted back on restart'
-                            print message
                             return
-                    #patch7e
-                    #self.StatusBar.setStatusText("Information Updated")
                     message = 'update save successful'
-                    print message
                     grass.message(message)
                     self.servers[self.selectedUid] = serverData
                     del self.map_servernameTouid[self.selectedServer.servername]
                     self.selectedServer = serverData
                     self.map_servernameTouid[newServerName] = self.selectedUid
-                    #patch5s
                     msg = self.servers
-                    print 'sending serverlist as message'
                     Publisher().sendMessage(("update.serverList"), msg)
-                    print 'message sent'
                     msg = self.map_servernameTouid
-                    print 'sending map_servernameTouid as a message'
                     Publisher().sendMessage(("update.map_servernameTouid"), msg)
-                    #patch5e
                     message = "Server Info Updated"
-                    print message
-                    self.setModified(False)
+                    self.setModified(False)
                 else:
                     message = "Update not Successful"
                     self.ShowMessage(message, 'Warning')
-                    print message
             else:
                 uid = str(uuid.uuid4())
                 if(addServerInfo(self.soup, self.soup.serverinfo, uid, newServerName, newUrl, newUserName, newPassword)):
-                    #patch7s
-                        #oldInfo = self.servers[uid]
                         if(removeServerInfo(self.soup, uid)):
                             message = 'Unable to SaveXML, Info not saved'
-                            print message
                             return
                         else:
-                            print message
                             return
-                    #patch7e
                     message = 'soup save successfully'
-                    print message
                     self.selectedUid = uid
                     self.map_servernameTouid[newServerName] = uid
-                    print 'Onsave(): printing the self.map_servernameTouid'
-                    print '--------------------------'
-                    #self.saveXMLData()
-                            #patch5s
                     msg = self.servers
-                    #patch5e
-                    #msg = self.servers
                     message = "Server Info Saved Successfully"
-                    #Publisher().sendMessage(("update.serverList"), msg)
                 else:
                     message = "Save not successful"
-                    print message
-            f = open('serverList.txt','a')
-            f.write(newServerName+" "+newUrl+ " "+newUserName+" "+newPassword+"\n")
-            f.close()
             self.selectedURL = newUrl
-            print self.selectedURL
-            #print self.servers
             self.__update_URL_List()
-  	    #Update_Url_List(newServerName+" "+newUrl)
         else:
             message = "Please fill servername and url fields"
-            print message
         self.editOn = False
@@ -385,14 +294,12 @@
             event.Skip()
     def OnRemove(self, event): # wxGlade: ServerAdd.<event_handler>
-        print '-------------------------------------------------------------------> OnRemove'
             message = "No Server selected....Remove Unsuccessful"
-            print message
             return
         else:
             if(removeServerInfo(self.soup, self.selectedUid)):
@@ -419,7 +326,6 @@
-                print message
                 if(len(self.servers) > 0):
                     self.ServerList.SetSelection(0)
@@ -434,8 +340,6 @@
                 self.PasswordText.Clear()
                 self.URLText.Clear()
                 self.UsernameText.Clear()
                 msg = self.servers
             else:
@@ -444,22 +348,13 @@
-                print message
                 return
-        #print "Event handler `OnRemove' not implemented"
         self.editOn = False
         event.Skip()
     def OnAddNew(self, event): # wxGlade: ServerAdd.<event_handler>
-        #patch1s
         self.checkIfModified(event)
-        #patch1e
-        print '-------------------------------------------------------------------> OnAddNew'
-        #print "Event handler `OnAddNew' not implemented"
         self.selectedUid = None
         self.ServerNameText.Clear()
@@ -467,59 +362,34 @@
         self.editOn = False
         self.selectedServer=None
-        #patch3s
         StatusBar_fields = ["Fill in the Info fields"]
-        #patch3e
         event.Skip()
     def OnQuit(self, event): # wxGlade: ServerAdd.<event_handler>
-        print '-------------------------------------------------------------------> OnQuit'
-        print 'onQuit pressed'
-        #patch1s
         if(self.checkIfModified(event) == wx.ID_CANCEL):
             return
-        #patch1e
             message = 'Unable to write in file, Exiting Application'
-            print message
         msg = self.servers
         Publisher().sendMessage(("Add_Server_Frame_Closed"), msg)
         self.Destroy()
-        #exit()
-        #self.Close()
-        '''out = open('serverList.txt','w')
-        for k,v in self.servers.iteritems():
-            out.write(v.servername+" "+v.url+" "+v.username+" "+v.password+"\n")
-        exit()'''
-        #ServerAdd.Close()
-        #print "Event handler `OnQuit' not implemented"
         event.Skip()
     def OnServerList(self, event): # wxGlade: ServerAdd.<event_handler>
-        #patch1s
-        #patch1e
-        print '-------------------------------------------------------------------> OnServerList'
-        #print self.ServerList.CurrentSelection
         info = self.ServerList.GetValue()
         if(len(info) == 0):
             return
-        print 'here'
-        print info
         urlarr = info.split(self.name_url_delimiter)
-        print urlarr
         if(len(urlarr)==2):
             uid = self.map_servernameTouid[urlarr[0]]
             self.selectedServer = self.servers[uid]
-            print self.selectedServer
             self.ServerNameText.SetValue(self.selectedServer.servername)
             self.URLText.SetValue(self.selectedServer.url)
             self.UsernameText.SetValue(self.selectedServer.username)
@@ -528,19 +398,15 @@
             message = "Wrong format of URL selected"
-            print message
-        #self.ServerNameText.SetValue(self.servers)
         event.Skip()
     def OnText(self, event): # wxGlade: ServerAdd.<event_handler>
         self.editOn = True
         event.Skip()
     #wxGlade methods ends
-    #Sudeeps methods start
-    #patch1s
     def setModified(self, booleanValue):
         self.ServerNameText.SetModified(booleanValue)
         self.URLText.SetModified(booleanValue)
@@ -550,15 +416,13 @@
     def checkIfModified(self, event):
         if(self.URLText.IsModified() or self.ServerNameText.IsModified() or self.UsernameText.IsModified() or self.PasswordText.IsModified()):
             dial = wx.MessageDialog(None, 'You have unsaved changes.\n Do you want to save them ?', 'Quit',
-                                    wx.STAY_ON_TOP | wx.YES_NO | wx.YES_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
+                                    wx.STAY_ON_TOP | wx.YES_NO | wx.YES_DEFAULT | wx.CANCEL | wx.ICON_QUESTION)
             val = dial.ShowModal()
             if val == wx.ID_CANCEL:
                 return val
             if val == wx.ID_YES:
-                self.OnSave(event) #well, the parameter is unused
+                self.OnSave(event)
                 return val
-    #patch1e
     def ShowMessage(self, message, type = 'Warning'):
         wx.MessageBox(message, type)
@@ -567,11 +431,7 @@
         self.servers, self.map_servernameTouid = getAllRows(self.soup)
         ComboBox.Append("")
         for key, value in self.servers.items():
-            #string = '{0}{1}{2}'.format(value.servername,self.name_url_delimiter,value.url[0:self.urlLength])
-            #ComboBox.Append(string)
             ComboBox.Append(value.servername+self.name_url_delimiter+value.url[0:self.urlLength])
-            #ComboBox.Append(value.servername+" "+value.url)
         return
     def __update_URL_List(self):
@@ -579,30 +439,22 @@
         ComboBox = self.ServerList
         ComboBox.Append("")
         for key,value in self.servers.iteritems():
-            #name = v.servername+" "+v.url
-            #self.ServerList.Append(name)
     def saveXMLData(self):
-        xml = self.soup.prettify()
+        xml = self.soup.prettify()
         try:
             TMP = grass.tempfile()
             if TMP is None:
                 grass.fatal_error("Unable to create temporary files")
-            print TMP
             f = open(TMP,'w')
             f.write(xml)
             f.close()
         except:
             message = 'Unable to write in '+TMP+' file, Save not successful'
-            print message
             return False
         try:
-            #os.system('chmod 777 ServersList.xml')
             copyCommand = "cp "+TMP+" ServersList.xml"
             r, w, e = popen2.popen3(copyCommand)
             if(len(e.readlines())!=0):
@@ -615,14 +467,9 @@
             r.close()
             w.close()
             e.close()
-            #os.system("cp templist.xml ServersList.xml")
-            #f = open('ServersList.xml','w')
         except:
-            #print 'cant open file in write mode'
-            print 'cp templist.xml ServersList.xml failed'
-            print 'Save not successful'
             return False
         return True
     def allFieldsValid(self, newServerName, newUrl, newUserName, newPassword):
@@ -632,8 +479,6 @@
-                print "Warning: UserName cannot consist of "+self.name_url_delimiter
-                print "Please give another username, save failed..."
                 return False
         if(newUrl.count(self.name_url_delimiter)>0):
@@ -642,8 +487,6 @@
-                print "Warning: URL cannot consist of "+self.name_url_delimiter
-                print "Change in config file required to use different character as delimeter which doesnot appears in url"
                 return False
         character = '>'
@@ -653,7 +496,6 @@
-            print message
             return False
         character = '<'
@@ -663,20 +505,15 @@
-            print message
             return False
         character = '&'
-        #patch2s
-        #or newUrl.count(character) > 0
-        #patch2e
         if(newServerName.count(character) > 0  or newUserName.count(character) > 0 or newPassword.count(character) > 0):
             message = character+' is not allowed in a Field'
-            print message
             return False
         return True
@@ -713,26 +550,6 @@
         self.Close()
         self.Destroy()
         return
-    def OnPopupSaveRequest(self, msg):
-        self.OnSave(None)
-        self.saveXMLData()
-        msg = self.servers
-        Publisher().sendMessage(("Add_Server_Frame_Closed"), msg)
-        self.Quit
-        self.Close()
-        #self.Destroy()
-    def OnPopupNotSaveRequest(self, msg):
-        self.Close()
-        self.Destroy()
-    def OnPopupCancelRequest(self, msg):
-        return
 # end of class ServerAdd
 def AddServerFrame(parentWMS):
Modified: grass-addons/grass7/gui/wxpython/wx.wms/parse.py
--- grass-addons/grass7/gui/wxpython/wx.wms/parse.py	2011-08-25 16:58:39 UTC (rev 47888)
+++ grass-addons/grass7/gui/wxpython/wx.wms/parse.py	2011-08-26 10:47:13 UTC (rev 47889)
@@ -60,9 +60,7 @@
  soup = BeautifulSoup(xmltext)
  #layers = soup.findAll('layer', queryable="1")
  layers = soup.findAll('layer')
- for attr, value in soup.find('layer').attrs:
- 	print attr, "       =          ", value '''
  namelist = []
  for layer in layers:
 	soupname = BeautifulSoup(str(layer))
@@ -70,15 +68,9 @@
 	if len(names) > 0:
 		namelist += names[0]
  return namelist
-f = open('wmsmaris.xml','r')
-a=f.read()
-print a
-#parsexml(a) '''
 def parsexml2(xml):
- print 'c1'
  layerDataDict={}
  count = -1
  xmltext = xml
@@ -86,46 +78,33 @@
  namelist = []
 	names =  soupname.findAll('name')
 	titles = soupname.findAll('title')
 	abstracts = soupname.findAll('abstract')
 	srs = soupname.findAll('srs')
-	print 'c2'
-	print names
-	print titles
-	print abstracts
-	print srs
-	print 'a1'
 	if(len(names)>0):
 		count = count + 1
 		layerDataDict[count] = LayerData()
 		layerDataDict[count].name = unicode(names[0].string)
-		print layerDataDict[count].name
 	else:
 		continue
-	print 'a2'
 	if(len(titles)>0):
-		print 'b1'
 		layerDataDict[count].title = unicode(titles[0].string)
-		print 'b2'
 	else:
-		print 'b3'
 		layerDataDict[count].title = ''
-		print 'b4'
-	print 'a3'
 	if(len(abstracts)>0):
 		layerDataDict[count].abstract = unicode(abstracts[0].string)
 	else:
 		layerDataDict[count].abstract = ''
-	print 'a4'
 	if(len(srs)>0):
 		layerDataDict[count].srs = srs
 	else:
 		layerDataDict[count].srs = ''
-	print 'c3'
  return layerDataDict
@@ -133,45 +112,29 @@
 def isValidResponse(xml):
 	soup = BeautifulSoup(xml)
 	getCapabilities = soup.findAll('wmt_ms_capabilities')
-	print 'heeeeeeeeereeeeee'
-	print len(getCapabilities)
 	if(len(getCapabilities)==0):
-		print 'False'
 		return False
 	else:
-		print 'True'
 		return True
 def isServiceException(xml):
-	print 'here'
-	#print xml
-	#print soup
 	exceptions = soup.findAll('ServiceException')
-	#print exceptions
 	exceptionList = []
 	xmltext = str(xml)
 	if(xmltext.count('ServiceException') > 0):
 		return True
 	else:
 		return False
-	print 'done'
 def populateLayerTree(xml,LayerTree, layerTreeRoot):
 	if TMP is None:
 		grass.fatal("Unable to create temporary files")
-	print '########################'
-	print TMP
 	f = open(TMP,'w')
 	f.write(xml)
 	f.close()
 	f = open(TMP,'r')
 	xml = f.read()
-	#print xml
 	dfs(soup,LayerTree, layerTreeRoot)
@@ -200,5 +163,4 @@
 	g = grassRegion[s:]
 	g = g.split()
 	g = g[1].strip(';')
-	print g
 	return float(g)
Modified: grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py
--- grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-25 16:58:39 UTC (rev 47888)
+++ grass-addons/grass7/gui/wxpython/wx.wms/wmsmenu.py	2011-08-26 10:47:13 UTC (rev 47889)
@@ -35,9 +35,6 @@
 from LoadConfig import loadConfigFile
-# end wxGlade
 class LayerData():
     name = None
     title = None
@@ -74,19 +71,7 @@
                 a = srs.string
                 a = a.split(':')
                 l = l+[a[1]]
-            print 'here'
-            print 'key = ' + str(key)
-            print l
-            print 'now'
             keytoepsgcodes[str(key)] = l
-            print 'dict value now is '
-            print keytoepsgcodes
-            print 'dict printed'
-        print 'final dict'
-        print 'final dcit printed'
         return keytoepsgcodes
 class Message():
@@ -123,14 +108,10 @@
         self.Bind(wx.EVT_BUTTON, self.OnGetMaps, self.GetMaps)
         self.Bind(wx.EVT_BUTTON, self.OnAddServer, self.addServer)
         # end wxGlade
-        #Sudeep's Code Starts
-        #self.urlInput.SetValue('http://www.gisnet.lv/cgi-bin/topo')
         self.usernameInput.Disable()
         self.passwordInput.Disable()
-        print 'new version'
             self.Close()
             return
@@ -152,10 +133,6 @@
         self.layerName = ""
         self.selectedEPSG = None
-        #items = ["a", "b", "c"]
-        #itemId = self.LayerTree.AppendItem(self.layerTreeRoot, "item")
-        #self.LayerTree.AppendItem(itemId, "inside")
-        #Sudeep's Code Ends
     def __set_properties(self):
         # begin wxGlade: wmsFrame.__set_properties
         self.SetTitle("wmsFrame")
@@ -199,36 +176,23 @@
     def OnGetCapabilities(self, event): # wxGlade: wmsFrame.<event_handler>
-        ''''f=open('check.xml','r')
-        xml=f.read()
-        f.close()
-        layerDataDict = parsexml2(xml)
-        ld = LayerData()
-        #ld.printLayerData(layerDataDict)
-        ld.appendLayerTree(layerDataDict, self.LayerTree, self.layerTreeRoot)
-        self.LayerTree.Expand(self.layerTreeRoot)
-        return'''
         if(self.selectedURL == "No server selected"):
             message = 'No Server selected'
-            print message
             return
         try:
             self.epsgList.SetSelection(0)
         except:
-            print 'epsg list is empty'
+            message = 'epsg list is empty'
         self.usernameInput.Enable()
         self.passwordInput.Enable()
-        #url = 'http://www.gisnet.lv/cgi-bin/topo?request=GetCapabilities&service=wms&version=1.1.1'
-        self.LayerTree.CollapseAndReset(self.layerTreeRoot)
-        #url = self.urlInput.GetValue()
+        self.LayerTree.CollapseAndReset(self.layerTreeRoot)
         url = self.selectedURL
         url = url + '?request=GetCapabilities&service=wms&version=1.1.1'
-        print url
         StatusBar_fields = ["GetCapabilities Request Sent..."]
         req = Request(url)
@@ -241,61 +205,35 @@
-                print message
                 return
             if(isServiceException(xml)):
                 message = 'Service Exception in Get Capabilities'
-                grass.warning(message)
-                print message
                 return
-            #for testing pruposes
-            #f=open('in1.xml','r')
-            #xml=f.read()
-            #f.close()
-            #self.statusbar.SetStatusText(xml)
-            #reslist = parsexml(xml)
-            #populateLayerTree(xml,self.LayerTree, self.layerTreeRoot)
-            print 'check1'
-            print 'check2'
             ld = LayerData()
-            print 'check3'
             self.keyToEPSGCodes = ld.setKeyToEPSGCodes(layerDataDict)
-            print self.keyToEPSGCodes
-            print 'check4'
-            #for res in reslist:
-            #       self.LayerTree.AppendItem(self.layerTreeRoot, res)
-            #self.Layers.SetValue(st)
-            #print xml
         except HTTPError, e:
             message = 'The server couldn\'t fulfill the request.'
-            print message
-            #print 'Error code: ', e.code
+            message = str(e)
         except URLError, e:
             message = 'Failed to reach a server.'
-            print message
-            #print 'Reason: ', e.reason
+            message = str(e)
         except ValueError, e:
             message = 'Value error'
-            print message
+            message = str(e)
             message = 'urlopen exception, unable to fetch data for getcapabilities'
             message = str(e)
-            print 'printing exception here'
-            print message
-            print 'done'
         else:
             message = 'Successful'
-            print message
         if(not message=='Successful'):
@@ -310,13 +248,8 @@
     def OnGetMaps(self, event): # wxGlade: wmsFrame.<event_handler>
-        #self.layerName = self.layerSelected.GetValue()
             message = 'No server selected'
-            print message
@@ -325,7 +258,6 @@
         if(self.selectedEPSG == None):
             message = 'No EPSG code selected'
-            print message
@@ -333,12 +265,10 @@
             return
         if(not self.selectedEPSG.isdigit()):
             message = 'EPSG code selected is not a number'
-            print message
             return
         bbox = self.getBBOXParameters()
@@ -347,24 +277,18 @@
         getMap_request_url = self.url_in
         getMap_request_url += '?service=WMS&request=GetMap&version=1.1.1&format=image/png&width=800&height=600&srs=EPSG:'+self.selectedEPSG+'&layers='
         getMap_request_url += self.layerName+'&bbox='+bbox
-        #'584344,397868,585500,398500'
-        print bbox
-        print getMap_request_url
         req = Request(getMap_request_url)
         try:
             message = 'GetMaps request sent. Waiting for response...'
             response = urlopen(req, None, self.timeoutValueSeconds)
             image = response.read()
-            #print image
             if(isServiceException(image)):
                 message = 'Service Exception has occured'
-                print message
@@ -372,17 +296,12 @@
                 if TMP is None:
-                print TMP
                 outfile = open(TMP,'wb')
                 outfile.write(image)
                 outfile.close()
                 if(imghdr.what(TMP) != 'png'):
-                    #print 'uiui'
-                    #print imghdr.what('./map.png')
                     message = 'Not a valid PNG Image, Unable to display Map'
-                    print message
@@ -396,24 +315,19 @@
-            print message
+            message = str(e)
         except URLError, e:
-            print message
+            message = str(e)
-            print message
-        except:
+            message = str(e)
+        except Exception, e:
-            print message
+            message = str(e)
         else:
-            print message
-        print message
         if(message != 'Successful'):
@@ -423,103 +337,53 @@
         event.Skip()
-    def OnServerListEnter(self, event): # wxGlade: wmsFrame.<event_handler>
-        return
-        print "Event handler `OnServerListEnter' not implemented"
-        print self.ServerList.CurrentSelection
-        newUrl = self.ServerList.GetValue()
-        self.ServerList.Append(newUrl)
-        url = newUrl.split()
-        if(len(url)==2):
-            self.servers[url[0]] = url[1]
-            f.write(newUrl+"\n")
-            f.close()
-            self.selectedURL = url[1]
-            print self.servers
-        else:
-            print "Format not recognized, Format: Severname URL"
-        event.Skip()
     def OnEPSGList(self,event):
         info = self.epsgList.GetValue()
         if(not info.isdigit()):
             message = 'Please select an EPSG Code'
-            print message
             seld.show_message(message)
             return
         self.selectedEPSG = info
-        print 'epsg = '+info
     def OnServerList(self, event): # wxGlade: wmsFrame.<event_handler>
-        print "Event handler `OnServerList' not implemented"
         if(len(info) == 0):
             return
-        print "OnServerList:printing urlarr"
-        print urlarr
-        print urlarr[0]
-        #print urlarr[0].encode()
-        #self.printDict(self.servers)
-        print "OnServerList: done"
         if(len(urlarr)==2):
             try:
             	self.selectedURL = self.servers[uid].url
             except KeyError,e:
-                print e
             	message = 'key error reported'
-                print message
         else:
-            print message
         event.Skip()
     def OnLayerTreeActivated(self, event): # wxGlade: wmsFrame.<event_handler>
-        print "OnLayerTreeActivated: ", self.LayerTree.GetItemText(event.GetItem())
-        print "Event handler `OnLayerTreeActivated' not implemented"
         event.Skip()
+    def OnServerListEnter(self, event): # wxGlade: wmsFrame.<event_handler>
+        event.Skip()
-    def OnLayerTreeSelChanged(self, event): # wxGlade: wmsFrame.<event_handler>
-        #self.layerName = self.LayerTree.GetItemText(event.GetItem())
-        #print "Event handler `OnLayerTreeSelChanged' not implemented"
+    def OnLayerTreeSelChanged(self, event): # wxGlade: wmsFrame.<event_handler>"
         self.epsgList.Clear()
         self.epsgList.Append('')
         self.selectedLayerList = []
         keys =[]
         self.layerName = ""
-        print "Selected layers:"
         for sellayer in self.LayerTree.GetSelections():
             layerNameString = self.LayerTree.GetItemText(sellayer)
-            print 'here'
-            print layerNameString
             layerNameStringList = layerNameString.split(':')
-            print layerNameStringList
-            print len(layerNameStringList)
             if(len(layerNameStringList)==0):
                 message = 'Unable to select layers'
@@ -529,65 +393,41 @@
                 return
             layerName = layerNameStringList[0].split('-')[1]
             key = layerNameStringList[0].split('-')[0]
-            print layerName
-            print 'done'
             self.selectedLayerList += [layerName]
             self.layerName += ","+layerName
             keys += [key]
             lEPSG = self.keyToEPSGCodes[key]
             self.epsgList.Append('<'+layerName+'>')
             self.epsgList.AppendItems(lEPSG)
         self.layerName = self.layerName[1:]
-        print self.layerName
-        #for key in keys:
-        #    lEPSG = self.keyToEPSGCodes[key]
-        #    self.epsgList.AppendItems(lEPSG)
         event.Skip()
     def OnAddServer(self, event): # wxGlade: wmsFrame.<event_handler>
-        print 'before add server call'
         self.AddServerisClosed = False
         self.addServer.Disable()
         AddServerFrame(self)
-        #print 'after add server call'
-        #print "Event handler `OnAddServer' not implemented"
-        #event.Skip()
         return
     def onAddServerFrameClose(self, msg):
         self.AddServerisClosed = True
         self.addServer.Enable()
-        #frame = self.GetParent()
-        #frame.Show()
     def onUpdateServerListmessage(self, msg):
-        #patch5s
         self.servers = msg.data
-        print 'in update serverlistmessage()'
-        print 'printing serverlist'
-        self.printDict(self.servers)
-        #patch5e
+        #self.printDict(self.servers)
         self.__update_Url_List(self.ServerList)
-        #patch5s
-    def onUpdateMapListmessage(self, msg):
-        print 'in update maplistmessage()'
+    def onUpdateMapListmessage(self, msg):
         self.map_servernameTouid = msg.data
-        print 'printing map_servernametouid'
-        self.printDict(self.map_servernameTouid)
-        #patch5e
+        #self.printDict(self.map_servernameTouid)
         msg = ""
-        print 'in quit'
         if(not self.AddServerisClosed):
             Publisher().sendMessage(("WMS_Menu_Close"), msg)
         self.Destroy()
@@ -600,22 +440,15 @@
         ComboBox.Clear()
         ComboBox.Append("")
-            #ComboBox.Append(value.servername+" "+self.name_url_delimiter+" "+value.url)
         return
     def __populate_Url_List(self, ComboBox):
         ComboBox.Append("")
         return
     def getBBOXParameters(self):
@@ -641,17 +474,6 @@
         res = str(minx)+','+str(miny)+','+str(maxx)+','+str(maxy)
         return res
-        '''f = open('serverList.txt','r')
-        lines = f.readlines()
-        self.servers = {}
-        for line in lines:
-            row = line.split()
-            print row
-            if(len(row) == 4) :
-                self.servers[row[0]] = row[1]
-            name = row[0]+" "+row[1][7:45]
-            ComboBox.Append(name)
-        f.close()'''
     def printDict(self,dict):
         for key in dict.keys():
@@ -660,16 +482,13 @@
 # end of class wmsFrame
-#Sudeep's Code Starts
 def DisplayWMSMenu():
-        print 'DisplayWMSMenu loaded...'
         app = wx.PySimpleApp(0)
         wx.InitAllImageHandlers()
         wms_Frame = wmsFrame(None, -1, "")
         app.SetTopWindow(wms_Frame)
         wms_Frame.Show()
         app.MainLoop()
-#Sudeep's Code Ends
 if __name__ == "__main__":
